Question about HP Officejet 5610 All-In-One InkJet Printer
5610 all-in-one wont print black
Black ink wont print
Ink cartridge magenta will not print and the cartridge is full of colour
Posted on Dec 20, 2012
SOURCE: How do I replace the black ink cartridge for hp 5610
make sure the printer is switched on
you can find a door at the right side end of the printer just open it and you can change the catirage
if you still cant follow use this below link
http://www.shopping.hp.com/webapp/shopping/store_access.do?template_type=product_detail&product_code=Q7311A%23ABA&jumpid=oc_R1002_USENC-001_HP%20Officejet%205610%20All-in-One&lang=en&cc=us
Posted on May 08, 2008
  • 20 Answers
SOURCE: How do I change my black ink cartridge for my HP 5610 All-in-One
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
alkkk-5
Posted on Sep 06, 2009
pineworks
  • 4041 Answers
SOURCE: Black ink will not print on my HP 5610 inkjet
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Feb 27, 2010
  • 1751 Answers
SOURCE: I have inserted new black
Hi
check expire date on black cartridge if it has pass
replace it with a new one or remove all old ink and replace it
with fresh one ..check here how
Posted on Oct 30, 2010
apkb29
  • 174 Answers
SOURCE: I recently changed the black
you make sure to removed the nosil protector tape to be removed.
otherwise the nosil may be dried out and ink did not come out.
Clean the nosil with soft tisue until ink comes out.
Posted on Apr 30, 2011
Can the printer print with only the black cartridge in or do you have to have both the black and color cartridges for the printer 5610v all-in-one to work?
90% of HP printers require both. I have not personally tried the 5610, but when I worked retail, I remember hearing a lot of complaints about it and HAVING to have both color and black in.
The reasoning behind having both cartridges in:
Ink is a liquid. When a liquid sits, it dries. Inkjet printers use print heads (microchips) to transfer the ink from the tanks to the paper. If these print heads get clogged. Say goodbye printer (or atleast is ends up costing more to fix, than to replace).
Aug 28, 2011 | HP Officejet 5610 All-In-One InkJet...
I have two cartridges in my 5610 a #22 color and a #27 black. I received a low ink message, but didnt know which one was low. I noticed that the most recent Word document looked fuzzy so I replaced the...
Hi
You can bypass the alignment on 5610 by pressing ok to start alignment
and then cancel
after that check by printing a document if your cartridges work fine if not
you can refill them with this easy and cheaper method
Jan 19, 2011 | HP Officejet 5610 All-In-One InkJet...
I have inserted new black ink. but it is not printing in black. color ink is not new but color is printing but without quality. hpofficejet 5610
Hi
Oct 12, 2010 | HP Officejet 5610 All-In-One InkJet...
Why won't my printer print black with a new ink
see it this site your problem solved
http://cluetechnologies.com/index.php?topic=688.0
Jul 02, 2010 | HP Officejet 5610 All-In-One InkJet...
Very slow printing - HP 5610 all in one
Very simple solution: The cartridges still have ink in them but printing is very slow. Remove the cartridges from the printer. Take a wet paper towel and wipe the print head on each one until the ink flows from each head. Usually it is the color cartridge because it is used less than the black one. Once ink is flowing again, reinsert the cartridges into the printer and your normal printing speed will return. This worked for me, no thanks to the "experts" or trouble shooting guides.
Oct 20, 2009 | HP Officejet 5610 All-In-One InkJet...
My HP 5610 is printing extremely slow.
Very simple solution: The cartridges still have ink in them but printing is very slow. Remove the cartridges from the printer. Take a wet paper towel and wipe the print head on each one until the ink flows from each head. Usually it is the color cartridge because it is used less than the black one. Once ink is flowing again, reinsert the cartridges into the printer and your normal printing speed will return. This worked for me, no thanks to the "experts" or trouble shooting guides..
Oct 05, 2009 | HP Officejet 5610 All-In-One InkJet...
HP L7680 prints red instead of black
Check your default ink setting if red is default then change it and make black ink default settings.
Thank You
Jul 28, 2009 | HP Officejet 5610 All-In-One InkJet...
My printer is not printing black it's printing yellow
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
ab8
Jul 16, 2009 | HP Officejet 5610 All-In-One InkJet...
HP 5610 Will not print Color documents, only Black and White
Chances are that your print driver is set to print in black and white while the copier side is automatically detecting that your original is in color. To have the printer print in color: Select file print, select your printer and hit preferences. Select the Paper/Quality tab and switch from Black and White to Color.
Henry
Apr 28, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
43 people viewed this question
Seeker5211
Seeker5211
