Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Replaced two IC's and still the same problem????
Well? I replaced the ic's and a repairman said was out..... And I still have the same problem with my TV??? The screen is bowed in from the top and I see multicolors... Before and after fixing the ic's, when I go to the convergence adjustment screens? It won't let me adjust the red and blue crosses into the white; also the white cross looks green??? What else can it be, that's wrong with the convergence??? Help me, please??? Thank you, Cliff
  • 1 more comment
  • rano Nov 03, 2007
    philips PTV915(cassis) 60P8341 green out for 1" to the right in menu red and blue in center green + is on the right donot have a option for green convergence only red and blue
  • HRDRCK Mar 18, 2008
    I CHANGED MY IC CHIPS TODAY AND IT DID NOT FIX THE PROBLEM,LOOKED AT ALL 6 OF THE RESISTORS, TWO LOCATED AT EACH PLUG FOR THE THREE DIFFERENT COLORS AND THEY DO NOT LOOK LIKE THEY ARE BAD. I HAVE A DIGITAL MULTIMETER IN WHICH I TESTED ALL OF THE SIX RESISTORS .BUT HAD SAME READING ON ALL. NEED TO KNOW WHAT THE NEXT STEP IS TO RESOLVE THIS PROBLEM?
  • HRDRCK May 11, 2010
    Checked to see if there were any fluids that leaked. None. This TV has a tray like thing to catch all fluids. Could it be the resistors?
    Genius:
  • 1,153 Answers
U say the set is bowed in from top, could this be a foldover? If so then the ic problem may not help. Check to see if any fluid leakage has dropped on your deflection board. If so then you probably will need to clean and replace some capacitors. This is kind of common with the philips projo's. Look around crt for fluid leakage and on board.
Posted on Aug 09, 2007
SOURCE:
Sony projection TV has double rainbow image
A component called IC STK needs replacement, You didn't wrote Model No. of TV otherwise i must provide you the specific part number of the said IC, Anyway contact any repairman nearby to replace the said IC.
Thanks.
May 14, 2011 | Televison & Video
2.2 ohm resistor blowing after convergence repair
It might be the issue on the board. I would recommend you to show it to a repairman
Sep 07, 2008 | Panasonic PT-47WX49 47" Rear Projection...
AV-56WP74
Could be shorted convergence chips. There are two of them in the TV. If they short they will shut the TV down. One quick test is to desolder both of them...then power the TV on..if it fires up the chips were shorted and would need to be replaced. You can get a complete kit from www.TvRepairKits.com
Mar 11, 2009 | JVC AV-56WP74 56" Rear Projection...
Pioneer HD TV - color fades
its the problem of STK --ICs in the television.they r located on the main board.the ic has to be replaced.it costs near to $30 per ic.there r two such ic on the board.both has to be replaced.
thanks.
Dec 15, 2008 | Televison & Video
Detailed problem per your response
The problem is that the ICs may have been blown because the resistors were bad. Just as a double check before you replace anything else. Please confirm that the STKs are STK392-110. Also, replaceing them with STK392-150 is a valid upgrade, I'm not sure about the 180s, but I'll check. Both the STKs and the resistors need to be changed at the same time.
The hour glass view you reported: Was the bowing on the top and bottom or on the sides?
Thanks,
Dan
Sep 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Auto convergence
Bull!!!!!!!!! i dont think he knows what hes doing....
you can send the board into ptscorp.com have them check it out, it's the board with big black iC stk392-XXX send that one in, you convergence is done thru the menu system.
Feb 15, 2008 | Philips 55PW9363 55" Rear Projection...
Kv-36xbr800
Hiii...
My version is :
For safety reason you should replaced them ( Horizontal ic,Vertical ic, Deflection ic) and olso all the big capasitor nearest the ic....that's my version....if you have big budget for it....he..he....
Thank's
[Vrya]
Dec 27, 2007 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
71 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
