Screen turned a green tint without touching it? Tried resetting or adjusting but didn't work, need help.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Problem is on whatever board controls the demod in the chroma circuit, likely the main signal board.
Posted on Nov 03, 2012
circuitcity
  • 137 Answers
SOURCE: One year old Samsung digital has green color tint; reset doesn't work
One of two scenario. One, you have a bad LDS cable. This cable is found inside the set. This is the cable that is plug into the panel, The other end is plug into the main board. This cable may also just need cleaning. The end that plug into the Panel may have some glue put on it to keep it from getting loose. You may want to unplug it and try cleaning it . Two, You may have a bad panel. In that case you may want to consider getting a new set.
Best regards
CircuitCity
Posted on Dec 06, 2007
Highdefjeff
  • 124 Answers
SOURCE: vizio liquid crystal tv l32hdtv
Check the cable connections and/or replace the cables to the AV2 input.
If replacing the cable doesn't provide a solution, try running your DVD through the input. Since it works fine now, you would be checking the input AV2 by putting your working DVD. If the DVD plays with no problems, the input is fine.
Also try the VCR using coax into the TV instead of RCA into AV2. This will give you some idea about the condition of the VCR.
I suspect either the VCR or the cables.
Posted on Apr 24, 2008
SOURCE: Color has strong green tint - can't adjust with set-up program
One color plug in the back was unplugged - Since the TV had not moved we didn't think to look for that. The cable bundle must have been bumped causing the problem - I feel a bit silly that I hadn't looked for that. Thanks for your follow-up.
Posted on Jun 12, 2009
  • 35 Answers
SOURCE: color and tint looks different
There is a problem with the connectors desoldering in the tv. My mother in laws tv did this after 2 months. Should be warranty issue if less than year old
Posted on May 10, 2010
  • 108 Answers
SOURCE: The TV works fine but the screen is green. Color
LCD television sets dos'nt have crt's, but ofcourses out of the RGB circuitry, R & B circuitry is'nt working or its not receiving the proper signals, that's the reason you see only green color,
If you are feeding the signal thru DMI/RGB cable from your set-top box, check for cable loose contact, cable wear-out, if you are feeding the signal thru coaxial cable its problem within the TV's circuitry.
Posted on Jul 29, 2010
Picture has red tint
I would unplug it from the wall for a while and see if that will help reset it. Also make sure there are no magnetic devices near the screen because this will change the screen color as well. Mine will mess up every once in a while so I just unplug it while I am off running errands, plug it back up when I come home and it seems to reset itself. Good luck
Jun 15, 2014 | Emerson EWF2004 20" TV
Green tint
what cable are uusing coumpount vga 15 pin to coumpunt or u try new cables
Jan 24, 2008 | Dell 3200MP Multimedia Projector
Green tint
Go to a channel that is in black and white and turn color all the way off.
Screen should be a black and white or gray color.
If green there is a fairly easy way to adjust--let me know what you find and I will tell you how to attempt the adjustments.
Feb 18, 2012 | Hitachi 57S700 57" Rear Projection HDTV
Green tinted screen
there is a Circle of Colourfull part in the monitor. it is getting break down. need to go service.
thanks to choosing FixYa.
May 28, 2009 | Acer X193W LCD Monitor
Magenta Color
Here is something that may help from the toshiba.com website under your model number television. Q. Why are people on my screen green?
Models: 32HL17, 37HL17, 42HL17, 42HL167, 47HL167, 52HL167, 42HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00107
If the problem is not the connections, try adjusting the tint on your television. A high tint setting will usually create a green
image on the screen where as a low tint will create a more red hue. In order to access your television's tint:
1. Press the “MENU” button on your remote control and use the LEFT or RIGHT arrow keys and select the
VIDEO menu.
2. Then use the UP and DOWN arrow keys to highlight PICTURE SETTINGS and press the "ENTER" button on
your remote.
3. Next use the UP and DOWN arrow keys to highlight TINT then use the LEFT or RIGHT arrow keys to adjust the
TINT. If the picture is too green the tint will need to be lowered.
4. Once you have adjusted the tint to your liking, use the DOWN arrow key to highlight DONE and press ENTER. The toshiba customer service telephone number is : 1-800-631-3811. I hope this helps you with your problem.
Feb 01, 2009 | Toshiba 42HL167 42 in. LCD Television
Mitsubishi tv problem
im assumiong you checked the tint in the menu options. if not go check it. other wise it sounds like you have a weak tube, or you do not know how to adjust the screen brightness. this is how i adjust the brightness (you dont need to touch the focus). turn the red up until your whole screen is tinted red, then do the same with the blue and the green. then go through each one and turn down just a little till your pic darkens a little. good luck
Sep 27, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Red tint on screen
Good Day,
Try resetting the TV by unplugging from wall outlet for 3 to5 minutes then plug back in. If no fixya take front grill off and panel and adjust the screen controls, turn color off adjust for Black & White Picture. Good Luck, big IRISH.
Sep 13, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Screen Green Tint
Turn down your color and see if the screen has a normal black & white screen. If it doesn't then the CRT is bad (picture tube). If it is black & White then you have a either lost your red or blue.That problem will be in your video driver circuit of which a service center can handle.
Feb 18, 2008 | RCA 20V500T 20" TV
Green tint on a SRT2232S
  • green tint & also very prominent when there is a black screen.
  • this problem is due to degaussing effct or magnetic effct in tv.
  • please remove magenatic material near tv like speaker or headphone.
  • if you have turned the direction of tv please bring to normal put the tv on & put it off for 30 minutes & now put it on it will be ok.
  •  do not turn tv when it is on
  • hope this will help.
Oct 22, 2007 | Sylvania SRT2232S 32" TV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
