Question about Hoover AAA160 Front Load Washer
Machine fills for about 10secs then stops and cycle begins.
Water supply is fine. Machine is 6 months old
Check the water level indicator not, make sure it is at full load. Also is the load balanced.
Posted on Nov 03, 2012
  • 1462 Answers
SOURCE: hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
Posted on May 04, 2007
  • 236 Answers
SOURCE: Machine fills, agitates partially & very slowly for a few cycles, does not Spin, empties water and stops.
sounds like the motor brushes need renewing.
Posted on Jun 02, 2007
SOURCE: WASHING MACHINE FILLS WITH WATER AT START THEN STOPS SHOWING ERROR 5
the carbon brush may be worn out and need replacement(these are a pair of componet that makes contact to the motor. Francis
Posted on Jul 16, 2007
  • 1003 Answers
SOURCE: hoover nextra wont fill
REPLACE WATER INLET SOLENOID
Posted on Feb 02, 2008
  • 41 Answers
SOURCE: Over filling of water and fail to wash cycle
blocked pressure switch hose
Posted on Jul 14, 2008
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
    My washing machine is not changing cycles. It fills, drains and refills. It sat unused for 1 year. 12 months ago it was working fine.
    Hi there. I can help you.
    • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. If this is the case, turn off the water and remove the hoses. Check both hoses to be sure the filter screens are not clogged with crud and that the hoses aren't kinked.
    Jun 18, 2009 | GE WSXH208A Front Load Washer
    Stops in the middle of wash cycle
    Hi!
    If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
    The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
    Frigidaire washing machine gets stuck on cycles
    Apr 01, 2009 | Frigidaire Washing Machines
    Soon as i set cycle and swich on door light flashes open
    hi,
    Thanks for your question.
    Jan 03, 2009 | Ariston Technologies AW129NA 16 Lbs Front...
    Basin will not fill with water during rinse cycle but will agitate and spin.
    most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
    Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    Washing machine fills in the water but does not start the wash cycle
    The fact that it does not fill completely can be related to a problem with the water-level switch, that regulates the water level.
    See from Repairclinic:
    "This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch."
    However, when it is only the switch the mashine usually completes the cycle, but with less water than normal.
    A possibilty is that either the timer is faulty or there is a problem with the water supply.
    Check that water is coming from water supply with regular pressure, and that hoses back there are not obstructed.
    More likely you will have to replace the timer.
    See again from Repairclinic:
    "When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water."
  • You can find parts at the following websites, you need to input your model number. If the part is not listed contact them.
    Repairclinic
    Partselect
    Don't forget to rate the solution.
    Many thanks.
    Sep 01, 2008 | Washing Machines
    Whirlpool AWO3761 stuck mid-cycle
    The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Hoover AAA160 Front Load Washer Logo
    Top Hoover Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
