Question about Kenmore 98702 Stacked Washer/Dryer
Kenmore stacking washer/dryer model #110 1850292dryer heater stop working
Kenmore stacking washer/dryer model #110 1850292 dryer stop drying. looks heater stop working. how to fix any fuse ?
  • 1294 Answers
SOURCE: Kenmore Model # 417.90812990 Stack washer & Dryer
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Height of exit hose (behind machine) should be approx 3 feet from ground level when you are re-fitting.
Rate me pl.....if helped.
Posted on Jan 03, 2008
docjohn174
  • 943 Answers
SOURCE: kenmore stacked washer / dryer 2002
hi thanks for the question so your saying your tub is full of water ,did it stop in the middle of the wash cycle or at the end of the wash if its at the end of wash and it doesn, drain then you have a lid switch problem . if thats the case reset your timer as if you want to start a new wash load if it starts to wash your timer is ok replace the lid switch
Posted on Sep 15, 2008
SOURCE: Kenmore Stacked Washer / Dryer Model Number 417.97802792
can the rear bearing on the drier be oiled/greased though the back casing, any easy way of stopping sqeek!
Posted on Oct 14, 2008
  • 89 Answers
SOURCE: Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
Posted on May 28, 2009
  • 351 Answers
SOURCE: Can't locate stacking kit for HE2 Plus Washer and HE2 Dryer
more of the model number would help, but i can get them parts for you at www.whirlpoolpartssurplus.com feel free to give us a call
Posted on Jun 23, 2009
Dryer not heating
Check Heating elements if ok check the in line fuse that go to drying element and if it open replace it and clean filter and check pipe that blow out side make sure it not stop up because if in line fuse is open stop up filter and pipe that blow air out side will cause the heating element in fuse to open up. And check for lose wire going to element to.
May 30, 2014 | Kenmore 98702 Stacked Washer/Dryer
On a stacked 417 Kenmore,what is the best way to get to the seal-tub
Here is a service manual for the stacked set. The model may be a little different but the repairs will be the same.
Oct 22, 2012 | Kenmore 98702 Stacked Washer/Dryer
Dryer doesn't heat.
you have to remove the panel between the washer and dryer to get to it it is the smaller fuse on the heater box-mike
Feb 07, 2010 | Kenmore Dryers
My kenmore dryer stopped heating.
yes the price of fixing it is less then a new unit most of the time.
you might need new heating element or cut-off switch only.
Jan 19, 2010 | Kenmore 94702 Front Load Stacked Washer /...
We have the dryer stacked on top of the washer and though we have always cleaned the screen, the dryer doesn't dry very well now. it's 5 years old now.
its likley to be one of your heaters has burned out, it has two one for low heat one for high heat on low only one works,,, both work for high heat
Oct 25, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer stopped heating
this is likley to be the heat seconsers or its the heater/s burnd out if one of the elements have died on you it will only partly dry the washing,, not a hard job to fix but still a bit pricy,
Oct 24, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Kenmore dryer wont stop buzzing
The ECU is faulty - or the timer.
Check/replace as needed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Kenmore 98702 Stacked Washer/Dryer
Dryer door
I would try to run the dryer again. If that doesn't work, it's time to call the repairman.
Aug 11, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
50 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
