Question about Necchi Sewing Machines
Walking foot jams for my model 4795. The actuator lever hangs up it looks like the stroke is too long
4 Suggested Answers
  • 22 Answers
SOURCE: I need a walking foot for a Necchi Model 4795 for Quilting.
http://www.sew4less.com/product/2034/Low_ShankEven_Feed_and_Walking_Foot_and_Quilting_Foot_10449
Posted on Jan 12, 2009
Michaelle
  • 65 Answers
SOURCE: Walking Foot for Brother LS-1217
Beckster, it may simply be that the walking foot needs to be tweeked a bit, perhaps screwed in further, or less.
If that doesn't help ...
Check out this site. All the Q&A answers in simple language, as well as a GREAT cust. support staff. (its a Brother after all!)
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/model_top/HomeSewingMachine/hf_ls1217eus.html?reg=us&c=us_ot&lang=en&prod=hf_ls1217eus
Posted on Jan 24, 2009
SOURCE: thread jamming, wont feed material, sewing in one place
Try moving the stitch length dial to 4 or 5 - check the manual. You may have it in the position for very close together sewing. I had to do a lot of trying with my 4795 to get it to work right. I found that very thin thread, polyester kind, broke at the needle after a couple of stitches. I switched to coats & clarks thread and a Singer ball point needle and it works fine. Be sure your needle is inserted with the flat top toward the back of the machine. Good luck!
Posted on May 27, 2009
I have a Necchi Royal Series 4795 and I can only use a straight stitch. How do you set this machine to other stitches(hemming,serging)? just need to know what dials to set for which stitch & what foot
try --www.yumaeng.com-- for a pdf version user manual for the machine
that should give you all the information on what to do for the stitches you want
go google and type in ---user manual for necchi sewing machine model 4795-- as there other sites with user manuals as well
Jan 04, 2017 | Necchi Sewing Machines
Why doesn't walking mechanism work?
if the pressor foot anvil doesn't move up and down /back/forth , the machine might be in "DARNING " mode this is usually a small button in the bobbin area , but some machines have them on the back of cabinet as well
Feb 26, 2016 | Sewing Machines
Old Bernina 830 walking foot not pulling item through.Lever not letting foot down completely but can push it down the rest of the way with my fingers
Hi Linda:
Does your 830 have a black needle clamp and screw instead of the standard nickel plated clamp? If not, the walking foot forked driving lever may be damaged by having used the machine with zigzag engaged. Another problem with older 830 machines is that the needle clamp has been repeatedly tightened very tight, causing the needle bar base to become damaged so that the clamp is no longer perpendicular to the direction of sewing...In other words, the clamp sets crooked on the needle bar.
The black clamp made for the walking foot had a specific diameter for the forked driving lever of the walking foot. The black clamp was also longer so that when using a wide stitch width, the driving fork of the walking foot did not collide with the needle bar clamp screw on the right side.
Please reply with your observations.
Oct 29, 2015 | Bernina Sewing Machines
Rod.carmichael4@gmailwalking foot doesn't work
Check to see that the lever on the walking foot is on top of the needle bar on the machine. When the needle is going up and down, it moves the lever on the walking foot which make the little pastic feet move.
Apr 21, 2011 | Janome L-344 Mechanical Sewing Machine
I purchased an Elna 7000 on E-Bay.Wonderful machine. I also purchased a 492000-20 walking foot for it. I can not find instructions on how to attach the walking foot to the machine.
I'm assuming that this is a generic style walking foot for low shank machines and it will fit your Elna?
To attach it, you will see a long lever arm at the front of the foot and the little curved bracket at the back of the foot.
Remove your usual foot and the clip on foot holder by undoing the thumb screw. Now fit the walking foot on instead by putting the lever arm around the needle bar and the curved bracket around the pressure bar and then putting the thumb screw back into place and screw up tight to hold the foot in place. Now lower the pressure foot and manually wind your machine forward a few stitches. As the needle bar goes up and down, it should move the long lever arm too which works the walking foot teeth gripping the top layer of fabric with each stitch.
Trust this helps.
Mar 24, 2011 | Elna 8007
Jan 12, 2009 | Necchi 4595 Mechanical Sewing Machine
Elna walking foot
If your SU is an Air Electronic model i.e. 80's model, Elna didn't make a walking foot to fit. However, if you've got a walking foot that is the same height from sole plate to the screw fitting as a standard Elna foot then you could give it a try. The walking foot connects to the presser bar with a screw but the needle bar also needs to hook into a secondary lever on the side of the walking foot to make the foot actually move. Probably sounds very confusing . Check the movement of the foot manually by hand turning the fly wheel to see how it works before you actually use with the motor to minimise any problems if the foot doesn't fit.
Also you'll probably only be able to do straight stitch with this foot due to the clearance around the needle plate.
Oct 27, 2008 | Elna 2007 Mechanical Sewing Machine
On my singer 9005 the pressure foot lifter does not stay in the up position - does not hold the pressure foot up.
These plastic presser bar lifters do wear out a lot ,very common,,,,,,,,You can lift it up and file as close to the machine side on top just a couple of stroke son the file will usually give it a surface to hang on and it will stay up ,much easier than changing the plastic lever
Aug 09, 2008 | Singer 7444 Mechanical Sewing Machine
Manuals/Video
Contact Allyn International INC. which are the distributors in the US. Model 4795 and 4595 are the same but one is the instructional type I think, that's what the person I talked to told me. I got a free video and booklet from them. Fortunately my machine came with the manual, but it was not enough for the hemmer foot and I also needed some help with the overcasting stitches. This booklet explain all the stitches, the foot you need to use and the proper width and length of the stitch.
Feb 15, 2008 | Necchi 4595 Mechanical Sewing Machine
Sewing Machines Logo
22 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
