Question about HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001
The power light just blinks along with rest of them on ac power
I can here the hard trying to start up no beeps at all if i push ctrl & alt along with delete the list stays on but still no screens
    Master:
  • 680 Answers
Could be a bad battery. You could take the computer along with the battery and have it bench tested.
Terry
Posted on Oct 19, 2013
How to restore acer extensa 5620z to factory setting no disk
is the mother board working at all
any beeps or lights on start up ?
any keyboard function
if you can confirm mother board is alive but no boot up
possible hard drive failure
end game
Sep 04, 2016 | Acer Computers & Internet
My acer wnt start up or boot is bios missing dll blue screen is all i ger
If you have a boot menu the problem is likely not the Bios. No beep codes? Some PC's will give hardware error codes in the form of long and short beeps through the MB speaker. Otherwise a bad boot sector on the hard drive would likely give you an error message, like ; NTLDR is missing
Press Ctrl+Alt+Del to restart
Check the power and ribbon wire connections to the hard drive. If you have recovery disc/'s, doesnt hurt to try! Otherwise its a new operating system, new hard drive, and searching for drivers. Good luck to you!
Aug 13, 2014 | Acer Aspire 7540G Compatible Laptop Power...
Emachine E528 Laptop is saying a disk read error occured push ctrl+alt+delete an it will restart
The error that you are getting indicates that the system is not able to detect the Hard Drive. We would need to confirm if the Hard Drive is detected in the system BIOS or not. For that we would need to turn off the computer. Turn on the computer and start hitting F2 key to reach BIOS. On the First page of BIOS it should show you the Hard Disk Drive with name and Number. If it shows all drives and none or not detected then it means the hard drive is not getting detected by the system. If you can open the Laptop and reach the Hard Disk Drive you can try to re-seat it to see if it gets detected. If it still remains undetected, Its time to replace the Hard Disk Drive.
Please try the above steps and get back for any further assistance or clarification
Aug 05, 2012 | Computers & Internet
My Laptop doesnt start at all . I dont know what
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
Oct 15, 2009 | Dell Inspiron 6000 Notebook
Pavilion dv6700 locks up; mouse & keyboard frozen;
If you take the battery out and unplug the AC power the laptop will shut off.
Aug 15, 2009 | HP Pavilion dv6000z Notebook
Access Toshiba BIOS
WHEN YOU FIRST TURN THE COMPUTER A LIST OF INSTUCTIONS WILL POP UP FOR 5-9
SECONDS, YOU NEED TO PAUSE THAT PAGE SO YOU CAN GET THE RIGHT ACCESS.
HERE ARE SOME DIFFERENT COMBINATIONS TO TRY.
DEL BEFORE TURNING ON HOLD THIS KEY DOWN UNTIL YOU HEAR THE BEEPING NOISE.
F2
F1 DURING BOOT
F10
RESET DEPRESS 2 TIMES
CTRL ALT ENTER
CTRL ALT ESC
IF NONE OF THESE DO NOT WORK THAN YOU NEED TO BUY THIS GUYS BOOK VER COVERS BOIS 2006 AND NEWER
I HAVE THE OLD ONE. VER 1997
THE BIOS COMPANION BY PHIL CROUCHER
May 12, 2009 | Toshiba Satellite P105-S6177 Notebook
Floppy drive
You're talking about My PC and device manager and I'm talking about Bios.
The BIOS (stands for Basic Input/Output System) is system software inside your computer that helps the computer start up, even before Windows does. It also contains key settings about what the computer has on board.
In newer computers, it exists on a special chip called CMOS (stands for Complementary Metal Oxide Semiconductor).
You can go into the BIOS to edit or change the technical information about key components of the computer like disk drives, keyboards, and display settings. It also keeps track of the date and time.
The BIOS can normally be accessed when you start your computer. You may see a reference to "Setup" when you turn your computer on. That’s your opportunity to get into the BIOS. It usually requires the push of a function key, such as F10, to get access to it. That "F" key varies between computers. Sometimes it’s not even one of the Function keys, but the ESC key or DEL key.
If a logo screen—like HP or Dell—is displayed during the start up process instead, then you may want to check with your computer maker for a command to turn off that screen and display the start up information, which is listed when a computer is powered on.
A partial list of BIOS access commands by brand is listed at the end of this article.
The BIOS also contains the boot-up sequence. Normally, computers are configured to boot from a hard drive.
Before you do anything to your BIOS, it’s always a good idea to record the original settings on a sheet of paper that can be kept in a safe place so you can reference it later if you need to reset it.
Here is a list of key sequences for various brand-name computers. If yours is not there, check with your manufacturer or watch for info flashed on-screen when your computer first starts, before Windows begins. It may say
"For setup hit..." That will be how to get into the BIOS on your machine.
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or Ctrl+Alt+Esc
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl+Alt+Esc
Award BIOS: (Del) or Ctrl+Alt+Esc
Compaq: (F10) (do this when the cursor is in the upper right corner of the screen blinking)
Dell: - F1 or Del.
Dell: - Some require pressing reset twice
Dell: - Ctrl + Alt + Enter
DTK BIOS: (Esc)
Gateway 2000: - F1
Hewlett Packard: - F1
IBM:
Older Models - In order to get into the configuration of the IBM setup screen (CMOS) screen you need to hold down both mouse buttons during boot up.
Aptiva - Press F1
IBM PS/2: Ctrl+Alt+Ins after Ctrl+Alt+Del
IBM PS/2 with reference partition: - Press Ins during boot
Some PS/2s, such as 75 and 90: - Ctrl Alt ?
Some PS/2s when pointer at top right of screen: - Ctrl + Ins
NEC: - F2
Packard Bell: - F1 or F2
Phoenix BIOS: (F1), (F2), or Ctrl+Alt+Esc
Phoenix BIOS: - Ctrl+Alt+S
Phoenix BIOS: - Ctrl+S
Phoenix BIOS: - Ctrl+Alt+Ins
Sharp Laptop 9020: - F2
Sony: (F3) while you are starting the PC, then (F2) or (F1)
Tandon computers: - Hold down the key after turning on power
Tandon: - Ctrl+Shift+Esc
Toshiba Laptops: - Toshiba Utility
Toshiba: - Press Esc during boot
Toshiba, Phoenix, late model PS/1 Value Point and 330s: - Press F1 during boot
Olivetti PC Pro: - Shift+Ctrl+Alt + Num Pad Del
Miscellaneous PC’s: - Ctrl + Esc or Ctrl and Alt and +
Zenith: - Ctrl+Alt+Ins
Let me know how it is going!
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Oct 15, 2008 | Computers & Internet
Problem with a disk read error
There are a couple of possibilities.
1. The hard drive is defective.
2. The operating system is corrupt.
The easiest way to test this is to run the restore cd that came with the computer to reload Windows.
If you get this error while running the restore cd then you will need to get a new hard drive.
Jan 03, 2008 | Computers & Internet
The Dreaded Blinking red light
what actually happens when you try to reboot?
Dec 07, 2007 | Computers & Internet
HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001  Logo
89 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
