Question about GE 13TVR70 13 in. Combo
Audio video on what channel do u get the input on the v model # 31gt658
    Scholar:
  • 90 Answers
Frequently you habe to press a TV/Video button on the remote, or channel down past channel 1.
Comment on the solution if this doesn't help and we can troubleshoot more.
Posted on Jan 04, 2009
Can't get a dvd to play. all input sources say no signal. where is the yellow video input? which input source should i use?
You can use AV1 or AV2 depends on the make and model of the TV you have. You should hvae THREE RCA plugs from the DVD (Yellow for the Video, Red for right channel audio, White for Left channel audio) You just have to match the colors at the TV and the DVD player.
What is the make and model of the TV?
Aug 26, 2011 | Televison & Video
I have a proscan tv model #PS27108, I do not know how to hook up the dvd player in regards to the cords and what channel to put it on? I would appreciate any help with this! Thanks in advance?
The ProScan will accept input on input 90/91/92 using the connectors on the backside. You can use S-video[the little round black connector] or the composite video [yellow connector] for the video in and use the red / white pair for audio in.
90 selects S-video and audio 1 in
91 selects composite and audio 1 in
92 selects composite in 2 and audio 2 in
Connect these cords to the S-video or composite yellow output, and the Red-right White- left audio outputs on the DVD.
If you don't want to do this, get a RF modulator ~$15, and connect the yellow/red/white from the DVD output to the inputs on the modulator, and then connect the RF [cable] output of the modulator to the antenna input on the ProScan, and tune channel 3 or 4.
tom
Oct 22, 2009 | Proscan PS27108 TV
Can not see the Video when I input it, see only a blue screen.
ok hook up the audio video in the OUTPUT on vcr and INPUT on the tv then make sure tv is changed to the right input channel now go to vcr and change that channel to AV,.if AV isnt there you may have to go into menu of vcr and do a channel search,but when you change it to AV on vcr you should see the picture
May 27, 2009 | Televison & Video
No sound when using xbox
Assuming you are using the Red, Green & Blue Component inputs from the X-Box, there will be either a set of Red & White phono (RCA) inputs for EXT3 audio, or a standard 3.5mm jack socket. If so, use these. You will need an adaptor if it is a jack socket.
Dependant on model, the setup menu should have options to assign the audio input to the correct video source.
The side inputs are separate, and are only for the composite or S-video inputs.
NOTE: if you are using the component inputs, you don't connect the yellow composite input.
If this doesn't help, post the exact model number and I will be able to advise you further.
Apr 19, 2009 | Televison & Video
No auxillery channel
your unit is equipt with audio video input jacks. It is located in front of the tv, right lower side. this is a video in and audio input for your dvd player.
Apr 11, 2009 | Sanyo DS19310 19" TV
Switching Input on GE Stereo Monitor
I tried for a while to get my dvd to work. I went to the menu, from my universal remote that totally works. Went to the menu, then channel set up, and switched the VCR1 channel to 00Enabled. When I want to watch a dvd I press 00 for my chanel and it works. I hope this helps all of you.
Dec 13, 2008 | Televison & Video
What tv channel do I use with Durabrand DVD Player model: DVD-1002 lvjack@juno.com
Some DVD players that has a built-in RF Modulator would normally use either Channel 3 or 4.
Most do not and uses Audio/Video OUT and therefore must not be on any channel but on VIDEO. Chances are you have to hooked up the DVD using Audio/Video with the RCA cables (yellow, red & white). The TV must be set to Video IN not TV Tuner/Channel. Additionally some TVs can only accept a mono audio input while your DVD's audio output is stereo. A quick and dirty way out is to use an adapter shown below to convert the stereo to mono. Additionally, some other TV's Audio/Video inputs are on the front panel.
Alternately, if the front panel Audio/Video connector is already being used by another device, an RF modulator may be used and this time your TV has to be switched to a channel prescribed by the RF modulator. A fine example is one from RadioShack.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 26, 2008 | Televison & Video
What channell do you tune to for dvd output for durabrand model Dwt 1905
I believe its not on a channel but on VIDEO. Chances are you have the DVD hooked up as Audio/Video using the RCA cables (yellow, red & white). The TV must be set to Video IN not TV Tuner/Channel. Additionally, your TV can only accept a mono audio input while your DVD's audio output is stereo. A quick and dirty way out is to use an adapter shown below to convert the stereo to mono. Additionally, to my knowledge your TV's Audio/Video inputs are on the front panel.
In some instances, there are DVD players that has a built-in RF Modulator and normally uses either Channel 3 or 4.
Apr 18, 2008 | Televison & Video
Daewood input w/out remote
Change channels manually on front and go below channel #1 and then it should say "video" 1 or "Aux". Hope that helped you. Have a great day. Jay
Jan 30, 2008 | Daewoo DVQ13H1FC 13 in. Combo
DVP334V cant connect to my LCD TV
  1. Connect the video cable to the players VIDEO (CVBS) OUT (yellow) jack and to the TV's VIDEO IN jack.
  2. Connect the audio cable to the players 'AUDIO LEFT' (white) and 'RIGHT' (red) output and the TV's 'AUDIO LEFT/RIGHT' input jacks.
  3. After it is hooked up, you will need to select the TV’s video input channel that corresponds to the jacks connecting the player to the TV.
    • Press STANDBY-ON to turn on the player.
    • Turn ON the TV.
      Note: Video Input selection varies for different brands/models of TVs. Consult the user manual or manufacturer or your TV if none of the below is successful.
      • Press channel 2 on your TV. Then press the channel down button to locate the video input channel. (This channel is usually located between the lowest and highest TV channels.)
        OR
      • For some TVs, there may be a button on the TV’s remote control that accesses the video input channel labeled SOURCE, AV or SELECT.
        OR
      • Select the Video Input Channel from the TV’s on-screen menu system.
Composite Video Connection. (Example Only)
051104165152_4352.jpg Attachments
    No attachment available.
Dec 25, 2007 | Philips DVP3340V
Televison & Video Logo
117 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
