Question about Crosley CE35100AA Electric Kitchen Range
How to operate a crosley self cleaning oven model#CSF365006
5 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: Crosley Range
Here are the fault codes for Crosley ovens:
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Posted on Oct 27, 2007
cosatto
  • 29 Answers
SOURCE: lost manual for Crosley self cleaning oven-HELP
Copy the below link into your browser and contact Customer Services, they should be able to email one to you for your model
http://www.crosley.com/service.do
Posted on Dec 11, 2008
SOURCE: Crosley self cleaning oven manual
I have a crosley but don't know if it is the same model.
1. move door to locked position
2. Press self-clean pad.
3. press up or down to select clean time (it will flash 3:00)
4. if you wish to delay the start of cleaning press a. stop time b. press the up button on pad to select the time of day then press clock and time of day will reappear. Press stop time pad to recall the time you set.
5. When the oven turns on the oven on indicator will light. Internal lock will engage and door cannot be unlocked.
6. About one hour after the clean cycle ends, the lock indicator will turn off. The oven door can be unlocked and opened.
** to cancel press cancel.
Hope that helps! RC
Posted on Jan 13, 2009
heatman101
  • 43501 Answers
SOURCE: unable to clean my 5 yr old self clean Crosley oven
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Posted on May 18, 2010
I don't have a clean button on my Crosley oven need cleaning very bad.
turn it up to maximum heat for 30 minutes, turn off and leave to cool. Self clean will only clean the coated sides of the oven.
Sep 20, 2015 | Crosley Kitchen Ranges
No User's Manual
I have a Crosley csf395001 and no manual, how do I turn on self clean option
Mar 26, 2010 | Crosley Kitchen Ranges
I have a Crosley Range that is self cleaning oven. Lost the manual..do I just press the CLEAN button for the oven to be cleaned?
You also have to close the oven door lock or Clean just wont happen. When the Clean light turns off, you are done.
Mar 05, 2010 | Kitchen Ranges
I need a manual for Crosley Self Cleaning model CSF 36500-1 or instructions on how to use the self cleaning oven.
Go to www.servicemanuals,net recheck your model number i looked for the one you listed and did not find it.
Sep 03, 2009 | Kitchen Ranges
Unable to clean my 5 yr old self clean Crosley oven
heatman101
Aug 31, 2009 | Crosley CE35100AA Electric Kitchen Range
I have a kitchenaid ceramic stovetop. recently I used the self cleaning oven and now it seems to not operate correctly. there is a frequent beeping noise....
is it the glasstop range with the oven control panel in the front? if so one of your over temperature thermostats is faulty.. it is probably causing an f-1 error.OR.. your temperature probe in the oven could be going bad.
Jan 01, 2009 | Crosley CE35111AA Electric Kitchen Range
Lost manual for Crosley self cleaning oven-HELP
Dec 11, 2008 | Crosley CE35100AA Electric Kitchen Range
Hope that helps! RC
Jun 21, 2008 | Crosley CE35111AA Electric Kitchen Range
Stove manuals for Crosley Electric Stoves
how do I operate the self cleaning function on my stove model
cs37500-1
Nov 12, 2007 | Crosley CE35100AA Electric Kitchen Range
Crosley Range
Failure
Code
Oct 27, 2007 | Crosley CE35100AA Electric Kitchen Range
Crosley CE35100AA Electric Kitchen Range Logo
21 people viewed this question
Top Crosley Kitchen Ranges Experts
Vitaliy Gins
Vitaliy Gins
Rob
Rob
Level 1 Expert
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
