Question about Refrigerators
My digital frigidaire refrigerator isnt cooling properly so did some research think it might be start relay got a 3 in 1 but know how to put that on any suggestion...How do I put the 3 in 1 in place o
Thermostat light blinking, both sides arent cooling enough, its been cleaned but has develops mold somehow, I've adjust the thermostat but it will change back & continue blinking
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
You do not need the capacitor or the overload or the relay,The kit has all of them thangs built in to it. Basically that hard start has 5 wires. You put red to the right(run). Black at the top (common) and white to the left pin(start). All you need to do with the other 2 wires is hook 120 volts to them. Usually your ice box will have a red and a white wire coming down from the cold control. That is what you hook the 2 ***** wires 2. If you have a condenser motor to contend with then hook it up parallel in the circuit. What do I mean by parallel? Instead of running everything in one big continuous circle you piggyback the fan motor on top of the hard start power wires so that both items will get the same amount of power.
Posted on Nov 04, 2012
  • 1462 Answers
SOURCE: Refrigerator not cooling.
compressor has failed. not a diy job
Posted on Apr 25, 2007
Oceti
  • 51 Answers
SOURCE: Frigidaire model # FRS26ZNHB2 side by side not cooling
T
From your description, you have a bad evaporator fan motor. The part number for a replacement motor is #5304445861.This is not a direct replacement but is more reliable.Remove everything in the freezer, take off the back panels and you will see the fan.
If there is a large frost buildup on the coils and the fan is turning you have a defrost problem. If that is the case, please call me at 334-347-0000 and I will walk you through it.
Posted on Jan 14, 2008
  • 3 Answers
SOURCE: lights flashing all cooling appears normal ice maker flap continually opens and shuts no water buttons not operational
As I mentioned before my Maytag was doing the same thing, I called Maytag expecting a big fight but they were really nice about it.
This is a recall problem and even if your warrenty is up Maytag will repair it at NO COST to you.
They shiped me the HV board and sent a repairman who had it fixed in about 10 minutes with a newley designed HV board.
Posted on Mar 30, 2008
  • 184 Answers
SOURCE: GE side by side refrigerator defrost problem
CHECK THE DEFROST HEATER FOR CONTINUITY. IF IT IS O.K. CHECK THE ELECTRONIC CONTROL FOR A FAULTY SOLDER CONNECTION ON THE DEFROST RELAY. THE ELECTRONIC BOARD SHOULD BE LOCATED ON THE BACK WALL OF THE REFIGERATOR BEHIND AN ACCESS PANEL.
Posted on Apr 10, 2008
SOURCE: Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Posted on Sep 26, 2008
Frigidaire refrigerator not cooling at times
Click this link below for problemRefrigerator is not cooling properly? http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
---------This will help.Thanks.
Feb 09, 2012 | Frigidaire Refrigerators
Kenmore model 105.53534300 side by side refridgerator not cooling
Relays are located on the left side of the compressor. How long ago did you smell the burning smell? Are you 100% sure the compressor is running? If it is, nothing is wrong with the relays. Although sometimes it is hard to tell if the compressor is running. By morning temps will be higher than tonight if compressor isnt running. If it isnt running, relays must be changed. I will post shortly on how to change the relays.
Dec 23, 2007 | Kenmore 53542 / 53544 Side by Side...
My refrigerator quit cooling, not making any noises just not cooling how do I test the relay on the side of the compressr
Hello and Welcome to FixYa!
The relay works on the principle that when voltage is connected and the relay is cool and under working condition, current passes through the relay to start winding. After a short time, current passing through the relays heats the resistor installed in the relay and causes increase in the relay resistance which causes blockage to the current through the relay and it trips (turns off the current to the compressor unit).
There are different techniques for different models to test the relay. Here is a general technique to check the working.
Physically you can observe the burn marks or burning smell from the component. If there is excessive burn smell or heat from the unit, the unit is faulty. Solid state relay plugs directly on compressor start and run terminals. Relay terminals 2 & 3 are connected within the relay. Run capacitor is connected to relay terminal 3. L2 side of 120 or 220 VAC power is connected to relay terminal 2. Locate these terminals. Please make sure that you have disconnected the refrigerator power. Remove the relay cover (if any) and disconnect the leads/jack. Check the resistance across 2 & 3 terminals. It should be less than or around 100 ohms or so( You get a proper reading ).If it shows 0ohm its short and if it shows infinite ohms its open... We'll there could be multiple reasons for which the refrigerator had quit cooling. Relay is one of that. You need to workout all the possibilities in order for the trouble free working of the unit.
Hope this is all you need to know,
Best of Luck,
Please do Rate the solution, As a token of appreciation,
Concerned.
Aug 11, 2010 | Frigidaire FRS26R4A Side by Side...
Frigidaire FRS26R4AW5 buzzing sound not cooling
Something has stopped your compressor. The part could be the start relay, start capacitor, overload or the defrost control board. where are the buzzing sounds coming from ? Sea Breeze
Dec 20, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire Side By Side Not Cooling
That sounds like the start relay is buzzing. Unplug and lets check the compressor to see how hot and if too hot to hold your hand on the top of compressor we need to leave it unplugged until we find out if the start relay, start capacitor, overload or if the condenser fan stops after running a short while. Sea Breeze
Sep 13, 2009 | Frigidaire FRS3R5EMB Side by Side...
Refrigerator does not cool down to proper temps. fans are running. had problems for a few days where it would stop cooling for a while then star operating prperly again. i am thinking defroster timer?
2002 hyundai santa fe will start and idle but has no power when driving wont tack over 3 grand acts like it isnt getting fuel transmission wont shift properly only if you shift manually
Sep 08, 2009 | GE Refrigerators
Frigidaire Refrigerator not cooling
Is the fan on the bottom on? Do you hear the compressor kick off and on within a minute? No/ Is the evaporator fan running? Do you have frost on the evaporator? Frost is a sign that the defrost isnt working. If evap fan doesnt run it wont cool the refrigerator. If everything is running and no frost buildup in freezer then you have a sealed system problem and need of a tech.
Jul 25, 2009 | Kenmore 50522 / 50524 Side by Side...
Frigidaire Model # FRS23R4A - Not cooling
wihtout replacing the relay there really isnt any way to tell if its the compressor or the relay. the relay is veyr inexpensive in comparison to the compressor usually less than 70 bucks. and the best part is you can replace it yourself as opposed to paying a service company. this is the part number 218721113 and it prices at 38 dollars thru  sears.com.
once you replace the part if the compressor starts you should be ok. if it doesnt start then you will need to call a service company to replae the compressor or look at replaing the refrig. if the unit is less than 5 years old it may be under warranty for the compressor so check into that first. if I can be of further assistance dont hesitate to ask. thanks Peyton
Mar 08, 2009 | Frigidaire FRS23R4A Side by Side...
I have a Frigidaire model FRT21LRG
CHECK TO SEE IF THE CONDENSOR FAN IS WORKING IT COOLS THE COMPRESSOR IF IT IS THEN UNPLUG IT AND LAT COOL DOWN FOR A DAY THEN TRY TO SEE IF IT WORKS BETTER IT MAY NEED A RELAY OVERLOAD TOO BUY A 3 N 1 START KIT IT TELLS YOU HOW TO WIRE IT ON THE PACKAGE
Aug 26, 2007 | Frigidaire FRS23KF7AB Side by Side...
Apr 25, 2007 | Amana ASD2622HR Side by Side Refrigerator
Refrigerators Logo
85 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
