Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Red tint in my tv wont go away even if i adjust the settings
Outline glow
    Sergeant:
  • 214 Answers
Could be a convergence problem or the CRT might need rejuvenated.
Posted on Nov 03, 2012
Images on screen are very red. Tried adjusting everything in the menu but still every thing is like glowing red.
Color balance is labeled "Tint"
Color amount is labeled "Color"
Both are in the "picture" adjustments menu.
Either your tint is swung too far to red, or the color setting is wide open making normally pink faces look sunburned...likely it's a combination of the two; Too much red, and a bit too much color.
Going back to the "default factory setting" in "setup" will also drop all settings to center.
Mar 30, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Red tint on screen
u shoud reset your setting try to on
Jul 27, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Lines on tv
Try these:
Contrast: 53 Brightness: 56 Color: 44 Tint: 2 Sharpness: 2
Color temperature: Off
Dynamic contrast: Off
Digital Natural Motion: Off
DNR: Off
Color enhancement: Off
Active control: Off
Feb 11, 2009 | Philips 42PFL3603D 42 in. LCD TV
The color on our lg 32pc5rv is too green and we cannot change it
you will need to check the componant cables on the tv, usually if the pic looks green, and wont adjust, the red componant plug has worked its way out, check it on the tv, and on the box, hope this helps
Jan 11, 2009 | Televison & Video
Red tint on screen
Good Day,
Try resetting the TV by unplugging from wall outlet for 3 to5 minutes then plug back in. If no fixya take front grill off and panel and adjust the screen controls, turn color off adjust for Black & White Picture. Good Luck, big IRISH.
Sep 13, 2008 | Hitachi 53UWX10B 53" Rear Projection...
2001 Philips 43P8341Blue outlines on images
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Aug 10, 2008 | Philips 43P8341 43" Rear Projection...
50pc5d LG plasma TV Blue glow/red pixels
THIS PHENOMENON IS A CHARACTERISTIC OF PLASMA TV SETS...KNOWN AS DIFFUSION ERRORS OR COMMONLY..SPARKLING...ON LG SETS...THE PANEL VOLTAGES MUST BE CHECKED AND ADJUSTED IF NOT WITHIN .5 V...PLUS OR MINUS..Vs...and Va...THE OTHER ADJUSTMENTS ARE ON THE Y-SUS BOARD..Vset DOWN...Vset up...RAMP up...RAMP down...these should be adjusted by professional tv personnel with experence...JOE ACE
Mar 05, 2008 | LG 50PC5DC 50 in. Plasma HDTV
Pioneer Pro-119 Rear Projection TV
HEY DF-YOU SET HAS 2 BAD STK392-110 CONVERGENCE ICS.THEY WILL NEED TO BE REPLACED AND IF NO OTHER CONVERGENCE CIRCUIT PARTS HAVE FAILED YOU SHOULD BE ABLE TO SET YOUR CONVERGENCE ALIGNMENT PROPERELY.TV REPAIR ESTIMATE SHOULD BE ABOUT 300.00$.DO IT YOURSELF FOR ABOUT 40.00$.
Nov 24, 2007 | Pioneer PRO-200 60" Rear Projection...
Picture is mostly red
might try to grayscale but that usually means taking the back off and making the adjustments
Oct 30, 2007 | Quasar SP-3233 TV
Sanyo Tv color problem
I would check the green signal all the wat to the display screen to determine is this is a signal problem or a system short. I would recommend that you take this set to a qualified electronics technician
Sep 10, 2007 | Sanyo DS27910 27" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
24 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
