Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Get a Professional
Find a Solution
Most Common Problems for:
Turntable in GE microwave stopped turning.
chrisfan11 on Jan 04, 2009
I assume the small drive motor needs replacing. How do I change the drive motor and / or troubleshoot the problem?
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 04, 2009
Very Helpful)
MicrowaveSvc
Rank: Guru  GE ExpertGE Expert
Rating: 88%, 4456 votes
On some GE models, the turntable motor and stirrer motor are powered off a tap on the internal cooling fan motor and in such cases they will be marked "21V AC".
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
It is vital that the cooling fan runs, or the turntable and stirrer won't work, and magnetron will soon be destroyed.
A quick test is to remove the stirrer cover in the ceiling of the oven. The owner's manual tells you how, and you can download that here.
Then run the oven for several seconds with a cup of water inside while watching the stirrer blade in the top. It should turn very slowly.
If it does not turn or is jerky, it or the cooling fan is not working.
Also, we have a sound clip of what a microwave should sound like when the cooling fan and everything else is working here. The cooling fan's absence will be notable after you hear the clip.
The turntable system otherwise consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If the cooling fan is good, but yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Accessing some parts may require you to pull the oven from thew wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Was this helpful?
Yes
No
1 person thought this was helpful
Related Problems
One of the bulbs for the under microwave lights separated...
Everything seems to work but cannot heat anything up
My touchpad is not working. The time is displaying and the...
It takes much longer to heat than it used to. (!0 minutes...
The keypad does not work. The display screen says "Press...
Can you Help with these Microwave Oven problems?
F3 is displayed on GE...
Solve
F3 is displayed on GE Microwave. Keypad does not work.
the turn table does not engage
Solve
I need a template for drilling the...
Solve
I need a template for drilling the mounting holes for a model JVM1653 GE Spacemaker microwave
microwave is heating fine, hear the...
Solve
microwave is heating but no air is blowing from the top exhaust.
My GE Spacemaker XL 1400 works fine...
Solve
My GE Spacemaker XL 1400 works fine but has a noisy clacking sound and vibrates too much when on.... (More)
Sponsored Links
Describe your Microwave problem:
Top Microwave Oven Experts
Rank: Guru Guru
Solutions: 2825
Experience: I have yrs of experience dealing with many situations.
Ask Me
Find more Microwave Oven Experts
Top Small Appliance Repair
(866) 895-9295
Rest assured, when you place an order for parts it...
Easy Appliance Parts
(800) 341-6361
Mr. Appliance Corporation is one of the largest...
Mr. Appliance
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
