Question about Epson Stylus C88 All-In-One InkJet Printer
Printer is printing whole page/page instead of highlighted lines.
I have an Epson Stylus C88+ Ink Jet printer that is two years old and all of a sudden it's printing all the page/pages Instead of what I've highlighted to print. Contacted Epson and followed their instructions for update of drivers and still having the problem. Have scanned for viruses. Would someone help me with this problem. Thanks, Robert Argo
  • 2 more comments
  • rtargo20 Mar 23, 2009
    I've tried twice to answer that I found my problem. I can't find where to post my "problem has been solved" Thanks......
    I've tried twice to answer that my problem is solved. I was not checking the " print selection". Thanks
  • Gerry Millward
    Gerry Millward May 11, 2010
    Hi Robert
    It makes it very difficult to help you if you don't respond to our queries. Please provide the requested answers in a new post.
  • Gerry Millward
    Hi Robert - the printer only prints what the computer sends it. Does this occur with all applications or just one e.g. Word?
  • 353 Answers
In view of rtargo20's lack of interest in this problem, I think we may declare it "solved by poster"
Posted on Mar 22, 2009
  • 7 Answers
SOURCE: Epson C88 communication error 600
yes you have to go to control panel and remove the drivers and install the drivrs again ok
Posted on Dec 09, 2008
gwbm
  • 353 Answers
SOURCE: Epson Stylus C88 InkJet Printer
Are you confident the new cartridges are full and in-date? Can you confirm that the old cartridges were not removed until immediately before the new cartridge was installed. Did you remove the yellow tape from the new cartridges before you installed them? Were the cartridges changed properly such that an ink charging cycle occurred. Have you carried out any head cleaning cycles recently? If not, do it. Then do a nozzle check print. Any improvement? Yes, but not perfect? If so do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
If you have already done lots of head cleans with no result, and you're sure you have good ink cartridges properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean/nozzle check again. If still nothing, post a new comment detailing what you have done and the results.
Posted on Mar 01, 2009
gwbm
  • 353 Answers
SOURCE: EPSON Stylus C88 Series not printing blue ink
From the lack of interest by koolcorgipro in this problem, I think we may say it has been solved by the poster.
Posted on Mar 26, 2009
tigertail
  • 163 Answers
SOURCE: epson stylus C88 won t print color ink black is
If you have carried out 4 to 5 head cleans, waited about 8 hours and done another 3 or head cleans doing nozzle checks after each clean (as recommended by the manual) and there is still no improvement then you will need a third party head cleaning solution such as this one:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Other makes & brands are available just google "inkjet head cleaning solution" Hope this helps.
Posted on Apr 03, 2009
gwbm
  • 353 Answers
SOURCE: epson c88 prints horizontal lines
It looks like storm_christ has lost interest in this problem, so we may call it "solved by poster".
Posted on May 06, 2009
Epson Stylus C88 Ink Jet Printer only prints in blue but when i look at ink levels they all almost empty
Replace all ink cartridges and the printer will work again. The level indicators are just indicators and are not precise.
Jun 07, 2014 | Epson STYLUS C88 INK JET PRINTER...
Epson Stylus C88 - New Epson Factory ink cartridges. Nothing prints, although printer goes through the motions of printing. What could be wrong? Ink levels are fine.
You should run a nozzle check to verify if the heads are printing all the inks correctly. If the pattern is incomplete you need to run head cleanings.
Apr 30, 2010 | Epson Stylus C88 InkJet Photo Printer
One line per page of printing has a white line through the printer line. It is not in the same spot on each page.
Clean the rollers inside the printer. That should remove anything that is blocking the ink flow onto the paper
Oct 24, 2009 | Epson Stylus C88 InkJet Photo Printer
Black and Magenta ink won't print...
Do a deep clean on the printer.
Done from the printer setup.
widows is done from start, printers and faxes, click on your printer.
Should bring up window for setup.
Look for cleaning section.
May 07, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson c88 prints horizontal lines
Apr 06, 2009 | Epson Stylus C88 InkJet Photo Printer
My ink is jammed fro epson stylus c88.
i would download the ssc and try reseting your printer
Mar 03, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson stylus cx5100 prints but no ink comes out on page.
It probably your head printer is jammed or dirt you have to use head cleaner fluids and inject it from ink head intake
Mar 02, 2009 | Epson Stylus C88 InkJet Photo Printer
Feb 23, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson C88 printer only prints blank pages
See my post about about underhead cleaning. If that makes no difference you will need the countermeasure for the split cap tube. The document about loss of ink on CX series machines is also applicable to C88
Jul 18, 2008 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus C88 All-In-One InkJet Printer Logo
44 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
