Question about GE GSS25JEMWW Side by Side
GE refrigerator not cooling
My GE Refrig is about 10 yrs old. The only number I can find on the back is TFX22PME. The Freezer is working but the refrigerator is not cool enough. I have tried to turn the thermostat down to coolest, the compressor is hot to the touch and the fan is running. Thanks
    President:
  • 1,462 Answers
On most refrigeration, the refrigerant goes to the freezer first and the tail end to the fridge. it is probable that the compressor is failing. compressors are quite hotg when running but not too hot to touch. if the compressor is too hot that also indicates failure. doubt it is worth repair
Posted on May 19, 2007
Refrig won't cool on either freezer or refrig side. Confirmed manual settings & allowed 24 hrs for cooling. Is there a reset switch somewhere other than manual switches inside refrig?
check that the compressor is working by feeling for motor vibrations at the compressor, hot compressor unit or hot fins or back wall of the fridge
if there is not heat then the compressor is not working
call a technician as it could be a start/run capacitor failed or compressor seized
get a quote as some compressor replacements cost as much as a new fridge
check that the utility power is getting to the fridge/freezer
Jul 10, 2016 | Refrigerators
Refrig. is 4 yrs old. Refigerator side just quit cooling. Freezer side seems to be working fine. Help!!! Samsung Model #RS267LBBP
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 16, 2011 | Samsung 26.1 Cu. Ft. Side-by-Side...
Items in refrig are freezing when they're not supposed to.
thermostat has failed i'd say..its not turning off at the requested temp.
Jul 24, 2010 | GE Profile PGSS5PJXSS Stainless Steel...
Side by Side GE Refrig/Freezer is blowing hot air out of the bottom - is this normal?
If your refrig is 10 yrs old or les , then yes , this is normal . It pulls air in from the back over the condensor coils then compressor and out thru the front . The refrig should be 3-4 inches from the wall so it can pull fresh air thru . If any closer , the hotter the air will be causing the coils and compressor to be hotter than designed for therefore causing less life for the refrig . The WARM air is good meaning the refrig is cooling properly .
Jul 18, 2010 | GE Refrigerators
My ge refrig is 30 yrs old...operating normal until yesterday. It constantly runs. the freezerer does not freeze, the circulation fan is not running in the freezer and the lower is cool but not cold.
Good day,
The freezer fan motor going bad, would cause all the symtoms you described. Remove it, take it to an appliance parts house, where they will be glad to test it. If bad, replace.
P.S. Always replace the blade as well when replacing a GE motor.
Mar 18, 2010 | GE GTS22KBP Top Freezer Refrigerator
My GE refrig is side-by-side & 15 yrs. Freezer is good, refrig is not cooling good. its 55C instead of 35C on the coolest setting
Check the evap fan inside the panel in the freezer. Try giving it a spin and a drop of oil. Replacement fan runs about $95
Aug 11, 2009 | GE Refrigerators
GE French Door 22 cu ft (PFSW2MIXSS). Loud buzzing from behind the freezer. Ceased cooling.
The model number you post appears to be incorrect.
The buzzing was from the evaporator fan blade hitting on some ice build up. Getting to it on a bottom freezer refrig is a bit of a pain in the back side. If your model has a pull out freezer drawer, that has to be removed, the icemaker removed, one side of the drawer supports from the freezer wall, all to allow you to remove the back wall of the freezer to get to the fan. You may be able to just thaw out the fan and surrounding area then which will get your refrig cooling again, if the ice was just around the fan area. On the pain in the but repair scale of 1 - 10, this one rates at least a 7.
May 30, 2009 | GE PFS22SBSSS Stainless Steel French Door...
GE Side by Side (3 yrs Old): Freezer iced up, refrig not cooling
Most GE defrost problems are bad defrost thermostat and defrost heater.
It requies removing the back wall panel on the inside of the freezer to access the parts.
Mar 17, 2009 | GE GSL22JFPBS Side by Side Refrigerator
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE GSS25JEMWW Side by Side Logo
499 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
R.A. Ellis
R.A. Ellis
