Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Motor Runs but air comes out
The motor runs but the air comos out the oil filler cap 2 holes at the top
left it running for a weekend by mistake and this is how it ended up any ideas
Thanks Dan
  • dacamovic Feb 06, 2009
    I have the same problem. I turn on the compressor, no pressure is reading on the gauges and air comes out of the two holes of the oil cap filter.
    How do I go about replaing the piston rings and/or the reed valves in the "head"
    Scholar:
  • 65 Answers
Sounds like you may need to replace the piston rings and/or the reed or similar valves in the "head". I think if the valves were bad you would be getting oil in your air, a lot of oil, but you might want to consider replacing them anyway while you have it apart. I don't think that leaving it running would have hurt it as long as it is cycling on and off.
If it wasn't then the information that follows would be why and/or the problem has been developing for a while.
It may not be now due to the problem that is occuring with the oil isn't allowing it to build pressure.
But all in all it sounds like blow by is getting past the rings into the crankcase and the pressure is forcing the oil out. This is on a piston type. A worm type may have different things causing it.
Posted on Jan 05, 2009
92 ford tempo has oil coming out at the cap
I believe you do mean the oil filler cap. If is that under the cap there is a rubber seal,probably became hard and does not seal well. Renew it,either the seal if you find it or the cap itself.
Aug 27, 2012 | Cars & Trucks
How do i check fluid for convertable top
"How do I get the air out of my hydraulic system"?
  • Remove the reservoir plug on the motor pump. Leave the plug out and do not put back until you have finished.
  • Fill the reservoir 3/4 full with fluid (to the bottom of filler plug hole). Put a rag under the hole to catch overflow that will occur as system fills.
  • Run the pump for 15-20 seconds. Stop. Check your fluid level and refill to bottom of filler hole. Continue running the motor in the same direction for an additional 15-20 seconds. When the top gets to the end of cycle, check your fluid level, fill to bottom of filler hole, and run the motor in the opposite direction.
  • You are literally running the top all the way up and down sereral times. Checking the fluid level as you go and fill as required, leaving reservoir 25% empty.
  • When you are no longer able to add fluid, put the top in the down position. Check the fluid level one last time, should be to bottom of filler hole. Put the plug into reservoir.
  • Apr 01, 2012 | 2004 Ford Mustang
    FILLING OF TRANSMISION OIL
    How to check & change oil in automatic transmission
    At the bottom of the automatic gearbox (tiptronic) you will find 2 threaded plugs on below surface. First (in front of the car) is for emptying, and second is for filling up. Tightening torque is 24 Nm.
    Automatic Transmission Fluid (ATF) checking:
    1. Requirements for check:
    1.1. Vehicle standing on level surface.
    1.2. Transmission must not be in fail-safe mode.
    1.3. Shift lever in "P" position, parking brake applied.
    1.4. Engine idling.
    1.5. Air Conditioner and heater OFF.
    1.6. ATF temperature must not exceed 104 Fahrenheit degree (40 Celsius degree) at start of test.
    1.7. Only ATF with designation ESSO LT 71 141 may be used. Do not use any lubricant additives.
    1.8. Automatic Transmission Fluid ATF - part number: G 052 162 A2 (1 liter wrapping)
    1.9. An ATF level check when transmission oil temperature is too low results in overfilling, when too high results in underfilling.
    2. CAUTION: Too much or too little ATF will affect the operation of the transmission. The ATF level must be checked at regular intervals.
    3. The oil level is correct if a slight amount of oil runs out when ATF temperature is between 86 Fahrenheit degree (30 Celsius degree) and 113 F deg (45 C deg) (caused by increase of oil level when heated). For warmer climates, 122 F deg (50 C deg).
    4. Hang filled ATF reservoir VAG 1924 as high as possible.
    5. Shift lever in "P" position, engine running at idle.
    6. Place oil drip pan under transmission oil pan.
    7. Remove ATF filler plug (at the bottom of the automatic gearbox you will find 2 threaded plugs on below surface. First (in front of the car) is for emptying, and second is for filling up.
    8. With ATF temperature between 86 Fahrenheit degree (30 Celsius degree) and 113 F deg (45 C deg), for warmer climates, 122 F deg (50 C deg), a slight amount of oil will flow from filler hole when ATF level is correct.
    9. If necessary drain or top off ATF to attain correct oil level. Top ATF with filler hook from VAG 1924 ATF reservoir. Insert VAG 1924 (tool) ATF reservoir filler hook into filler hole and top off until a slight amount of oil flows from filler hole.
    NOTE: Fit filler hook into one of the oil deflector cap slots placed on the filler opening.
    CAUTION: Do not press filler hook upward or oil deflector cap can be pushed off.
    10. Reinstall ATF filler plug. Tightening torque is 24 Nm.
    Jun 01, 2011 | 2006 Audi A4
    Checking transmission oil 2003 audi a6 tdi auto
    1.4. Engine idling.
    Oct 16, 2010 | 2000 Audi A6
    How to locate the transmission fluid filler screw ?
    1.4. Engine idling.
    Aug 17, 2010 | 1999 Audi A4
    Gear oil top up audi a4 2.4 auto
    1.4. Engine idling.
    Please rate my response. Thanks!
    Apr 16, 2010 | 1998 Audi A4
    Craftman 3gal/1hp air compressor runs normal, but
    Chek for pressure BEFORE REGULATOR,if the problem remains worn rings or valve seats most likely source of trouble.
    Aug 09, 2009 | Air Tools & Compressors
    Air compressor/ alot of air is coming out of the oil cap vent.
    this could be blow back possibly bad piston rings you may need new rings oil chamber is usually at intake pressure unit may need rebuild
    Jan 13, 2009 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
    Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
    135 people viewed this question
    Top Craftsman Air Tools & Compressors Experts
    John Trevino
    JOHN LAPIER
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
