Question about Nokia Play 360° bluetooth speaker
Speaker has rattling sound
Brand new unit
  • Nokia Master
  • 805 Answers
Configure it from your computer sound system
Posted on Nov 05, 2012
SW-910, blown speaker or ? makes rattle/buzz sound. replace speaker and/or change to passive type sw?
i would suggest replacing it rather than fixing. The cost of the repair will be about the same.
if you went to a passive sub/seperate power amp setup you could get a much higher quality unit, but it would cost you considerably more cash.
Feb 01, 2015 | Sony Audio Players & Recorders
Rattling in left earcup
Sounds like you have blown out the cone on the speaker. Have you removed the covering to see if the speaker in that earphone is intact?
Feb 10, 2014 | Bose QuietComfort 15 Headphones
Hi, I just got a new williams allegro digital piano, and the right speaker sounds noise with low keys.
If this is a brand new unit, exercise your warranty!
BUT FIRST see if packing material worked through the speaker grill... you know littel pieces of the packing peanuts or otherr contamination that sits in the speaker cone and rattles.
Feb 12, 2011 | Williams Allegro 88-Key Digital Piano
I have a velodyne h6510bg subwoofer, the fuse blew and we replaced it but there is a rattle in the metal cage unit and when you plug in and activate the speaker there is only a humming sound ??
It sounds like the driver itself may have violently blown (the rattle). Is the hum from the speaker (amplfied) without input? Probably something in the amp is gone, too. A hands-on tech would be able to diagnose it for you.
Jan 10, 2011 | Audio Players & Recorders
I've got a Behringer Ultrabass Bb410 1200w 4x10 Bass Cabinet in which 2 of the speakers rattle. I know the speakers have been removed and rewired. How can I get an internal wiring diagram to check...
The cabinet is listed as a 4 ohm unit.
We would exoect to see four, 4 ohm speakers in series parallel or four 16 ohm speakers in parallel.
If teh unit seems to rattle, first put an audio oscillator into it and sweep the frequency. It is common for grilles and also logos attached to them to rattle.
Open the unit and power each speaker the same way individually for a test.
I suspect you will find either the grille or mounting hardware is actually doing the rattling OR possibly the wires inside are vibrating.
If the sound is a scratchy buzz, then the speaker(s) have probably had voicecoils damaged by overheating.
In this case, buy 4 new speakers and replace all. It is not likely to find replacements for the Buggera brand they put in these cabinets. Also the word on the web about that brand of speaker is not very good.
Sep 21, 2010 | Behringer Ultrabass Bb410 1200w 4x10 Bass...
(orignal game boy) no sound from speaker but rattling
i guess your speakers are not recognizing the ''treble'' sounds !
this case, the only solution is buying a new speaker =/
Jul 30, 2009 | Nintendo Game Boy Advance SP Console
Rattle in rear window speaker.
go in trunk .remove 4 nuts . remove inside car
Oct 21, 2008 | 2007 Chevrolet Impala LS Sedan New Cars
Rattle Problem w/ subwoofer
When you put the new foam, maybe the cone went off center. Get a new kit, and re-do the job with more care. Check to make sure that the spider is okay, and that the speaker coil is not warped or anything like that.
There are speaker companies the professionaly rebuild speakers. They are better equiped and have the jiggs and facilities to properly rebuild the speaker from the coil up.
If you really want your speakers, you should consider giving the complete set out for rebuilding and testing.
Jerry G.
Apr 27, 2008 | Audio Players & Recorders
Brand New Speakers Distorted and not right...
Are you still using the same head unit? You could try to run a short set of new wire to one of the speakers directly from the unit. Had you previously used these speakers in another vehicle...what I'm getting at is that you need to isolate the problem. If the speakers test fine in another vehicle, I would think there is something wrong with the existing head unit
Dec 31, 2007 | Pioneer TS-A1057 Coaxial Car Speaker
Nokia Play 360° bluetooth speaker Logo
109 people viewed this question
Top Nokia Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Nokia Audio Player and Recorder Expert? Answer questions, earn points and help others
