Question about RCA 20F420T 20" TV
Tv Volume is Locked
Our Hand-Me-Down Sharp Unytron television suddenly stopped letting us control the volume. It only lets us have three settings; no volume, half volume, and full volume. The problem is, the half-volume is still WAY to loud.
There was no remote, but we have been using a Radio Shack 5-in-One Remote just fine for over a year. The problem is the same whether we use the remote, or just click the TV itself.
We can't really afford a new TV right now, so any help would be greatly apricated.
  • rachelcreate Jan 05, 2009
    I tried unplugging it for an hour, and the problem still persists. Anymore ideas?
    also, there is no menu, as far as I can tell, or none that I can get to without the original remote.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls post back the exact model number of the Sharp Unytron, something like 13RV629 or 20SB50.
Offhand, let's try the basics/easy ones. Try to see if you could enter the MENU/SETTINGS/AUDIO. The idea is to reset the audio controls back to default factory settings. Normally, there would be a choice for personal settings, try to reset that also. I suspect that there is nothing wrong with the Sharp, it was just programmed to operate like that by the previous user. If the universal remote does not have a MENU button, see if there is one at the front/side panel controls. Once inside the MENU, the channel up/down and the volume up/down would control the selections.
Good luck and Thank you for using FixYa.
Posted on Jan 04, 2009
  • RCA Master
  • 19,396 Answers
Try first unplugging tv power plug for a while, so that you can reset the TV, then verify that your all in one is controlling the TV, eventually reinsert code.
If the problem is none of the above, then it is a faulty TV, to find out the TV must be tested with original remote.
  • RCA Master
  • 13,433 Answers
Try unpluging the tv fot a hour and see if the settings reset. also look in the menu if you can find a settings reset or factory defaults to that direction.
Virgin remote control code for volume on my 50" samsung plasma tv
To set up the volume control on your Telewest remote control, to be able to change the TV volume, please follow the instructions below.
1. Using the table below find your make of TV and the code which matches it.
2. Press and hold down Volume + and mute on your remote control at the same time for at least three seconds, until the green light in the top right-hand corner of your remote control flashes twice.
3. Release the buttons and enter the first four digit code from the table below. (You must do this within ten seconds).
4. As you enter the first three digits the green light on your remote control will give a short blink.
5. As you enter the fourth digit, the green light will flash twice to confirm that the volume is set.
If setting the volume is not successful, please repeat the above steps with the second or third codes from the table below.
Samsung 0065, 0584, 0037
Nov 18, 2011 | Samsung 50 in. Plasma TV
Volume won't display and can't enter menu
U can unplug.replug about an hour later,it will reset it back to factory setting.Should work as before.
Mar 06, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Need codes where can i find them
To set up the volume control on your virgin remote control, to be able to change the TV volume, please follow the instructions below.
TV Codes
Akai 0236, 0544, 0630
Alba 0037, 0065, 0246
Amstrad 0205, 0440, 0065
Bush 0246, 0263, 0377
Decca 0064, 0100, 0544
Ferguson 0101, 0363, 0221
Fidelity 0244, 0221, 0460
Finlandia 0374, 0387, 0236
Goodmans 0065, 0064, 0100
Granada 0379, 0387, 0391
Grundig 0563, 0582, 0515
Hinari 0037, 0064, 0065
Hitachi 0253, 0384, 0377
JVC 0681, 0081, 0122
Matsui 0263, 0205, 0037
Mitsubishi 0136, 0382, 0064
NEI 0065, 0365, 0459
Nokia 0508, 0501, 0576
Panasonic 0678, 0254, 0278
Philips 0584, 0065, 0040
Saisho 0039, 0205, 0263
Sanyo 0236, 0073, 0100
Sharp 0121, 0064, 0065
Sony 0533, 0038, 0039
Tatung 0065, 0100, 0544
Thomson 0363, 0653, 0137
Toshiba 0536, 0063, 0271
If I have not listed your make of TV in the table above,
1. Press to go to the Home Screen.
2. Choose Telewest Services.
3. Choose Technical Assistance.
4. Choose TV Control Codes.
5. A full list of TV brand codes will appear.
If the volume control is still not working after trying all the codes for your TV model, or your TV model is not listed, then your TV is not compatible with our remote control and you will need to use your TV remote to control the volume as normal.
You can also use your TV remote control to adjust the volume in the normal way. Good Luck
Jul 27, 2009 | Televison & Video
No remote, channels locked on smart tv
On this set, the volume buttons are the same as the menu button on your remote. The two channel buttons work the same as the scrolling arrows on your remote. It will take some practice, but to turn on the menu, press both volume buttons at once. Then practice using the volume controls to scroll. Once you have the hang of it, you can simply use these four buttons the same way you would have used your remote. If you cannot figure it out on your own, come back here, let me know, and I will sit down and map it out completely for you.
Hope this helps in some small way!
Jan 30, 2009 | Philips TP2784C TV
Volume
Sounds like it's locked. Either hold the remote control "DISP" down for 3 seconds, or press it repeatedly about 10 times & it'll unlock.
Jul 16, 2008 | Insignia NS- 27" TV27 TV
Re: K displayed and Volume control
Hi.
Do this it will remove your set from factory mode.
  1. Unplug the AC power cord of TV set .
  2. While holding down the “VOL (–)” and “INPUT” keys on the set at once, plug in the AC power cord to turn on the set.
  3. The letter K should have disappeared from the screen.
Your set will now work correctly.
http://dysonmanuals.llc.nu/
May 25, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Why does my RCA TV cycle through channels on its own?
Hi there!
I think your remote may be at fault. Liquid spill or sweat from the hand accumelates on the inside over some time and then becomes sticky. Some of the buttons may be permanently activated. Then other functions won't work. Have someone check it for you or if familiar yourself. Regards, JUS004
Mar 12, 2008 | RCA TruFlat 27F520T 27" TV
Ilo 32-hd
ILO TELEVISION TURN ON AND OFF BY IT"S SELF, IF I HOLD DOWN THE VOLUME BOTTON IT COMES ON,LET THE VOLUME BOTTON GO NO PICTURE
Aug 29, 2007 | iLO 3200 32 in. LCD Television
RCA 20F420T 20" TV Logo
50 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
