My Bosch front loading washer is not draining.
  • 15,935 Answers
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Bosch 100 series will not drain
You need to check and clean the pump filter if you have not already done so.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
Mar 15, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
How do I winterize bosch front loader washing machine
Turn off the water supply to the washer, and disconnect the inlet hoses, remove the drain outlet hose and lay it down to drain any water in the hose.
Remove filter, and drain water off inside.
That should do it.
Hope this helps.
Dec 10, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch nexxt washer fabric softener not draining
is there a drain on the bottom left corner if so drain the contents its usually under a small panel
Sep 14, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Water wont drain from my front loader bosch axxis washer and no spin cycle
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
May 05, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch washer - taking apart the anti-siphon valve
I have a Bosch Nexxt Washer when it goes into the spin cycle I get EOO2 and the washer stops
Mar 20, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
My Bosch 2060 Front end loader will not drain/spin
Get the pennies or dimes out of the accordian style black hose at the bottom of the washer. You will need to lay the washer against something so you can get in from underneath. Take a plyers and squeeze the medal clamp so the hose can slip off. I found 3 dimes that acted like washers. The machine will drain.
Jul 08, 2008 | Bosch Axxis WFL 2060 Front Load Washer
I have a bosch wfmc 2100 washer that doesn't drain
Have a look on the Bosch web site, they offer solutions to some problems, if not contact them via email
Jan 01, 2008 | Bosch WFMC 2100 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
