Bricked my samsung tv by using service menu - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
This is why I refuse to provide information on how to get there---only suggestion is contact Samsung to see if they are willing to help at all--suspect they will not and tell you take it to a service center.
Posted on Nov 04, 2012
I have a Samsung TV (un75f6300afxza) and Reboots on its own. Sometimes it does it multiple times. The TV is not under warranty anymore and I would like to figure out what parts I need to replace.
Hello, do a software upgrade ( that's done through your tv's menu) and see if that takes care of your issue. If not, there's a cover over the WiFi receiver , unplug the tv and remove the small cover and unplug the WiFi and see if it still shuts off. Let me know.....tks
Jan 30, 2015 | Samsung Televison & Video
May someone please send the service mode specifications for a Samsung LED 40 inch TV UA40EH5000R?
I don't have service mode specifications but I do have a Samsung and looked around for how to get it in service mode some time ago because the HDMI cables somehow disconnected themselves a lot. Thought it was an electronic problem but it turned out to be a parenting problem instead SO I have never used this information and can not vouch for it. I cut and paste it from a note I copied from a forum entry to use at your discretion:
First post:
To enter "Service Mode" Press the remote - control keys in this sequence :
From Standby Info-Menu-Mute-Power On
- The buttons are active in the service mode.
Remote - Control Key : Power, Arrow Up, Arrow Down, Arrow Left, Arrow Right, Menu, Enter, Number Key(0~9)
Careful though there are things you shouldn't touch in this menu.
avforums.com/forums/lcd-led-lc­d-tvs/601553-samsung-service-m­enu-research.html
Another post:
Method 1
Put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu.
Method 2
Turn the power off. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
Method 3
With the TV in standby, press the {DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Method 4
With the TV in standby, press the {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
Method 5
With the TV in standby, press the {DISPLAY} {MENU} {MUTE} {POWER} on the remote.
Method 6
With the TV in standby. On the remote, press Mute followed by 1, 1, 9, Enter in sequence.
Samsung LCD Monitor Service Menu Instructions
End quote.
Good luck. Just a basic suggestion you probably don't need: keep track of any changes made by writing them down so you can put it all back if you have to.
Dec 20, 2014 | Samsung Televison & Video
Tv is locked
1. Turn the power off.
2. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
3. You should now see the service menu. To exit the Service Menu always select RESET.
If you do not currently have your Samsung TV's remote control, then you will probably have to contract Samsung Electronics division in your country. You can try using their email support form located here.
Feb 04, 2013 | Samsung LN32A330 32 in. LCD TV
Samsung tv (EURO MULTI) sarvice code
Hello
These are the service modes for Samsung. Check it with.
[1]
Turn on the TV on and select the input that you want to adjust.
# Turn the display off
In quick sequence on the remote press:
{MUTE} {1} {8} {2} {POWER} buttons.
# The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
# Select the function and use the {VOL+} button to enter.
# Save settings and exit by pushing {MUTE} twice then {POWER}.
[2]
With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
Press the {POWER} button to exit the Service Menu.
[3]
Use the {CH+} {CH -} buttons to select items.
Use the {VOL+} {VOL -} buttons to adjust.
Jun 25, 2011 | Televison & Video
Need to access service menu
GO to All TV Service Menu Code to browse olmost tv factory mode.
You can find lot of service code for tvs, DVDs, Monitor and many more.
Mar 27, 2011 | Toshiba 26AV52R LCD TV
How do i unlock the panel lock on samsung portable combi tv vhs model no:TE-14N5
Hello
Unlocking your Samsung TV requires access to the Samsung TV service menu, which will allow you to reset or remove any previous lock in the settings. In order to unlock your Samsung TV you will need your remote control. All you have to do is simply follow the instructions provided below and you can use the service menu to guide you from there. Also note that upon entering the Service Menu, all User Menu settings will revert to factory default
Steps To Unlock A Samsung TV 1. Turn the power off.
You must have its orginal remote control with you to perform these functions. If you haven't it with you, contact Samsung Electronics at your country.
OK.
Jan 07, 2011 | Samsung CXJ1352 13 in. TV/VCR Combo
Factory reset Menu
IF A SAMSUNG TV Put tv into STANDBY
WARNING DO NOT CHANGE ANY OTHER SETTINGS TV WILL NOT WORK
Press INFO / MENU / MUTE / STANDBY on remote tv will come on with service menu displayed and FACTORY RESET (12) is on it
ONLY USE DOWN NAVAGATION KEY until you highlight factory reset
NOW PRESS RIGHT NAVIGATION this will reset all settings
PRESS POWER ON THE TV TO EXIT then turn on tv and retune
Nov 07, 2009 | Samsung LE32R72BX 32 in. HD-Ready LCD TV
Samsung LCD Tv
Try this:
Access menu service by press on your command, with your TV OFF:
INFO + MENU + MUTE + POWER ON
Then you should get access to Service Menu.
The last item says: RESET
This will do a reset to the TV.
Make no harm.
WARNING: If when on service menu you feel tempted to "screw" on anything FIRST take note on ALL you change! You can compromise the TV ...
Apr 13, 2008 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
Electro Med Services...
