My modem sometimes work and sometime show only two lights i.e. power and ethernet and do not connect to my dsl internet
    Sergeant:
  • 279 Answers
Do you know if you have line issues with your phone company? If you're at the outer edges of DSL range from the Central Office, your connection might be dropping. The fact that the power and ethernet lights stay lit shows that the connection might not be on your end. Does the connection get reestablished when you reboot the modem? You may have to get your provider to do connectivity tests on your line.
Posted on Jan 04, 2009
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
Won't connect to internest.
first there should be 2 cables connected the device.
1) power adapter
2) ethernet cable from either a dsl modem or a cable modem connected to the wan connector
with most cable modem service its usually dhcp meaning you are always connected to the internet
with some there is ppoe connection where a user name and password is used to make a connection to be on the internet with the dsl modem
there are some dsl companies that are dhcp just like the cable modem companies.
with the ethernet cable connected the wan port on your router there should be some kind of activity light on the router but check with the type connection from your dsl or cable internet provider. also you will need a second ethernet cable to connect your computer to setup and configure the wireless settings and wep protection.
need more info?
Aug 24, 2011 | NetGear WNR2000 Wireless Router
How do you set the router up!!! no diagram to hook up to desktop
How you connect it depends on how you plan to use it. Let me explain:
Some people have a dsl line (high speed internet connection) and their modem from their internet provider only has room for one computer cable to connect and use the internet. If the customer has more then one desktop computer they want to connect to the internet, they will need to buy a router. A router provides multiple ports for several computers to connect to the internet at the same time.
If you have a dsl modem already and bought a router to add additional computers to your network - then follow the instructions below to set it up:
Connect your phone cord from the wall into the dsl modem. Plug in the power cable from the dsl modem to the wall and turn it on. Connect an ethernet cable to the dsl modem (ethernet cables are the ones that look like a regular telephone cord but the ends are a little larger) and connect the other end to your router. Make sure you plug this cable into the port marked "ethernet" on your router. There is only one port for your internet connection line coming into the router, the rest of the ports are for adding computers only. Some routers say the word "ethernet" near the port for the internet connection. Others have a picture near or or brackets around it to show that it is different then the others. Plug in the power cord to your router and turn it on. Make sure you turn on your modem first and let it warm up before connecting your router. Modem power on first, then router power on - always.
Now connect an ethernet cable to your router and connect the other end to the pc you wish to use on the internet. Do not turn on your pc until the ethernet cord is attached. Your dsl modem has to be powered up first, followed by your router and then your pc. All in that order.
Your computer should automatically sense the internet connection upon start up. You can verify that your connection is installed correctly and that your pc is sensing it by looking at the bottom right side of your screen near the clock area. You should see a picture of a computer monitor that represents your internet connection status. Sometimes they glow green when they are healthy. Sometimes they show a red X on top of them if they are disconnected from the internet. If you can't find the Icon for your internet connection on the bottom right side of your screen, unplug the ethernet cable from the back of your pc - while watching the bottom right side area and plug it back in again. Watch for a change to locate the icon. Sometimes there is a downward pointing arrow near the clock which needs to be clicked on to open up the area and view the icons.
Thats all! One line from the modem to the router - another line from the router to the pc - and the internet should be up and running fine.
If you bought a router combination modem - then its the same as above - just without a separate dsl modem. (i.e. Connect the power cable from the router/modem to the wall. Connect the ethernet cable to the port marked "ethernet" for your internet connecton and connect the other end of the cord to your pc. Then turn your pc on. Router/modem power on first and pc power on second in that order)
All the lights on your modem should be green and steady - except for the one marked internet or connection which is usually flashing and moving. If you have any red or yellow lights then you need to troubleshoot and correct the problem before your internet connection will work.
Mar 03, 2011 | ASUS WIRELESS ROUTER |WL-520G - RT...
My modems LAN light is blinking and I can't get Internet, I've tried unplugging it, but the problem still exists, please help
There will be 4 lights...
Power
Dsl
Internet
Ethernet
Power light indicates power supply is good...
Ethernet light indicates connection between modem and computer is good...
DSL light indicates connection between modem and telphone line is good... Also DSL light should be steady and it should not flash...
If it flashes then it says there is a lot of noise in telephone line...
Internet light says whether the internet status is connected or not...Internet light can flash depending upon the internet activity...
Feb 03, 2011 | Paradyne 6381 ADSL2+/ReachDSL Router...
Ethernet light flashing
Check your DSL Filters on your house phones or anything connected to the phone line EXCEPT the modem. The modem should not have a filter on it. If this doesnt help I would recommend getting your ISP out to test the line because sometimes the resisitors or hardware in the box goes bad or at the DSLAM.
Jul 20, 2009 | Efficient Networks SpeedStream 5667 Modem
Ethernet port
try to reset first the modem before checking the cable maybe your modem need to be reset... if not work... try to unplug for a minute then plug it again... then try to use your internet..
Jul 17, 2009 | Dell Dimension 4600 PC Desktop
Modem won't connect to internet. OS: WinXP Pro SP 3. ISP: Earthlink DSL. Modem: ZyXEL P-660R-D1 (supplied by Earthlink) connected to computer with ethernet cable. Modem includes double filter for phone...
maybe you have to wait for your provider for them to isolate the problem, it seems that your modem got hit maybe by high surge. ask them to bring a spare modem for isolation.. there is no way for you to isolate the problem coz you've already done the basic....
Jun 19, 2009 | Computers & Internet
DSL modem connected but no internet
Have you installed DSL filters on all your phones and make sure you don't have on on the line for your modem?
Jun 28, 2008 | Westell Wirespeed LiteLine 6100...
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
