Question about Sylvania 4GB Micro Video/MP3 Player SMPK4600BL
My sylvania smpk4600 wont turn on unless plugged into computer
No battery unless plugged into computer
My Sylvania netbook says loading os image and stays right there
There are a few things you can try to fix this issue. The first thing is called a hard reset. Remove the battery and unplug the netbook from power. Press the power button for 30 seconds and then release. Replace the battery and plug the netbook back in. Try turning the computer on again and see if the same message displays. If it does, remove the battery and unplug the power, remove the memory chips from the computer and then reseat them. Replace the battery and the power plug and turn the computer back on. If it is still hovering with that message, you may have a crashed hard drive and will need to replace it and reload the operating system back on it. The only other thing you can do is do a full system restore with either the OS disks that came with the machine, or if the OS came preloaded on the netbook, there is usually a hidden partition that can be accessed to try and reload the operating system back to the way it was when it was new. In any case, you may or may not have lost whatever info you have on the drive unless you backed up your data somewhere along the line. Depending on where you are located, many of us are licensed, certified technicians that can help you out to determine for sure what is wrong.
Jan 09, 2015 | Sylvania Computers & Internet
My sylvania laptop wont turn on
Nsanchez1370:
It sounds like your operating system crashed. If you have the operating system disk you probably need to reload the operating system. You'll lose anything that you have on the hard drive unless you have backed it up...
Mar 16, 2013 | Sylvania G-Netbook
I just bought the smpk4600 and I got the installation CD, however, I have a netbook with no disk drive. How do I install the player?
Use a computer that has a CD drive, place the CD in this computer and copy the files off the CD on to a USB memory stick. Then insert the USB memory into your netbook to install the player.
Apr 10, 2011 | Sylvania Audio Players & Recorders
My sylvania smpk4600 mp3 player won't turn on, it only works if it is connected to my computer via the usb cable.
I had the same trouble I noticed that it acted differently on different usb ports strange but it happened, swap to a different port, if the battery animation isnt moving that it hasnt synced properly i noticed that it especially didnt like working with my front panel usb ports, switched it around tot he back and it charged just fine
Mar 21, 2011 | Audio Players & Recorders
Just bought sylvania smpk4600 mp3 player and charged for 6 hrs and it doesn't turn on
Did you hold down the play/pause button? Instructions say to hold that button (last one on the right) down until it turns on.
Feb 28, 2011 | Supersonic IQ-4600 Digital Media Player
Wont turn on unless plugged into computer
Hi it very much sounds like the on board batttery is not charged up, (not charging) hence when you plug into the PC it gets it supply from the USB 5Volts and plays as normal
Apr 15, 2010 | SanDisk Sansa Clip MP3 Player
Ipod touch wont turn on unless pluged into computer
Itmaybe a battery problem...if you think its not a battery problem,you may want to try a software upgrade/restore...if your software version is already the latest one,backup all the ipod contents before you restore...you will find the restore option in the summary tab in itunes.
Sep 27, 2009 | Apple iPod nano
Mine just wont turn on unless i plug it in to the computer
Mine had the entire screen lined out and the screen faded out over that day. Let the battery run down if you can, charge it. If you can't get the battery to run down then I don't know what to do.
Good Luck
Feb 28, 2008 | SanDisk Sansa e250 MP3 Player
Sylvania 4GB Micro Video/MP3 Player SMPK4600BL Logo
24 people viewed this question
Top Sylvania Audio Players & Recorders Experts
David Payne
David Payne
Tre Elkins
Are you a Sylvania Audio Player and Recorder Expert? Answer questions, earn points and help others
