Question about Kenmore 62622 Microwave Oven
No heat in a kenmore microwave model 721.80012401
4 Suggested Answers
  • 112 Answers
SOURCE: Microwave won't heat
The two possible causes are a faulty door switch and a bad magnatron. You can pull the top cover off of the unit and check all of the door switches (there are 2-6 of them all on a common rail, me normally closed)). If the door switches all check out, replace the magnatron, diodesmag-glass_10x10.gif, and capacitor
Posted on Oct 28, 2008
ginko
  • 19396 Answers
SOURCE: kenmore microwave model 665.68681891 runs but won't heat
Test the high voltage capacitor, the rectifier diode.or the magnetron. If all this are fine, test the control board.
If it additionally does not spin and no light, then check also the door switch and fuse.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
SOURCE: microwave stopped heating
I had the same oven for one and a half years and had the same problem. Had the sears repairman come out and he said the magnetron burned out and needed replacing for $285. It was never under warranty with the warranty that came with oven. I couldn't believe it! We had an independent repairman look at it and he found a design flaw that causes the magnetron to blow. If you replace the matnetron (megnatron?) it will work for awhile, maybe, but then just need to be replaced again. It's cheaper to buy a new microwave. In fact, I got out our old microwave that's over 20 yrs. old and still works--just isn't as fast and as new ovens. Good luck!
Posted on Jul 24, 2009
Why is my microwave model 60609 making extremely loud noise and not heat?
Usually that is a sign that your magnetron tube has gone bad (shorted out).
Jun 10, 2014 | Kenmore 80822 80823 80824 80829 1500...
My still fairly new kenmore 1000 watt microwave appears to be operating fine but doesnt heat. What might be the problem?
When you hit "Start" to microwave, do the inside light, cooling fan, and turntable all come on?
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
Post a new help request with the answers to these questions as well as the full model number from the tag on or in the unit.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Apr 14, 2013 | Kenmore 62622 Microwave Oven
Kenmore microwave model 721.80033700 won't heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Jul 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My Kenmore microwave model 565 60502990 will heat sometime and sometimes it won't. It runs even when it won't heat?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jhhjujk
Jan 05, 2010 | Kenmore 63792 Microwave Oven
My Kenmore Elite Microwave Model No. 721.64683300 does not seem to be heating well and will shut off and flash an F9 code. What does the F9 code mean
Oct 07, 2009 | Kenmore Microwave Ovens
Kenmore Microwave Oven model #401.80082700
Sounds like a bearing is tightening up when it get heated up with use. Then after a cool down period it works normally until using it heats it up again. Eric
Sep 15, 2009 | Kenmore 62622 Microwave Oven
Kenmore over the stove microwave will not heat 1996
YOUR MAGNETRON IS MOST LIKELY BAD. THIS IS THE UNIT THAT CREATES THE MICROWAVES.
Apr 11, 2009 | Microwave Ovens
Kenmore microwave
Since it's under warranty, they will replace or repair it at their choice, and if they replace it, it will be the same model or a "like model".
I'd ask them about it.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 04, 2008 | Kenmore 63663 Microwave Oven
Kenmore 62622 Microwave Oven Logo
215 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
