Turning on and off by itself. Capacitors are not blown
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Maybe time to check voltages there---problem has to almost certainly be power supply related or on the main board with the control circuitry.
Posted on Nov 04, 2012
I have an Emerson LED HDMI flat screen television. I would like to know why it keeps turning off and on randomly by itself.
if the power board capacitors are fine ( blown or brown gunk under the capacitors are damaged should be flat tops) then its the smd capacitors next to the processor under the heat shield 16v 1000uf. there will be 2 of them. on the input board.
Apr 24, 2018 | Emerson Televison & Video
TV will not turn back on after it's powered off
The capacitors on the power supply need to be replaced. When you take apart the TV, and then remove the power supply (it's the section that the power cord goes to) and open it up. Look for the little can capacitors and see if any of them are bulging on top. That is the sign that they've blown. Replace the big ones (about 5) for about $5 in parts. Reassemble and test by turning it on. Search for YouTube video on how to replace capacitors.
Feb 05, 2014 | Samsung 39" 1080p 60Hz LED TV...
Tv shuts off
Jan 12, 2014 | Samsung 55" UN55D6420 3D LED TV Smart TV
Sharp primo tv 21 inch have power but no display?
You may have one or more capacitors blown. This is a very typical problem. Google "Blown TV capacitor" to see the pictures of a (blown) capacitor so you know what and where to look inside the TV.
Nov 29, 2013 | Office Equipment & Supplies
I turned my tv on, it then turned itself off, there is no red light, have turned off from socket but still nothing.
Hi!
That's a clear indication that you have a bad power supply in your TV.
If you know how to DiY...I suggest you open your TV. Locate the power supply section, it is where the end of the power plug is connected. Replace all blown or bulge or leaked capacitors with same value. That will fix your TV problem.
The hardest part is to disassembling your TV cover, cause you will need to pry off the snap in lock at the edge of your TV.
Power supply board should look like this. Examine the capacitors in the board
After replacing blown capacitors...it should work again.
Things you will need.
1. A plastic flat end screw or any object with flat ends....to fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Hope it helps
Mar 06, 2012 | Televison & Video
Sanyo tv keeps turning itself off any ideas?
You probably have blown capacitors on the PSB-power supply board. Recaping with new UF caps works 90% of the time. The set turns itself of into a fault protection to keep from damaging more components internally. A few bucks a soldering iron some solder should do the trick.
hope it will help you. -monchi
Oct 17, 2011 | Sanyo Televison & Video
Playstation 3 turned itself off while i was playing a game and now every time i turn it on it keeps turning itself off after like 3 sec
It sounds like your PS3 overheated and is now shorting out. Try removing the power from it completely, and let it sit for about 4 minutes. Plug it back in. If it doesn't straighten out, you will likely need to contact Sony support for an RMA- it sounds like yours has developed blown capacitors
Dec 16, 2010 | Sony PlayStation 3 40GB System
Monitor turning itself on and off
If you can open it... check the capacitors in the power supply section. Blown, bad or bulge capacitors need to be replaced with exact value. If you have the knowledge and the right tools then you can fix it by yourself. Otherwise bring it to a repair shop
Aug 10, 2010 | Westinghouse Computers & Internet
Tv keeps turning on and off
Jun 29, 2010 | Sanyo DP50747 50 in. Plasma TV
Akai LCT2785TA Capacitors blown out
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Nov 25, 2008 | Akai LCT2785TA 27 in. LCD Television
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
