Question about Toro "Toro" Super Blower/Vac
How do i replace the impeller on a toro blower model 51587
The impeller has 3 broken fins on it and needs to be replaced. I can buy the part on line but how do I remove the existing impeller?
5 Suggested Answers
rwvanlue
  • 486 Answers
SOURCE: Toro leaf blower Model 51591 from 2003 has started
Sounds like a piece of wood is caught under/between the impellor and the case/housing. When removing the impellor, you may find it has a left hand threaded nut.
Posted on Nov 13, 2009
  • 10 Answers
SOURCE: Where can I find brushes
True to an extent but not just any brushes, just be sure to find brushes with the same flex wiring connection and then shave away. You'll need to shave them into the original shape for the ends and length as well as the lateral dimensions, so the springs will fit right.
I had to do this for a Shop Vac, took a few weeks to locate some brushes that would work right with the springs and the wire connection once shaved.
The motor unit was all the OEM would sell, and for the price I could get a new unit. :) Don't you just love a disposable design ethic?
Posted on Jun 09, 2010
2strokeguy
  • 183 Answers
SOURCE: i need a toro impeller
The impeller for your Toro blower is part #98-3150 and is available from www.partstree.com for about $20 plus shipping. To avoid shipping charges, find your local Toro dealer. Go to www.toro.com to find your nearest dealer.
An exploded parts view is also provided on partstree.com's website. This should make it easier to see what has to come apart for the impeller to be replaced.
Posted on Nov 12, 2010
  • 138 Answers
SOURCE: how do replace the impeller on a toro 51591 super
Toro and Sears blowers are pretty much the same. It is not worth the trouble to replace. Good Luck
Posted on Jan 06, 2011
My blower is running extra high and hard. so high that it shakes the cap off. how can i tame it down. model 51587
Remove the bottom of the blower or vac and see if any blades are broken on the plastic fan blade, known as an impeller. If a blade is sheared off, this could be the source of your noise and shaking. This part will need to be replaced. I've just ordered one and will be replacing mine when it comes in.
Jan 06, 2011 | Toro "Toro" Super Blower/Vac
How do replace the impeller on a toro 51591 super blower vac?
Problem is my hardly used Toro Blower Vac is getting no Power
If it has not run for awhile, check the brushes. they might need to be replaced. The plug is usually moulded right on power cord. That might have to be replaced because if there is a problem with a broken or disconnected wire right at plug there is no way to see it. Hope this helps.
Dec 07, 2010 | Toro 51599 Electric Blower 12 Amp
I need a toro impeller model no 51553 or 51587
Nov 12, 2010 | Toro "Toro" Super Blower/Vac
Where can I find brushes for my Toro electric leaf blower (model 51587)? I went to the Toro site and to Partstree.com, but they only sell the motor as a unit (which costs more than a new blower). A...
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Toro replacements are hard to find because Toro does not sell them and it is tricky to make you own.
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers
Jun 07, 2010 | Toro Blowers Rake and Vac - Electric...
Nov 13, 2009 | Toro Blowers Rake and Vac - Electric...
We have a leaf blower 51587 and I don't know how to get the blower on instead of the mulcher. Thank you.
Go to the Toro site I listed below. Choose your model and it takes you to a very neat interactive manual. Basically, the blower tube goes where the bag goes. Just about the extent of it. Good Luck.
http://www.toro.com/home/customercare/interactivemanuals.html
Oct 25, 2009 | Garden
Need a replacement impeller for Craftsman blower
toro impellar is the same thing...even same part#(1009068)
May 25, 2009 | Craftsman Garden
Engage on/off switch will not start
the diode is bad on the start switch check with a meter for amps
Apr 05, 2009 | Toro Blowers Rake and Vac - Electric...
Sm.piece broke off spinner wheel; result motor not balanced
yea if you cant fin da company to order the part form which you probably cant youll have to trash it.
Jan 09, 2009 | Toro Super Blower Vac
Toro "Toro" Super Blower/Vac Logo
141 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
