Question about Sony DVP-SR210P Progressive Scan DVD Player
Area limitations playback prohibited due to area limitations
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: need unlock code.
I found this region hack here Sony DVP-NS575P region code , check it out:
"Warning
The following guide describes how I managed to make my Sony DVP-NS705V DVD player multi-region.
There are no guarantees that you will be able to do the same. Be aware that you will probably void any warranty you have and possibly even break the player.
Put shortly, you proceed at your own risk.
Introduction
First of all, the Sony DVP-NS705V can be made multi-region simply by applying appropriate service codes, you do not need to install a so called "mod chip".
This supposedly applies to the entire NS-series of Sony DVD players. There are some encouraging reports out there supporting this, but nothing has been verified by me. Again, if you choose to apply this guide to any DVD player, you do so at your own risk.
If you do find that this procedure works on another model, please drop me a line at sonyhelp@selen.org and let me know. Include the exact model number and original region of your player.
Update: Some users have reported success on the following players:
DVP-F21 (special thanks to Garry Self for this one)
DVP-LS500
DVP-LS755
DVP-LS785
DVP-NC615
DVP-NS300
DVP-NS305
DVP-NS310
DVP-NS315
DVP-NS330
DVP-NS333
DVP-NS355
DVP-NS360
DVP-NS400
DVP-NS405
DVP-NS410
DVP-NS430
DVP-NS433
DVP-NS575
DVP-NS585
DVP-NS590
DVP-NS700
DVP-NS730
DVP-NS765
DVP-NS900
DVP-NS905
DVP-NS930
DVP-PQ1 (thanks go to Michael Joy for this one)
DVP-PQ2
RDR-GX3 (thanks to Andreas Norman)
RDR-GX7 (thanks to Daniel Tapie)
RDR-GX300
RDR-GX700
RDR-HX900
RDR-HX1000
Please note that not all players behave exactly like the NS705. For example, some players do not display "success" when hacked.
Thanks to all who have contributed.
The infrared service codes required to make the update are available on the Internet. Unfortunately, not many people have an appropriate device to enter the codes into. You basically need a programmable remote (Philips Pronto, One-For-All) or a PDA (Palm, iPAQ) with suitable software.
This guide shows you how to make the update with a regular PC equipped with an IRDA port.
The procedure
1. Download the winsamp -package from Blank Frank's site.
http://www.veg.nildram.co.uk/remote.htm
This innovative piece of software allows you to send standard home electronics IR signals using a PC IRDA port.
2. Extract the package onto a bootable DOS floppy disk.
3. Download this IR code
http://www.selen.org/files/REMOTE.TXT
file and place it in the same directory as the package above.
This file holds the five necessary IR codes converted to the format used by Blank Frank's winsamp.exe. Please do not bother Frank with questions concerning this particular procedure.
4. Boot up your PC from the floppy disk and run winsamp.exe.
If your IRDA port doesn't appear as COM2 you may override this by using an appropriate command line switch. For example, use COM1 by running 'winsamp C1'.
5. Press the 'r' key to load up the codes into winsamp.
6. Make sure your DVD player is in standby mode and your IRDA port is within range.
7. Run the IR codes from 1 to 5 by pressing Enter on each corresponding button.
8. Your DVD player should start up and display the text "SUCCESS".
9. Repeat step 7. Your player should return to standby mode.
10.Your player is now multi-region."
Posted on Feb 10, 2009
My DVD player is saying Playback prohibited by area limitations. What does that mean
You can try the region code hack. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Search the site by keyword "Region code"
Jul 14, 2015 | Sony DVP-SR200P DVD Player
Why ask me my DVD Playback prohibited by area limitations ??? Pls help me now I wane watch movie thanks
Most DVD players are region-locked, meaning they will only play disks encoded in the location they are from, or disks without region-specific encoding. For example, if I bought a DVD player in Europe and tried to play a disc from the United States, it would not play. Unfortunately, in order to get past the "area limitations" you will either have to buy a DVD encoded in the same format as your DVD player, or set the player to a different region code (which often will lock the player after a certain number of times).
Feb 27, 2013 | Televison & Video
Playback prohibited by area limitations - what does this mean?
you are trying to use a dvd from a different region then the player is set up for the player has to be unlocked to play multiple regional discs
Jul 17, 2011 | Sony DVP-SR200P DVD Player
My dvd player says playback prohibited by area limitations
Sounds like it's the wrong region disc. Try a disc that worked before and if it does than there is nothing wrong with your dvd player it is the disc you are trying to play that has the issue.
May 07, 2010 | Sony DVP-SR200P DVD Player
Pinnacle DVD's won't play in DVD players
The region code of your stand alone player is different from the region code on the disk. To resolve this Pinnacle should have an info tool that will allow you to check the region code. If not Nero has this tool available with thier software. You should be able to download it @www.download.com. Also most newer DVD players only read specific data types. For instance, you cant use DVD-RW in a player that only reads DVD-R. So make sure you are using disks that are compatible with your DVD player.
Mar 15, 2010 | Pinnacle Studio Ultimate 12 for PC
'PLAYBACK PROHIBITED DUE TO AREA LIMITATIONS'
Check area code at your unit and usualy its printed at back side. If your unit belongs to code 1, it will play only region code 1 dvds and so on other codes.
Jul 23, 2008 | Sony DAV-IS10 System
Sony DVP-SR210P Progressive Scan DVD Player Logo
268 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
