Question about Hoover Vacuums
Replacing intake hose
We have a hoover conquest vac. and we got a new intake hose, black oblong accordion style in appearance, the one that takes it from the main body to the hard plastic bagless receptacle. Would like to know how to attach it. Thank you. Terry
    President:
  • 1,673 Answers
Should be a clamp on each end to undo, then the hose will come off.
Posted on Jan 04, 2009
How do you clean build up out of hose? i do not find black seal under tank,anyone have a picture of it?
If you want to take the hose off you can just flush it with a garden hose or in a wash tub. Just back flow it a few times. All the parts are plastic and water proof you wont hurt it. The black seal I believe you are looking for is this:
http://www.vacuummedic.com/product.php?id=422
Good Luck!
Vac Dr.
Sep 28, 2012 | Hoover V1 SteamVac SpinScrub Vacuum
Upright carpet vac will not pick up
Broken belt or bloked hose replace belt. Take hose of machine off and take outside Use garden hose to push up one end and out the other.
Apr 27, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hello, I have a Hoover quadraflex Powermatic central vacuum system Model # s8099-031 that requires a new replacement 35 ft hose...I have contacted Hoover and they do not know where to buy a replacement...
Tammy, no info re your location, so I''l try this.
Your Hoover hose is shot because it was made of rubber.There are new swivel handled, tangle proof lighter hoses made of vinyl which will last much longer and can be adapted to the old Hoover head by changing the upper steel tube.
Find a Hoover service center, outlet in the yellow pages and ask for the "NEW "style, gray``Plastiflex`` brand hose and upper adapter tube sold with new Hoovers at Costco and you will be all set. Then, when the head eventually dies, you can upgrade to a far better one , while still having the Hoover cannister, the hose and tools do not need to match the original tank.
Sep 17, 2009 | Vacuums
My Hoover upright vacuum runs but isn't picking up
Either it's clogged, has a broken belt, or the bag needs to be replaced.
Hope this helps.
Aug 19, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
MY hoover steam vac hand held hose cleaner leaks profusely
try taking a sharp knife and shaving a little off the edge of the plastic, or a small file if you can get to it, see if it is getting binded. If its getting stuck internally, you will have to replace the switch instead of risking takin it apart.
Jul 09, 2009 | Hoover F5810 SteamVac Upright Vacuum
Hoover steam vac hose broken so I get no suction.
The entire hose has to be replaced. I beliive they run about 39.99
Jun 11, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Brushes don't work on my hoover steam vac v2
The bearing on the inside of the turbine is rusted. You will have to take the hood of the unit and unscrew the black piece that has to rub hoses going to it. Then take apart the black turbine. Inside you will find 2 white gears and a small 1/2inch bearing. Use wd40 to uncease the bearing. After this put the take pliers and make sure the metal post will turn. Spray wd40 on everything you see including Hoover for making such ****. After this put put everything back together. Now the best thing to do is get some automotive bearing grease and put a large amount on bearing and and other metal parts. Put everthing back together. Clean any hair off the brushes and you are ready. Now the bad news if your gears are worn you will have to replace the turbine. Go to an internet website and the part number will be 91001019. I know all this because I spent 6 years working for Hoover and they found it cheaper to send our jobs overseas.
Apr 11, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Clean water coming out of sides
Hoover SteamVac Ultra (model F5883-900) Threw it away, and had to buy a new machine. Sorry, but I found it more difficult to deal with the housing unit on the machine and just couldn't deal with it anymore. I hope you have better luck than I did with it. I couldn't find ANY help on ANY web sites for this model, just too old I guess.
Jul 26, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Replace interior hose for cleaning attachment for Hoover Steam Vac Agility
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=632107
Replace interior hose for cleaning attachment for...
Posted by castcomm on May 29, 2008
How do you dismantle handle to replace aforementioned hose?
Swing arm on unit goes all the way to the floor. Is this normal? Is there a "stop" broken that caused the hose to stretch, and ultimately break?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac Carpet / Upholstery Deep Carpet Cleaner.
There are handle screws that you can get into the handle and then you can back track the replace the interior hose for the cleaning attachment. There should not be a stop that caused the hose to stretch ad break. The hoses after a while do get old crack and break due from normal use or if the bend @ sharp angles, this is common among all vinyl vacuum cleaner hoses. You should really check with your local factory authorized Hoover vac dealer in your area or , please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 29, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vac - water leaks
May be an "o" ring missing. Being brand new, it is under warranty, you have a 1 year warranty, so you may want to take it for repair.
Dec 31, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Vacuums Logo
56 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
