Question about Nokia 5230 Nuron Protective shield Bulk
Backup files Phone start-up failed
All
  • 580 Answers
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Posted on Nov 04, 2012
Tried to run a full system backup with FreeAgent Go. Backup failed and it looks like some files and programs were deleted from my computer in the process.
Unless you asked the backup program to delete files it won't. The program may have deleted some files it created for its own use.
What error code did it give for failing the back up. How do you know you need the deleted files?
Mar 17, 2014 | Computers & Internet
Hello i have a problem with my nokia 3110c whitch is : when i flash my phone with phoenix i got this result : Flashing started Creating product data items list Product data items list created Backup...
Now what is the condition of the phone ? If the phone has still problem, uninstall the previous file you have installed and re-install this one3110c file.Select the product code 0544311 or 0556977.This two files can use universal.Use fully charge battery or insert charger when message prompt.I hope there will be no error.Thanks good luck.
Aug 16, 2011 | Nokia N70 Cellular Phone
Browser is not upgrading.
If you want to update your browser, then you have to update the phone. To do this, download the Nokia pc suite and backup all of the files on your phone
To do that simply start the Nokia PC Suite application and click on the Backup button. Make sure you save everything on that phone. This might take a while if you have lots of personal files like images or music stored on the phone. The files will be transfered with the Nokia Content Copier software.
Backup the contents in the Nokia phone as well. You find that option in Tools > Memory.
Download and install the Nokia software updater application which will be used to update the firmware of the Nokia phone. Please note that you have to use this software and can't use the Nokia PC Suite to update the mobile phone.
Make sure you connect the charger to your phone before you start the process because a failed update can brick your Nokia phone.
Alternatively, you can use Opera Mini web browser instead of the phone's built-in browser.
To get Opera Mini, to to http://m.opera.com/ on your phone, and it will pick the right version for you. (Operator internet access charges will apply to the download. The download will be about 128kB.)
Regards
Jun 25, 2011 | Nokia 5130 Cellular Phone
My nokia N72 shows phone memory full and cannot open certain apps and messages.I tried your method to backup the files but the PC Suite shows that no files need backup and backup fails.Plz help me on this?...
You can try to delete unnecessary files directly in your phone manually to clear some space. Just delete images or videos on your phone memory that is not important anymore for you..
Hope it helps..
Don't forget to rate!..Thanks...
Mar 30, 2010 | Nokia N72 Cellular Phone
Operation failed when receiving a file via bluetooth
don't worry. just make a backup of your personal data such as songs, images, games that are in the memory card. save that backup in your pc or if a have required space in your cell so save that backup there. now formate your memory card. after that replace all your data and then try receiving again. it will work, for sure.
Aug 09, 2009 | Nokia 6300 Cellular Phone
N 72 Installation problem
The phone needs to be formatted .... take backup and then press *#7370# ...default code 12345 ...the phone will restart ...after which try again after that you will download from www.mobile9.com because the nokia N72 will suport only sis files please down load from this web site
Oct 13, 2008 | Nokia N72 Cellular Phone
N91-phone start-up failed
try this..
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card.
3. Switch-off your 6600 phone.
4. Press and hold 3 keys;
Green dial key, * (star key) & no. 3 key and then press the power on/off to swtich on the 6600 phone.
Remember, do not let go all of the keys and hold keys until you see a formatting word screen show!
5. After a few minutes when the Full phone formatting completed, your 6600 will back to original system and factory settting.
All apps installed & not of the phones' default will be lost. If you did a backup on your mmc, you can restore it back to the C drive again.
Jan 08, 2008 | Nokia N91 Cellular Phone
Error code 0x80040702
you should go into your computer to my computer. then file programs.look for palm then open. look for your user name open then look for backup file rename the back up file then hot sync the phone then use the same user name it will start up a new back up folder. you might have something on your phone that the phone do not agree with. this should work if you hot sync your phone to your computer.
Dec 23, 2007 | Palm Treo 650 Handheld
650 stopped syncing after I set up the email function
Reinstall software. If this is helpful, please post as such. TY
Sep 12, 2005 | Palm Treo 650 Handheld
Nokia 5230 Nuron Protective shield Bulk Logo
44 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
