Question about Toshiba Satellite A75-S206 Notebook
My Toshia A-75 mouse pad is not working. Pointer is stuck and cannot access my computer.
    Sergeant:
  • 279 Answers
Try downloading drivers from here.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=713723&rpn=PSA70U&modelFilter=A75-S206&selCategory=3&selFamily=1073768663&selModel=713723%7CPSA70U#
After updating the drivers, if it still doesn't work, you may need to get it repaired if it's a hardware issue. You can use the keyboard to navigate Windows (Tab, Alt, cursor keys, etc.)
Posted on Jan 04, 2009
HP 2530p EliteBook - touchpad stopped working. Scrolling works except touch scrolling on right side of pad) and right button, but that's all. Wireless mouse works fine.
To access Mouse Properties, select Start - Control Panel - Hardware and Sound -Mouse.
Use Mouse Properties in Windows to customize settings for pointing devices, such as button configuration, click speed, and pointer options.
Jan 18, 2013 | HP EliteBook 2530p Notebook
The mouse pad of our computer is not working how can u fix this problem?????????????////
Depending on what kind of laptop you have, there are generally have a button that enables the
mouse pad. Most of the time, it sits just above the mouse pad. The other thing you can check is to use your windows button to open the start menu, use your pointer keys to navigate to control panel, then to the mouse icon. Make sure you mouse pad pointer device is selected on the bottons tab and the device settings tab.
You can also try a restart, using the same windows button and the pointer keys to select restart to see if this will reset your mouse pad. If this does not work, look at the two suggestions above.
If you found this information helpful, please remember to leave positive feedback.
Thank You,
Brian
Feb 10, 2011 | Computers & Internet
I have a Dell studio laptop. Recently, within the
1. In order to fix this, you go to control panel > mouse
the last tab is called "Device Settings" click it and make sure you have "static tray icon in taskbar" selected.
(You can always remove this later.) Apply the changes and click the red coloured icon in your task bar. An option will be available called "Tap to click." Clicking it will enable you to tap with your mouse pad instead of the keys! Hope this helps you out, I know it helped my friend.
2.
In the Control Panel open Accessibility Options Icon and click Mouse Tab and than Setting.
To move the mouse pointer by using MouseKeys
If you have not already done so, turn on MouseKeys.
To turn on MouseKeys, open Accessibility Options, click the Mouse tab, and then select the Use MouseKeys check box. Use the buttons on the numeric keypad to move the mouse pointer. If MouseKeys doesn't function, press NUM LOCK, and then try MouseKeys again.
To move the pointer horizontally or vertically, press the arrow keys on your numeric keypad.
To move the pointer diagonally, press HOME, END, PAGE UP, or PAGE DOWN on your numeric keypad.
Notes To open Accessibility Options, click Start, click Control Panel, and then double-click Accessibility Options.
To specify whether NUM LOCK must be on or off for MouseKeys to function, on the Mouse tab, click Settings, and then for Use MouseKeys when NumLock is, click On or Off.
To change the pointer speed and acceleration when using MouseKeys, on the Mouse tab, click Settings, and then move the sliders to adjust the pointer speed and acceleration.
To temporarily increase or decrease the pointer speed, on the Mouse tab, click Settings, and then select the Hold down Ctrl to speed up and Shift to slow down check box.
Jul 27, 2010 | Dell Studio 1737 Laptop
Mouse wont move
Are you referring to the mouse pointer when using the touch pad? To isolate the problem, try to use a USB mouse and see if the pointer will move. If the USB mouse works, then the touch pad could be disabled.
Refer to the user manual of the laptop and see on how you can enable the touch pad.
If same problem occur even though you're using a USB mouse, contact the manufacturer of the computer for second opinion or repair.
Good luck and have a great day!
Feb 08, 2010 | Dell Inspiron 6400 Notebook
Pointer stuck in middle of screen on my acer laptop,Help!!
Are you using a mouse or the touch pad? Make sure the touch pad is turned on.
Jan 06, 2010 | Acer Aspire 5100 Notebook
Compaq notebook laptop: my mouse pointer or arrow is
If you have a manual for the notebook, check to see if you can use the function key and the similarly coloured key on the keyboard which enables/disables the touch pad. Usually you can disable the mouse pointer touch pad with this FUNCTION key + MOUSE key when pressed together. Often these keys have the same colour (usually blue). The purpose is to disable the touch pad when you are using an external USB or wireless mouse, then you press the 2 keys again together to enable the touch pad once you have removed the USB/wireless mouse.
If that doesn't work, borrow a USB mouse and attach it to your notebook to use temporarily while you diagnose the problem.
Dec 19, 2009 | Acer Aspire 5100 Notebook
When mouse pointer is set to go to default box it does a runner!
check the mouse sensitivity settings under control panel.
Oct 06, 2009 | Computers & Internet
The built in mouse pad needs cleaning. How can the panels be opened ?
I experienced the same issue but luckily enough one of my close friends is a Sony tech and helped me with this (and saved me much money too!)
You need to remove the back panel and soak the unit in lukewarm water. Be sure that the water temp. does NOT exceed 75 degrees or you will damage the battery. Soak for not more than 10 minutes. If no results, then remove the back panel again and soak it for 15 minutes. Again, DO NOT immerse the unit in water that is warmer than 75 degrees!
May 10, 2009 | Sony (1-796-623-14) for PCG-V505 Series...
Mouse pointer stuck.
Hi
make sure when you chang the battery if your mouse has a light(usually red light) it is on
second make sure optical eye is clean , use air duster to clean it , if your mouse is not dameged ,now it should be working .
thanks
Dec 13, 2008 | Computers & Internet
Cursor stuck in middle of screen
If you are using an external mouse, unplug it and see if it will go with the pad.If it works with the pad then its the exteranal mouse.
If you are using the pad you may have to replace the pad or recalibrate it using the pointer device, you can use the tab key to go through to the start menu then use the arrow keys to go to control panel.
Hope this helps
Nov 28, 2007 | Compaq Presario 5000 PC Desktop
Toshiba Satellite A75-S206 Notebook Logo
66 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
