Question about Sewing Machines
The thread breaks going thru the dial tension assembly
I thread the machine and it sews just fine, yet the thread breask everytime I try to pull the sewiung item out from the sewing area
  • Sewing Machines Master
  • 1,564 Answers
Kathy. Get in the habit of stopping the machine with the take up lever in the UP position. Then lift the presser foot, and pull your item away. If you still have issues..... try "flossing" with unwaxed floss the tension discs. And check to
make sure you are in between the discs rather than to one side of them or the other.
Good luck
Posted on Nov 04, 2012
  • 106 Answers
SOURCE: Tension disc assembly - sewing machine
Sorry but there is no way to explain how to re-assemble the tension mech on here, you need to be actually shown or have someone do it for you. It is very fiddly and needs to be exact, can I suggest you get in touch with a sewing machine tech who(at cost) will sort you out.
Sorry I cannot be of any further help.
Rob
Posted on Mar 29, 2008
  • 8 Answers
SOURCE: Bobbin thread breaks
Make sure your bobbin thread is turning clockwise as it sits in the bobbin case. There is a screw on the outside of the bobbin case you can turn with your thumb slightly to adjust tension. If you dangle the case from the thread and give it a light ****, it should move down slightly when doing so-an indicator of good bobbin tension.
Posted on May 20, 2008
SOURCE: Thread breaking
Well, I have owned the Janome 1600DP with the Gracie Frame for 3 years now and have only successfully quilting 3 quilts. Its very intimidating how easily the thread breaks!!!! Add hot flashes with the frustration and I've almost given up. Today, I think I have found something. I cleaned the bobbin case, cleaned between the discs, put in a new needle (using the one recommended) but I put the spool of thread in a coffee cup located at the non-sewing end of the machine, sitting it on the Gracie Frame. Then the thread is through the metal eye ring that came with the frame. All the rest of the threading is per the Janome instructions. So far, so good. There you have it but if I had to purchase a sewing machine again for quilting quilts, it would NOT be a Janome!!!
Posted on Oct 04, 2008
Storma
SOURCE: Upper Thread Breaks!!!
Hi, here are some reasons why the thread is breaking :-)
  • Threading is not correct.
  • Thread has a knot in it.
  • Thread tension is too tight.
  • Needle is bent or blunt or has a sharp eye.
  • Needle is wrong size.
  • Needle has been inserted wrong.
  • Needle and thread does not match.
  • Starting to stitch too fast.
  • Thread take-up lever has not been threaded.
  • Hope this helps.
    Posted on Jan 14, 2009
    SOURCE: Thread in needle or bobbin keeps on breaking
    The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
    Posted on Apr 07, 2009
    Lower thread breaking on lower looper ( green code) It won't sew over seams breaks everytime I rethread it
    has the cone of thread at the back got caught up? this sounds like your thread is being caught and not feeding freely through the tension guides. Check the thread cones are okay and that the thread is pulling freely off the most right hand cone (lower looper). Also this thread dial should be set to the same tension setting as the next dial to the left for the top looper. Other possibility is that the tension disc itself has become gummed up or dirty with thread lint or dirt. Turn thread dial to zero and clean between the discs be rubbing the selvage edge of a piece of fabric between the discs gently. Now return tension to 5 or normal setting and try again.
    Mar 28, 2011 | Janome MyLock 204D Mechanical Sewing...
    The thread on my Juki machine keeps breaking when I sew. How do i fix it. Also, How can i change the thread tension
    there's a tension dial with numbers-0-9 --above the needle area- the smaller the number the looser the tension--the higher the number the tighter the tension
    thread breaking-try this
    try rethreading the machine
    thread tension to tight
    needle is bent or blunt
    needle is inserted incorrectly
    the thread is either too heavy or too fine for the needle
    try this & see if it helps you
    Cut 6-8 inch piece of thread of the spool you are going to use for your project
    Take the needle you are going to use for the project
    & insert the thread thru the eye of the needle
    & lift one end of the thread to a 45 degree angle
    & if the needle is the right size for the thread it will slide down the thread
    But if the needle hangs on the thread you need one size larger needle for the thread
    Oct 26, 2010 | Juki DDL-8300
    Hi, I would sew , up to 3 inches of sewing on the cloth the needle would stop and when I look underneath the fabric where I just sewed. The tread is all bunched up and tangled. The top threads looks fine...
    re-thread the entire machine. Pay special attention to the take-up lever and the tension assembly.
    Always have the presser foot in the UP position when threading the machine. This opens the tension disc to allow the thread to nestle inside the assembly.
