How to disassemble Cambridge Soundworks Ensemble II speaker
I want to disassemble a pair of old Cambridge Soundworks Ensemble II speakers so that I can blow dust off of the electronics. However, there is no obvious way to disassemble them.
I have a pair of CSW Ensemble II speakers; I did this so I could strip the sticky Nextel paint off and refinish the cabinet.
You first need to remove the grill by using a paper clip hook to pull the wire mesh grill off; you will then see screws to remove the drivers and get to the electronics (the drivers have a bit of glue to hold their frame in place but gentle prying popped them free.)
You can pry at any grill hole, but there is a larger one at the top/center edge that was specifically made for this purpose; work around the top or bottom edges so scratches will not be visible. The grill is held in place by sticky tape at the 4 corners so it's easy to re-install.
Posted on Mar 30, 2013
3 Suggested Answers
Open SKy
  • 620 Answers
SOURCE: Fluctuation in sound output on Cambridge Soundworks 5.1 speakers
Hi Paulus
A lot brand of speakers, like Sound Blasters, Logitech, Cambridge, has this (strange) kind of volume problem, sometimes, is the resistor, in the volume control, sometimes in the modulator for the board on the sound speakers, Subwofer.
I use a general tip is let the volume in one setting and don't move in the intermediate low volume say....9 .
from other thing, be change the speakers.
Posted on Nov 26, 2007
Open SKy
  • 620 Answers
SOURCE: cambridge soundworks speakers
Happy Holidays Fredonna
Well, easy task, just put a music CD, on system and if you got an headphones, put in the green connector on your sound card, pop up the PC volume, and see if you heard sound, if you do, heard sound then the problem is your speakers. if don't is your sound card.
good luck
Posted on Dec 26, 2007
I need circuit diagram for Cambridge Soundwork Slim 500 model. Where I can find it?
    Cambridge Soundworks circuit diagram cambridge audio a1 ...
    www.fixya.com > ... > Tags > circuit diagram cambridge audio a1 mk3
    Ask your Cambridge Soundworks circuit diagram cambridge audio a1 mk3 questions. Get free help, advice & support from top Cambridge Soundworks experts. images for circuit diagram for Cambridge Soundwork
Jan 05, 2016 | Audio Players & Recorders
Owners manual for a ensemble 3 sub woffer
Try http://www.manualslib.com/manual/220406/Cambridge-Soundworks-Ensemble-Iii.html
Feb 04, 2015 | Audio Players & Recorders
How can I replace a tweeter for a 10 year old Cambridge Soundworks tower 2 speaker?
Its pretty simple actually.
If you already have the same size new tweeter. You take off of course the large felt cover so speakers are exposed on front. Just like your picture is in this post. Then you should see some screws, most likely it is going to be Phillips. Then unscrew all the screws, the whole front should slide out with of course speakers still attached, don't pull out to fast or far, to make sure the internal wires are long enough to take whole front out and set aside speaker box, the on back of speaker should be two wires going to it, maybe three if is tapped in conjunction with a ground. Anyway on back of speaker unplug the wire from speaker and then, take out screws which is normally on back of speaker, pull speaker out, put new one in and repeat steps in reverse order. Hope this helps. Mike
Jul 07, 2011 | Cambridge Soundworks Tower II Speaker
Sony STR-DH510 Multi-channel AV receiver connected to cambridge soundworks ensemble IV w/ passive subwoofer: no sound from center channel during viewing, or during speaker level test- all other speakers...
The STR directs sound to the center as instructed by its speaker setup. You say the center does not work on calibration. Is it defined?
Prove another speaker does or does not work on the center output. Then we'll know if it's the receiver or the speaker ensemble that has the problem.
Have you checked the manual for this "
There is no sound, or only a very low-level sound is heard from the center/ surround. "?
Aug 03, 2010 | Yamaha DSP-A1 Receiver
Cd won't go into the cd slot on the Soundworks--any suggestions?
As far as I know, SoundWorks speaker systems don't have a CD slot. Why would they?
They're supposed to be connected to a computer, which has a CD/DVD drive.
Nov 22, 2009 | Creative Labs Cambridge SoundWorks PC...
No volume
do they plug in with a 3.5mm audio jack?
if so, i think you need to check your drivers for laptop output socket.
have you tried output with any headphones etc? do they work on laptop?
Feb 25, 2009 | Cambridge Soundworks SWBL SoundWorks PC...
Cambridge soundworks speakers
good luck
Dec 24, 2007 | Gateway Edison Computer Speakers
Hi Paulus
Nov 25, 2007 | Cambridge Soundworks Movie Works 108...
1,051 people viewed this question
 Grubhead
Grubhead
