I have a vaillant turbomax pro combi boiler.ive set my clock for the heating to come on certain times of the day,thats fine. but when the heating goes off it seems to come back on when its not suppose to,is there any reason why this is happening.
It may be the preheat setting on the boiler for the hot water circuit. do the radiators get hot when the boiler fires up with the time clock off ? if not then there is nothing to worry about if it is only on for a short time.
If you they won't go off when your timer is off. There's a possibility it's clock keeping it on although its turned off, which is fairly rare. However depending in which model of Vaillant you have, if your boiler has a hot water pre-heat on it. Some models which have this the diverter was prone for sticking thus leaving the port for the radiators open when in hot water mode.
Being the girl that you are, I'll step forward and ask your need. Can you take a phone cam pic and send it to me so I can see what the rtimer looks like. [email protected]
Most likey problem is the diverter valve, not energising fully. This in turn will not move the little plastic lever arm that actuates the microswitch on the side, sending the signal to ignite.
You can buy a diaghram kit from most local plumb centres, you need to replace the diaghram and seals, don't forget the silicon grease to ensure the plunger doesnt stick. Kits less than a tenner.
You should have noticed before it stopped working completely the water had reduced in temperature before the weeks it failed.
To make sure it is a diverter valve fault, depress the microswitch if you can, when the hot water is flowing and hey presto the demand for hot water light should shine.
check to see the time clock is set with the clock symbol. there are three settings on analog clocks I , O and clock the I setting is constant running, the O setting is off and the clock setting is timer.
also try setting the thermostat up higher to see if the boiler fires.
Which turbomax, as there a two different models. The more modern one, with the brass CPL diverter valve, located at the front left of the boiler, was very prone sticking & jamming, this would restrict flow through the hot water circuit in the boiler, and cause cycling. Vaillant actually modified the diverter. You can identify, if it is the old type, as there is a very small hole in the middle of the diverter on the old ones, probable no more than 1mm-2mm wide. The modfied one, is much bigger approx 5mm wide. If old type, replace as this usally sorts the problem
