Electronics over-ride? Can we use our electronically started and electrically vented Valiant furnace when our power is out? The furnace is powered by propane and was installed in 1997.
    Problem Solver:
  • 9 Answers
I don't think you can as to the fact that it has electronic parts the operate the main components unless you have a generator to power it up thats just my opinion actuallly I'm pretty sure you can't.
Posted on Nov 04, 2012
  • 108 Answers
SOURCE: goodman gas furnace power vent motor and housing replacement
You need to type GOODMAN GAS APPLIANCES into you browser to find you local servicecenter. I must tell you that Goodman only sells to authorized service companies in my experience. So you become EgKraft Company.
Posted on Nov 07, 2008
  • 15 Answers
SOURCE: Venting a Dayton 4E454 24,000 BTU gas furnace
If you intend to use this in a residential garage, you will have to use standard galvanized round pipe coming off the unit, 24 gauge will suffice, use a minimum of 6”-8” from the unit. From there you will have to make the transition to the B-Vent. Always double check with you local codes in your area.
Hope this helps.
Posted on Dec 02, 2008
  • 252 Answers
SOURCE: furnace clicks multipal times while running.Is this normal?
As it starts and stops several switches will open and/or close, sometimes you can hear them. When it's just running then it may make a few noises from expansion and/or contraction.
Posted on Mar 31, 2009
  • 53 Answers
SOURCE: Vulcan Quasar 40 wall furnace - electronic display problem
Have a gasfitter bypass the clock. The clock is the source of the problem. You will then have a manually operated heater.
Posted on Oct 08, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: We have a coleman electronic ignite propane
This furnace should have a diagnostic light that will give you a starting point where to look. It is located on the control board and will blink a code. If you remove the panel with the door switch on it, you will erase the code. Look for a small viewing port that looks on to the circuit board. Once you get the code, look on the wiring diagram for a explaination of the codes.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Posted on Jan 24, 2010
Leviton Decora PIR Wall Switch Sensor won't work in auto when the garage when it's hot
Heat is the enemy of electricity, especially electronics.
The public doesn't understand how global warming is going to affect electrical devices including your phone, timers, detectors, and all electrical power.
If you research operational temperatures for small electronic devices, the upper range is usually 105-120 degrees F. Some can operate up to 135 degrees F, and will fail in higher temperatures because the circuit board, chip and parts are made to withstand certain temperature tolerances.
High temperature hardened devices cost more than typical box store electronic device.
There can also be a low temperature range that affects batteries and rechargeable batteries inside devices that have display properties.
Back to high heat: Electronics are limited by high heat.
Electrical transmission along power lines is limited because of high heat. Long distance transmission is high voltage and low amperage to reduce heat caused by high amperage.
(Super conductive materials, that allow limitless transmission without loss, must be at very low temperatures (absolute zero, etc))
And then at your house, the high voltage low amperage power line is changed to lower voltage high amperage at the transformer before it enters your home.
If you get serious electrical shock, you will get burned because electricity is Hot. The power line in electrical circuit is called the Hot line. So electricity is all about heat.
http://waterheatertimer.org/See-inside-main-breaker-box.html
Unrelated to electronics, but related to global warming: Even gas water heaters inside hot attic will lose the pilot light because the heat pushes air molecules farther apart, making it harder to breathe, and causing the pilot flame not to have enough oxygen to support combustion.
People should consider if we will be able to make small fires if global temperatures get hot enough.
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas Water-Heaters.pdf
This means the short-term solution to your electronic problem is to open a window slightly in the garage.
Better yet is to install natural ventilation.
Install a vent(s) on the wall, down low along floor on shaded side of garage. Then install another vent(s) on wall near ceiling, or install a vent pipe to roof.
The combination of high-and-low vent will cause a natural flow of air through the garage. This is the same principle used to ventilate an attic.
Aug 24, 2012 | Leviton R01-PR180-1LI Decora 180 Degree...
No power when i turn the key to ignition, but if i turn to acc, i get guage light and mileage.
Hi Anonymous, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve vacuum line broken or carburator vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump, pressure regulator and or fuel injectors.
