Question about Tefal Avante Deluxe 4 Slice Toaster
T-Fal Bagel toaster makes buzzing sound
I have a T-Fal Avante Delux Bagel toaster. When you push down the toasting lever, the two small red lights switch on by "reheat" and "bagel" and the machine emits a reasonably loud buzzing sound.
I'm assuming this is a built-in feature to warn something's not right.
Anyone know what this means, and how to solve it?
Many thanks
    Problem Solver:
  • 5 Answers
I'm not sure if this applies to your problem, but I found a great solution to the buzzing I've experienced on my GE toaster at the following link: http://applianceguru.com/forum1/18670.html
Posted on Dec 19, 2010
Toaster BTA830XL only toasting bread on one side the outside elements only. Not using bagel setting.
There are tow issues here: Bilateral elements (heating strips) of course are necessary for two sided toasting, and you mentioned the Bagel Setting. Are you saying the Bagel setting works with both sides in operation and inoperative when in normal mode? Obviously is in both modes, should only one side function, the element is burnt out.
We need more information.
Jan 16, 2018 | The Kitchen Appliances - Others
Hi my girlfriend just gave me this toaster, and would like to know what the lighted buttons are for thanks
Since you don't mention the make or model number of the toaster or its age I can only make the following guesses.
It might be an electronic model. To test if this is the case, leave the toaster unplugged and push the lever of the toaster down. If it does not stay down it is an electronic toaster. If it stays down then it is NOT electronic.
The lights might be lighted push buttons.
If you plug the toaster in then put a slice of bread or two in and push the lever handle down and one light comes on then this is probably a dual purpose pushbutton. It indicates that the heating elements are on and if you push it will cancel the toasting cycle and the bread slices should pop up.
If there is a button beside the above button it could be for extending the toaster cycle time a bit longer to compensate for a thicker slice or a denser bread like a bagel. If you push it, it will light up to let you know that the cycle has been extended for this reason.
If there is a button beside this one, it could be for extending the toasting cycle to compensate for a frozen slice of bread or whatever, like a bagel or even a frozen waffle.
If you find the make and model for your toaster, it might be on the bottom somewhere, google it to see if you can download an instruction manual for it.
Hope this helps. Good Luck.
Jun 03, 2017 | The Kitchen Appliances - Others
What are top buttons for
Each bay has 3 buttons: Left button: Frozen items (Waffles, etc.)
Center button: Bagel setting ( turns off the outside elements, toasting only the insides of the bagel)
Right button: Cancel (turns off the Frozen and/or the Bagel settings and "pops up" the toast.
Feb 24, 2013 | Kenmore KTES12 Cool Touch 4-Slice Toaster
Toastmaster B1042 toasts only one side of one slice and both sides of other slice
The is by design. The bagel side only heats on one side because of the bagel not needing to be toasted .
Jan 16, 2013 | Toastmaster Kitchen Appliances - Others
Received 2 slice toaster (kitchenaid) as a gift - from the very 1st time it was used, only the outer coils would heat up, so only 1/2 of each slice ever gets toasted!!! Anyone who could help solve this...
I think it is set to cook bagels. Check the control settings.
Most toasters have a bagel setting which only cooks the
sliced side of the bagel. This model is designed to accept bagels. Hope this helps.
Jul 22, 2011 | KitchenAid KMTT200OB 2-Slice Toaster
The lever to push down the toast will not lock in to start the toastng cycle
Inside the toaster (behind the toast, bagel, etc. Buttons) there is a magnet, this needs to be clean for the taster to lock. First, unplug the unit. Now remove the cap on the thumb lever and the four screws at the bottom, separate the toaster. Now you will see the magnet, remove any debris with a dry towel or with your finger tip. After properly re-assembled this should work.
Dec 20, 2009 | Oster 6330 4-Slice Toaster
Slide button won't push down
I have the same problem, if my toaster isn't plugged in. If it is plugged in, it should work.
May 02, 2009 | West Bend 6220 Slide Thru 2-Slice Toaster
Toaster only toasts on one side
Please ensure that the "Bagel" function is not selected (LED is not lit up). The Bagel function will toast one side of the bread while only warming the other side.
Mar 13, 2009 | KitchenAid KTT261 Ultra Power Plus 2-Slice...
Tefal Avante Deluxe 4 Slice Toaster Logo
728 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
