Question about Jenn-Air 35 in. JGC9536 Gas Cooktop
Ignitor quit working on GE Monogram ZGU375NSD3SS...gas stovetop
We had this converted to LP...did work for a few months...now, we need to use a lighter.
  • leeladevere Jan 05, 2009
    Asn we took it further apart...we see that the transformer has a burned out looking place in it...we will replace it tomorrow and I will report what happens.
    President:
  • 2,976 Answers
If it still clicks and tries to spark, get in there with a a toothpick or a pin and clean out any spilled food and / or carbon build up. If the sparker itself doesn't even try, it will need to be replaced.
Posted on Jan 04, 2009
My GE Monogram gas range will not light. The igniter keeps going off but the gas will not light.
Hi, sometimes cooking spills stop the ignitor from working. Clean the cook top thoroughly and try it again. Spills can also make the ignitor go off randomly when you are not operating your cooker. Check if the ignition point where the zap comes from is not turned or bent too far from its original position. If you have a gas shut off make sure it is fully open to supply enough gas. If all else fails buy a cheap hand held ignitor to start your gas stove. If the cause is a spill which sometimes the problem can persist even after cleaning it may take a while for it to work again. If the problem is with all six burners then your ignitor probably needs replacing. When you hear the ignitor zap check to see if the electronic zap appears to jump across to the edge of the burner. If it doesn't it will not light the flame no matter how many times you try. I hope this helps you.
Aug 21, 2012 | General Electric GE Monogram 48""...
My GE Monogram Gas Cooktop model ZGU650N4DH5SS ignitor keeps sparking even after the stove is lite. What do I need to change or fix please?
Hi Ishiggs,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 11, 2011 | Cooktops
Mod jgp328wec2ww changed orifices from nat to lp. Burners not getting hot enough. It took 12 min to bring 1 qt to boiling and not rooling. how is this adjusted?
Please tell us everything you did to convert your stovetop/oven to LP? Beside swapping the natural gas orifices for LP orifices, did you also switch the appliance regulator over to LP? When you put in the orifices did you match up the proper size ones to each different size burner according to your owner's manual? They have #'s stamped on them to identify them and some are even color coded. Were you having any similar issues with your previous stove? If so, it may be a pressure problem. I can help you solve this problem with a little more information. Douglas
Oct 05, 2010 | GE Cooktops
I have a GE Monogram Gas Stove - 5 burner. All
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
w3
Jun 15, 2010 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Grill will not ignite-glow pug is bright red
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter
http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Feb 14, 2010 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
GE Monogram ZGU48N6D- None of the Ignitors "click"
We just had that problem - the igniter is electric - if none of the burners are "clicking" it could be a power problem. unplug the stove and check whether the outlet is working. In our case, the outlet the stove is plugged into has a "GFI outlet with a reset button. So we reset the outlet and that fixed the problem.
Apr 08, 2009 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
KitchenAid Stovetop with grill and griddle - KGCP484KSS0
hi im gerbee, try to clean the sensor valve by using a scott brite, the sensor place in the side wen the flame is on like a gold metal, 2nd try to adjust the flame control by using a plat or + screw,u see it at the gas control knot on top the small screw.adjust to high flame is touch the sensor valve.sory for my english.tnx gerbee i hope i help u
Nov 30, 2008 | KitchenAid Architect KGCP484KSS Gas...
GE 36" Monogram Gas Cooktop - low flame
I would have someone come out. Perhaps a gas plumber first. Gas is not something you want to fool around with yourself.
Aug 01, 2008 | GE 36 in. JGP628 Gas Cooktop
Converting stovetop from natural gas to lp
there is a square nut on top of the regulator un screw it and underneath you will find a Cly flip that over should take care of it one side will say ( nat) the other will say( lp) you want lp up
Feb 25, 2008 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Jenn-Air 35 in. JGC9536 Gas Cooktop Logo
596 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
