Question about Orion STV2763 27" TV
Orion tv wont turn on after power outage
I had it on and the power went out, now power is back and it wont turn on
    Sergeant:
  • 214 Answers
I would get it serviced. There can be something wrong with it that might not naturally fail.
Posted on Nov 03, 2012
After a power outage, the tv wont turn back on. was hoping there is a fuse that may have blown.
Hi Michael,
Yes there is a fuse in your TV too and sometimes you do escape with a blown fuse after a power outage. Please open if you can the back cover of your TV, locate the fuse. If you do not see any damaged or blown parts, replace the fuse with the same rating. If the works, enjoy watching. If the fuse blows again, the power board needs to be repaired or replaced.
Good luck.
Apr 04, 2016 | Sanyo Televison & Video
The power went off and wen it came back on the tv wont turn back on
If your power outage wad caused by a surge your tv may have died. Check fusebox for tripped circuit breaker also check tv wall plug fuse in case that has blown. It might be that the tv internal fuse has blown, you should disconnect the tvv from the electricity supply if you intend opening the rear of the set to check this.
If they are all okay the set probably needs the services of a trained technician
Good Luck
Jun 08, 2015 | Televison & Video
My tv wont come back on
Check the power cord to the television if you are unable to turn it on with the "Power" button on the front. Make sure the cord is connected properly to the television and to a working AC outlet. If a power outage has occurred, unplug the television for 30 minutes to allow it to reset and plug it back in.
Feb 01, 2013 | Sylvania LC-225SL9 22 in. LCD TV
Power in house went out. T.V. wont turn on.
Did you have a surge protector on the TV? Have you tried unplugging it for 5 minutes, if not try that. If it still won't work contact your local electrical power provider and start a claim for damages from the power outage.
Jan 24, 2012 | iLO Televison & Video
I was watching my hitachi plasma tv when the power went off it wont turn on no clicking or any noisy
If you still have led lit on front panel, then you know main ac fuse is good. Check fuses on y sustain board and z sustain board and there will be other fuses in the secondary of the power supply board.
check those also.
Nov 27, 2011 | Televison & Video
The power outage went out yesterday and my tv wont turn on
Most likely it is capacitors on the dm board that have gone bad. This is a fairly common problem and has been addressed on fixya many times. If you know someone who is good with soldering and technically incline or even an honest electronics guy then the repair is quite cheap. If you have any other questions please let me know. if its not the capacitors on the DM supply then its a problem with the whole DM assembly that part usually is around 300$. So you may want to consider purchasing a new tv. Trying the 7 caps on the dm supply board shouldn't cost much if it takes anything more then that. I would sell the tv on craigslist or ebay and recoup as much as you can towards your next tv.
thank you,
lee
Thank you,
lee
Apr 01, 2010 | Mitsubishi WS-55511 55" Rear Projection...
ILO 2706 TV WONT TURN ON
This TV might have been affected by the power outage even if it was not ON at that moment. There is a standby voltage still present even when OFF and connected to the AC line.
There might be different failures on this TV:
1. The power supply might be defective after the power outage.
2. The main board could also be defective since the power supplies for today's TVs are not well regulated and once the voltage getting to the power supply increases, the standby voltage voltage will also increase damaging voltage sensitive components like the microprocessor or memory circuitry.
Let me know if you require further assistance.
Dec 18, 2008 | iLO 2600 Television
50 inch dlp wont restart after power outage
did you replace the light bulb from the back of the tv set ?
check if its blown ?
if so just replace and your good to go ....
Aug 07, 2008 | Toshiba 50HM66 52" Television
My orion tv
We had this same problem, and this is what resolved it. Unplug the tv from the wall, wait a minute, plug it back up, and turn it on again with the "power" button. This worked for us (without a remote).
Jun 29, 2008 | Orion STV2763 27" TV
Orion 1934
RGB circuit trouble?? crt should be ok,get it checked anyway.May be adjustible in servicer menu.
Aug 22, 2007 | Orion1934 19" TV
Orion STV2763 27" TV Logo
313 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