For a prime suspect please visit website below and good luck:
Harley Diagnostic Codes 04 to Present
Apr 30, 2012 | 2008 Harley Davidson FXD Dyna Super Glide
Winding like a motor trying to be started, over
You probably have water in the bottom of the blower housing, and need to remove it and empty it. Be "VERY" careful, because water and electricity do not mix. if you cannot do it, you should call a furnace company to check it and give you an estimate. Also. make sure the power is off before even touching the unit.Your situation "IS" very dangerous.
Feb 21, 2010 | Honeywell Electronic Programmable...
I have a coleman evcon furnace that wont work. The electrical box green light is not on at all so it cannot pinpoint what the error is. Any thoughts?
Hi, I would just make sure you have power to the furnace. Check breakers or look for the power switch on the electrical box. Also, some mobile homes have a wall switch that cuts power to the furnace.
Jan 16, 2010 | Coleman Propane Forced Air Heater...
Amana furnace main burner intermitent
Sounds like dirty flame sensor. You can either clean it orreplace it.
Apr 21, 2009 | Honeywell Power Humidifier: Furnace...
Short cycling..continually..minimal heat
Is this furnace standing pilot or electronic? if standing pilot turn power off then take t-stat off wall and connect the wires labeled r and c together and see if that keeps furnace working. If electronic check flame sensor you can check flame sensor buy cleaning with steel wool. if that doesn't work then try t-sat.
Jan 21, 2009 | Coleman Propane Forced Air Heater...
Coleman presidential II furnace blower on and off
Sounds like the flame sensor. But it could be the thermostat. Is the furnace standing pilot or electronic spark or hot surface ignition. I would start by checking thermostat. Turn power off to furnace take thermostat off wall and take wires marked r & w and connect them together. Turn power back on if furnace works then change out thermostat.Most eclectronic ignition Furnaces have a flam sensor, You could take flame sensor out and clean it up with steel wool or wire brush. If you need anymore help just reply back .
Jan 17, 2009 | Coleman Propane Forced Air Heater...
Coleman Presidential II mobile home furnace. When burner lights the blower cycles on and off instead of blowing constant through burner cycle.
Is this furnace standing pilot or electronic ignition. If standing pilot i would check furnace filter then the thermastat. To test themostat first turn power off to furnace. Take thermostat off wall and take wires labled R & W and connect them together. If you have electronic ignition I would start with cleaning the flame sensor with steel wool or wire brush.If you have and more questions i will be glad to help.
Heater flashes 3 times says it means combustion switch failed to close
Combustion switch is your vent safety.. Check your vents outside for blockage, sometimes the intake pipe will freeze or frost up not allowing the preassure switch(vent safety)to close. putting furnace into a lock out.. you can reset the furnace by turning the power on and off.. if there is no power switch just remove the bottom door and reinstall...
Jan 08, 2009 | Coleman Propane Forced Air Heater...
Amana Air Command 80, 20 years old. Electronic ignition. Furnace does not start. Good power to furnace. Themostat properly set. Where do I start looking? Bob
Hello Bob,
Welcome to fixya,
You said, Amana Air Command 80, 20 years old.
Thermostat properly set.
Sounds like you possibly have one or more bad jets if the unit is a gas furnace!
Let me know how it goes.
Huuum
WOW, listen to this story!
I understand you are looking for the solution to fix your furnace your self.
But I want to tell you my story about my smart wife and our furnace.
When we moved into this house the furnace was 20 years old and she suggested that we put a new one that it will save us money.
I laughed at her and replied if it's not broken why fix it!
Six years later it finally broke down and I replaced the whole furnace and central air unit with a new one.
Our utility bill went down $100 dollars a month!
That's $7200. that I lost over 6 years due to not respecting my wife's power of reasoning!
If you can afford it or can get financing replace any unit 20 years old and it will pay for it self.
Can you imaging $1200. a year for 20 years is $24,000 dollars I'm saving with a new and efficient unit.
Do the math!!!!!!!!!
Thank You,
Huuum, Hope I gave you some good fatherly advice.
Please remember to leave a rating
Oct 12, 2008 | Amana Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