    Make sure the thread passes through the take up lever
    Make sure you inserted the thread in every thread guide
    I always recommend a sharp needle. You may not notice any slight bends, burrs or dullness in the needle which would throw off the timing and the stitch quality.
    SPOOL CAP - If you have a horizontal spool pin a spool cap is very important. Its also very important the spool cap covers the end of the spool of thread but make sure its not too big or it will throw off the thread tension.
    TOP TENSION DIAL - The setting should be between 3 and 5 on most machines.
    The best way to know if you threaded the tension assembly correctly is to put the presser foot in the DOWN position. Now take the thread from the right of the tension assembly and pull. Is there tension on the thread or does it pull out very easily? If it pulls out easily you threaded it incorrectly. Try it again
    also check under the needle plate for lint
    and in the bobbin case area for lint or loose threads
    Oct 19, 2010 | Brother LS-1217 Mechanical Sewing Machine
    Where is the tension release unit
    Try this, with the presser foot in the raised position, pull thread thru the needle, it should pull thru easily. Now lower the presser foot and pull thread thru the needle, it should be harder to pull thru. If this is the case then the release unit is working. (make sure the upper thread tension dial is set at about 4)
    Apr 22, 2010 | Brother PE-150V Computerized Sewing...
    Janome 6600 tension
    You need to do a tension assembly test.
    Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Tension assembly test. To do this test. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
    (To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)
    If it doesn’t work this way then you probably have a piece of thread or lint stuck inside the tension discs. To remove it, turn the tension to 0 zero and raise the presser foot.Using a small screwdriver, open the space between the discs and spray with canned or compressed air. The stuff should come out. Do the tension test again to make sure you got everything and then try sewing again.
    sewman7
    Feb 16, 2009 | Sewing Machines
    WHITE 2037 TENSION ISSUE...
    Okie Dokie..... Here's the way I see it.. The repair center was of little or no help to you . So, I will try to do my best..
    First thing you need to do is unthread your machine and set the tension to 4.. Rethread the machine up to just before the needle.
    When you get that far, put the presser foot down. If your thread pulls right thru easily, it is not threaded thru the tension wheel right. It your thread is hard to pull thru with the presser foot down, then it is threaded right.
    General rule of thumb..
    Loops on the bottom-- problem on the top
    loops on the top--- problem on the bottom.
    Hope this helps..
    Mimi
    Dec 15, 2008 | White Sewing 2037 Mechanical Sewing...
    Having trouble with my bobbin thread
    Check your tension disks, with your presser foot up, and the tension dial on zero. Sometimes a piece of cotton breaks off between the tension disks and then prevents the disks to work properly. Also make sure when you thread the machine, the thread does go through the disks and over the take up lever. After you threaded the machine, before putting the thread through the eye of the needle, lower the presser foot and while pulling on the thread with your left hand, increase the tension with your right hand. Do it slowly and you should feel in difference in tension. If this is the case, your machine should work fine. Good Luck!
    Aug 28, 2008 | Brother LS-1520 Mechanical Sewing Machine
    JANOME RX18S
    If it was sewing correctly BEFORE the needle break...why did the needle break in the first place?...and what fixes did you make?
    If it sewed properly...what changed?
    Cut your upper thread close to the spool...make sure the presser foot is raised and pull the cut off thread section through/out of the machine from the needle area (sewing direction...do not pull the thread backwards!)
    Clean out the bobbin area...remove any traces of lint or pieces of thread...look for any broken off needle pieces... brush the bobbin area out....then add a drop of sewing machine oil (but only if your manual says to oil that area).
    Remove the needle plate to expose the feed dogs...brush/clean out that area too and add a drop of sewing machine oil...then secure the needle plate back on.
    Replace the needle...do it again...yup...some needles arrive bad from the factory. Make sure the needle is inserted and positioned properly. Then thread the machine WITH the presser foot in raised position. (The thread needs to get seated into the upper tensions.)
    ..with the.presser foot down...thread the new needle.
    Oh...and use the correct needle for the thread. (a universal 80/12 is standard).
    Thread can cause issues too. Try a different bobbin, or maybe a different spool of thread to see if that makes a difference.
    Mar 25, 2017 | Janome Memory Craft 9500 Computerized...
    Keeps cutting the thread from inside the machine
    Make sure all of your threads are in between the tension dials. Sounds that the machine isn't catching because of the tension. Good Luck
    Apr 06, 2008 | White Sewing Speedylock 1600 Mechanical...
    Sewing Machines Logo
    Top Sewing Machines Experts
    Tally Girl
    Tally Girl
    Chris Wetmore
    Are you a Sewing Machine Expert? Answer questions, earn points and help others
