Question about Kitchen Ranges
How to self clean crosley range model #CSF365006
fridgetech
  • 473 Answers
SOURCE: Crosley Range
Here are the fault codes for Crosley ovens:
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Posted on Oct 27, 2007
gwshaw71
  • 83 Answers
SOURCE: self clean
if your oven has a clean cycle it will say clean on the knobs or a button if digital.self cleaning cycle turns on both broiler and bake elements and temperatures up to 1500 deg.and disintegrates everything in oven also you will have a door lock on oven door
Posted on Nov 25, 2007
  • 1314 Answers
SOURCE: Whilrpool Self Cleaning Range Door won't unlock
try this 1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds.
Momentarily (less than 5 sec.) press CANCEL key again to remove error code
display.
2. Press and hold any key for 1 minute until F2 E0 code is displayed.
3. Cancel F2 E0 error code.
4. Program and start the clean mode. Observe to see if door locks. If it does not,
inspect the locking mechanism from the solenoid to the latch pawl and door to
find the cause of the problem. If the door is not locking, then 1 minute from the
start of clean, the F5 E1 code will again be displayed. Steps 1 through 3 will
have to be repeated before another clean can be started.
5. Once any mechanical problems with the latch mechanism have been corrected,
program and start a clean cycle (after, if necessary, clearing F5 E1 error code)
to ensure proper operation of the door lock. Immediately cancel the clean mode to observe proper operation of door unlock
Posted on Feb 12, 2008
SOURCE: Crosley self cleaning oven manual
I have a crosley but don't know if it is the same model.
1. move door to locked position
2. Press self-clean pad.
3. press up or down to select clean time (it will flash 3:00)
4. if you wish to delay the start of cleaning press a. stop time b. press the up button on pad to select the time of day then press clock and time of day will reappear. Press stop time pad to recall the time you set.
5. When the oven turns on the oven on indicator will light. Internal lock will engage and door cannot be unlocked.
6. About one hour after the clean cycle ends, the lock indicator will turn off. The oven door can be unlocked and opened.
** to cancel press cancel.
Hope that helps! RC
Posted on Jan 13, 2009
SOURCE: ROPER ELECTRIC RANGE SELF CLEANING
how long to leave on to self clean
Posted on Apr 18, 2009
I don't have a clean button on my Crosley oven need cleaning very bad.
turn it up to maximum heat for 30 minutes, turn off and leave to cool. Self clean will only clean the coated sides of the oven.
Sep 20, 2015 | Crosley Kitchen Ranges
-F-3 error message on stove
F-3 is open or shorted temp sensor probably due to using self cleaning mode, temps in self cleaning mode on some brands and models can reach upwards of 1000 F. replace temperature probe, and if problem ensues replace clock\control.
May 09, 2012 | Crosley Kitchen Ranges
No User's Manual
I have a Crosley csf395001 and no manual, how do I turn on self clean option
Mar 26, 2010 | Crosley Kitchen Ranges
I have a Crosley Range that is self cleaning oven. Lost the manual..do I just press the CLEAN button for the oven to be cleaned?
You also have to close the oven door lock or Clean just wont happen. When the Clean light turns off, you are done.
Mar 05, 2010 | Kitchen Ranges
I need a manual for Crosley Self Cleaning model CSF 36500-1 or instructions on how to use the self cleaning oven.
Go to www.servicemanuals,net recheck your model number i looked for the one you listed and did not find it.
Sep 03, 2009 | Kitchen Ranges
Unable to clean my 5 yr old self clean Crosley oven
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Aug 31, 2009 | Crosley CE35100AA Electric Kitchen Range
Lost manual for Crosley self cleaning oven-HELP
Copy the below link into your browser and contact Customer Services, they should be able to email one to you for your model
http://www.crosley.com/service.do
Dec 11, 2008 | Crosley CE35100AA Electric Kitchen Range
Hope that helps! RC
Jun 21, 2008 | Crosley CE35111AA Electric Kitchen Range
Stove manuals for Crosley Electric Stoves
how do I operate the self cleaning function on my stove model
cs37500-1
Nov 12, 2007 | Crosley CE35100AA Electric Kitchen Range
Cleaning glass on oven door
The marks may be on the inside part of the glass. If so then the door will need to be taken apart for cleaning. You can use a razor blade scraper and glass cleaner to soften the buildup. Self cleaning won't remove if it is on the inside.
Oct 01, 2007 | Crosley CE35100AA Electric Kitchen Range
Kitchen Ranges Logo
21 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
