Question about HP OfficeJet 6110 All-In-One InkJet Printer
Press Enter To Align Cartridges
HI,
I was removing the cartridges and i forgot to close the kocking mechanism wich seats on the top of the cartridges,at the point i close the printer cover and i heard a strippping noise and a message came on the display saying (Press Enter to Align cartridges).I try reset this message pressing ENTER,but is not working.please HELP.THANKS.
Regards
Rui Brandao
    Problem Solver:
  • 15 Answers
Open the cover, make sure your cartriges are properly seated. it will proabably still ask you to re-align the cartriges. all this does (usually) is print a page and then ask you some questions about thw eay that page printed.
also, try turing you printer off and back on. (resatarting your PC with you printer may also help somehow, but that's pure unfounded speculation based on the experience that restarting the device usually fixes it...).
Posted on Jan 04, 2009
2 Suggested Answers
  • 13 Answers
SOURCE: (Press Enter to Align cartridges)
disconnect printer from power and from CPU/laptop. Leave off for a good minute. have paper loaded and cartridge case closed properly. reconnect to power and then CPU/laptop. attempt to print. follow instructions it provides.
Posted on Jan 03, 2009
Cannot find where and how to replace ink cartridges
hi,
  • You have to lift the access panel on top of the printer to view the cartridges at the opening.
  • Press down the top of each cartridge housing to expose them.
  • Turn off the printer.
  • Remove them from the housing.
  • Take the new cartridges and remove the orange tape on top/bottom.
  • Fit the cartridges into their housing such that the words on their top are facing the front of the printer.
  • Close the housing.
  • Press down the access panel to close it.
  • Turn on the printer now.
  • Insert a few papers into the paper tray for the printer to align the cartridges.
  • After the prints,align the cartridges by selecting the clean and align option on properties on the printers program.
Sep 17, 2011 | Canon i 320 InkJet Printer
HI, I have an HP Printer and model is HP psc 750. Please guide me how can I remove the cartridge of this printer. Thank you. Fahid Amin.
  1. Open the cartridge access door. Figure 4: Open the cartridge access doorc00127636.gif
  2. Raise the cartridge latches for both cartridges. Figure 5: Raise cartridge latchesc00127637.gif
  3. Remove the protective tape from the end of the cartridges. Figure 6: Remove tapec00127639.gif
  4. Insert the cartridges into the carriage. Figure 7: Insert cartridgec00127642.gif
  5. Close the latches, and then close the cartridge access door. Figure 8: Close latchc00127644.gif The control panel displays a message prompting you to align the cartridges.
  6. Press the Enter button to start the cartridge alignment. Wait until the alignment completes before continuing.
Oct 28, 2010 | HP PSC 750 All-In-One InkJet Printer
Changed cartridges, printer doesn't align or function
Something seems to be physically wrong in the mechanism.
Try the rolling wheels and the belt on which the cartridges run.
Jul 19, 2010 | HP OfficeJet 6110 All-In-One InkJet...
What ink cartridges does a canon mp520 take? currently using 5 PGBK black, have been told I can use 8 black, but don't know how to install it
Your printer uses 4 cartridges: PGI-5 Black and CLI-8 (Cyan/Magenta/Yellow). Unless you have a slot for a fifth cartridge, CLI-8BK cannot be used in your printer.
As for installing new cartridges:
  1. Turn your printer on.Open the printer's lid. The printer will automatically move the ink cartridges to the center of the opening.
  2. Unplug the printer's power supply cord from the electrical outlet to avoid the risk of an electrical shock.
  3. Remove the printer cartridges by first pressing down on the top of each cartridge housing. Pressing down on the cartridge housings will cause the top of each housing to automatically lift up, thereby exposing the cartridges. Lift the cartridges out of each cartridge housing to remove them.
  4. Install the replacement ink cartridges by first removing the orange safety tape located on either the top or the bottom of each cartridge, depending on the particular type of cartridge. The safety tape ensures that the cartridges do not leak ink before being installed. To remove the tape, simply pull the orange tab on the end of each piece of tape away from each cartridge. Position each cartridge into its cartridge housing so that the printed words on top of the each cartridge faces towards the front of the printer, then close the tops of the cartridge housings.
  5. Plug the printer's power cord into an electrical outlet, then close the access panel by pressing down on the panel.
  6. Turn the printer on and allow the printer a few minutes to recognize the new cartridges, then insert at least three pieces of paper into the paper tray, which the printer will require to align the cartridges.
  7. Align the new cartridges by selecting either the "Clean and Align" or the "Cartridge Alignment" option, depending on the particular printer model. Some Canon models require the user to align the cartridges through the printer's software program. Select the "Print Properties" option in the printer's program, then select the "Clean and Align" option. The printer will produce several printed pages to confirm that the cartridges have been aligned. Other Canon models allow the user to align the cartridges directly from the printer. These printers features a display screen on the printer. Press the "Menu" button on the display, then use the arrow keys to select "Settings." Press the "OK" button, then use the arrow keys to highlight "Maintenance." Press the "OK" button, then use the arrow keys to highlight "Manual Head Align." Press the "OK" button, then use the arrow keys to highlight "Yes." Press the "OK" button one final time, then allow the printer to produce the printed pages confirming that the cartridges have been aligned.
Apr 07, 2010 | Canon PIXMA MP520 InkJet Printer
How do i change my ink cartridges on SX200 please
Open top cover, exposing control pad.
Press button (align??) to move expended cartridge into place for removal
Squeeze both clips to remove.
Peel tape from new cartridge, being careful to avoid touching contacts.
Insert new cartridge, gently push until fully seated.
Press button again.
Close top cover.
Aug 05, 2009 | Epson Office Equipment & Supplies
after putting a plain paper in the paper tray then try pressing ENTER or OK button on the printer this will print the alignment page.
Please rate the solution
Jan 03, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Keep getting message Press Enter to Align Cartridges
Try the following button sequence on the front panel of the printer :
Press and hold the Setup, button, and then press Options (or Copy Options).
Oct 25, 2008 | HP PSC 950 All-In-One InkJet Printer
Align cartridges
Hi ,
can u cet alignment print from u r printer if u get this printer .
please put this print on scanner & press scann button for scanning ........it will automaticaly align u r cartridges & printer will get ready for printing ......
if this information is useful for u please Rate me...........
if any update give me comments for it....
thanks & regards
Sandipk
Jun 18, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Printer
This issue occurs if the alignment page is not perfectly or with good colors. Replace the low ink cartridge. If the ink levels are good do the following steps to clean cartridges :
1. Turn the unit on and open the lid or top cover.
2. Remove the cartridges.
3. Using a clean, dry lint-free cloth (a coffee filter works well),
wipe the cartridge contacts, from the top to the bottom. The contact
area of the cartridge should be rubbed briskly to remove the waxy
lubricant material from the gold contacts.
4. The contacts inside the printer may also require cleaning. Using a
clean, dry, lint-free cloth, 5. gently wipe the contacts, from the
top to the bottom.
5. Re-insert the cartridges and close the printer's top cover.
Steps to manually align cartridges
1. Press Setup until Maintenance appears, and then press Enter.
2. Press until Align Cartridge appears, and then press Enter. Two pages are printed, one with instructions and one with patterns.
3. Follow the instructions on the instruction page, then place the page with patterns on the glass and press Enter. The cartridges are aligned correctly.
If the issue persists do the below to by pass alignment :
Press Setup and Options (or Copy Options) simultaneously when align message is prompted on the All-in-One.
Thanks
Dec 22, 2007 | HP PSC 2110 Color Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
