Question about Delta & Single Handle Shower Faucet
Replacing delta 1800 series faucet cartridge - Delta & Single Handle Shower Faucet
  • 67 Answers
SOURCE: Delta Series 1400 shower faucet, no or very little
Remove the handle by opening the little red/blue cap. Use a hex key to remove the handle. Remove the tope ring holding in the cartridge in. Take out the cartridge and you will most likely see particles blocking it. make sure you use a little valve lube or vasline on the seals before you put it back in so you will have smooth operation. If that doesnt cure it just replace the cartridge at lowes or home depot and bring the old one.
Posted on Sep 22, 2009
  • 454 Answers
SOURCE: Delta 1400 series cartridge replacement
The chrome cover needs to be unscrewed with a strap wrench or pair of pliers. Then, you can access the cartridge assembly. You may need an adjustable wrench to unscrew the cartridge.
Posted on Apr 16, 2010
  • 81 Answers
SOURCE: How do you remove the temperature knob and cover
http://www.deltafaucet.com/customersupport/documentation/1824-74.html?document=pd&documentIndex=0 The very center piece of the temperature setter pops off with a screw driver. Remove the screw underneath it and everything else to the handle comes off. Firmly grab decorative sleev behind handle and pull. Firmly grab round brass collar and turn counterclockwise. carefull pry cartridge from brass body.
Posted on May 29, 2010
agent91
  • 2100 Answers
SOURCE: Any ideas on how to remove a stuck 1300 series
Did the plastic break off? Is the faucet in limbo and useless? Is there a retaining ring, nut, something holding it on there? How about getting a piece of pvc pipe that will fit in the hole there, cut the ends with tin snips, pliers, band saw, jig saw, whatever you have available, to fit in the holes and turn the thing out of there. Or better yet would be a piece of copper pipe, something stronger. Check it out.
Posted on Jun 11, 2010
  • 760 Answers
SOURCE: How do you remove the handle from a classic delta
On most delta models you pop the cap in the center of the handle. Then there is a screw to remove the handle. If it is old the bonnet can be hard to remove. Be careful, as you don't want to damate the complete faucet behind the wall.
Posted on Jul 19, 2010
Where is the grub screw that has to be removed as I can't find it?
plumbing - How do I remove a stuck faucet/tap cover ...
diy.stackexchange.com/questions/.../how-do-i-remove-a-stuck-faucet-tap...
Apr 18, 2011 - Anybody can ask a question; Anybody can answer; The best ... There are total six faucets in a bathroom, two made into a bathroom basin ... The other possibility is that there's a small plastic "decorative" cap covering the screw.
How-To: Replace A Shower Faucet Cartridge ' Toolmonger
toolmonger.com/2009/12/01/how-to-replace-a-shower-faucet-cartridge/
Dec 1, 2009 - In many modern shower faucets like Delta and Moen (which is what I have) .... About a year ago, one of the bathtub faucets in my other bathroom jammedopen. .... the exact faucet I have in my shower, so you answered my first question, ...I can tighten and loosen the screw but the handle just won't come off!
Problem Removing Handle Off Of Delta Monitor 1400 Series ...
www.diychatroom.com/.../problem-removing-handle-off-delta-monitor-...
May 20, 2009 - 15 posts - ‎12 authors
... from a Delta Monitor 1400 series tub/shower single handle faucet. ... sorry for the REALLY sxxxxx question. which way to turn (loosen) the set screw. ... only suggestions i have on the issue. when a setscrew will not back off i ...
REMOVAL OF STUCK CURVED FAUCET HANDLE WITH HEX SCREW ' DIY Forums
www.diyforums.net/removal-of-stuck-curved-faucet-handle-with-hex-sc...
Feb 03, 2016 | Home
Delta 18 series tub facet leaks
the possible cartridges you can replace are listed on this pdf
http://www.deltafaucet.com/media/SpecSheet/DSP-B-R18000_Rev_A.pdf
Jan 13, 2013 | Delta Innovations 18 Series Monitor...
Can't get both hot water running at the same time. Delta Shower faucet
  • The spool and sleeve, the part of the Scald-Guard pressure balance valve that blends the hot and cold water, is not working properly. This can is caused by mineral deposits that build up over time resulting from hard water. To fix this, follow the steps below based on your model.
  1. Shut off water supply.
  2. There are two types of valves. Choose one or the other below depending on your series.
  • 1300-1400 Series: Remove handle.
  • 1700-1800 Series: Remove temperature knob, cover and handle.
  1. Twist and pull sleeve to remove it.
  2. Unscrew brass bonnet nut.
  3. Remove cartridge.
  4. Soak cartridge in a 50/50 vinegar and water solution for 24 hours to remove any mineral deposits.
  • **NOTE** Unless both hot and cold water supplies are turned on, the pressure balance valve will allow only a dribble of water to flow through the valve.
  • I have put up a picture to make disassembling it just that much easier for you.
Regards, Tony
May 23, 2011 | Delta & Single Handle Shower Faucet
I have a Delta kitchen faucet Palo 467 series. I am having a difficult time switching between spray and stream on the wand assembly. Occasionally it will "lock" into one position or the other and...
Are you using a softener in your home? Sometimes hard water deposits can clog up the cartridges and create the problems you such described. Im not sure about the lock/button issue though since I have never used this particular Delta faucet myself, but with one problem, it can usually cause many others.
Try replacing the cartridge on the Delta faucet first, Here is a link to the replacement one from the Delta site. http://www.deltafaucet.com/repairparts/details/RP50587.html
Here is a link to Delta warranty and lifetime guarantee. http://www.deltafaucet.com/customersupport/warranty.html
Here is a link to the Delta page with lots of useful information on your product. http://www.deltafaucet.com/kitchen/details/467-DST.html
Ex-Plumber
Hope this helps-
J.Sper
Mar 06, 2011 | Delta Faucet Delta 467-SSSD-DST Palo...
We have a Delta 172 single handle faucet. We had our hot water heater replaced. Now it takes longer for hot water to get to the faucet. Could debris (calcium build up, etc.) from the replacement get in...
Yes, debris from water heater replacements often breaks lose and gets stuck. The problem could potentially be anywhere between water heater and the faucet. The faucets shut off valves or the Delta faucet cartridge itself. Turn the hot and cold water valves off under the sink and disconnect the water supply lines from the faucet. aim the water supply lines into a bucket and turn the valves on one at a time. If there is a significant reduction in the water pressure and volume on the hot water side, you need to replace the shut off valve. If there is no reduction in water pressure, you need to clean and/or replace the Delta faucet cartridge. Contact Delta to receive free replacement parts.
Dec 11, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
I have 5 of these faucets in my home that was built only 2 years ago. All of these faucets leak from the spout. I have replaced cartridges and they still leak.
Did you replace the seats and springs under the cartridges, Delta part number RP4993. These are the more important parts to replace when your Delta faucet is dripping from the spout.
Sep 03, 2010 | Delta Faucet 2578LHP/H277 Leland 4''...
Delta Series 1400 shower faucet, no or very little water out of the cold side of the faucet. Plenty of hot water. What can I do to fix this?
Sep 22, 2009 | Delta & Single Handle Shower Faucet
Delta & Single Handle Shower Faucet  Logo
1,073 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
