Question about GE Washing Machines
Drum is loose - GE Washing Machines
    Top Expert:
  • GE Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 04, 2012
  • 14 more comments
  •  Bret Chaffin
    Bret Chaffin Nov 05, 2012
    WCVH6800JMV GE Toploader approx 5yrs old...
  • Richard Roth
    Richard Roth Nov 05, 2012
    Open the back of the unit and check for loose bolt on the pulley.
  •  Bret Chaffin
    pulley and belt have no play nut is tight
  • Richard Roth
    Check the shocks to see if one has broken.
  •  Bret Chaffin
    The metal part of the drum is loose from the outside drum housing
  •  Bret Chaffin
    parts list only shows drum and outer 2 halves..whats in the middle?
  • Richard Roth
    You have lost me. What part are you talking about? Look at this diagram of that unit. Do you see the part you are talking on it? http://cdn.appliancepartspros.com/images...
  •  Bret Chaffin
    Item 311 stainless steel drum is flopping around inside of 315 and 309
  • Richard Roth
    Well, that is not good. You will need to replace the drum. The shaft has come off and cannot be fixed. Here is a the drum to order.http://click.linksynergy.com/fs-bin/clic... It's not cheap! Sorry to be the bearer of bad news.
  •  Bret Chaffin
    Thanks for your help!!
  • Richard Roth
    You are welcome. I wish I had better news for you. These things always seem to happen before the holidays.
  •  Bret Chaffin
    Im still trying to figure out why this model doesnt list a shaft bearing???
  •  Bret Chaffin
    Bret Chaffin Nov 06, 2012
    Update: disassembled washer it has serv bearings failure is drum arm cracked!
  •  Bret Chaffin
    made in china what do ya except plain as day part and material failure!!
  • Richard Roth
    Richard Roth Nov 06, 2012
    Sorry to hear that. I hate these company's that out source overseas!
  • Richard Roth
    Is it under warranty still?
Drum rattles
If you are sure there are no loose items in or behind the drum, check if the drum is loose (wobble it by hand). Sometimes the bolts holding it to the drive wheel get loose, or the bearing goes.
Apr 24, 2016 | Washing Machines
How do I break rear brake drum loose
un do the adjustment . remove any retaining screws in the face of the drum. Use a hammer and hit between the wheel studs. hit the drum back onto the axle flange If the brakes have been adjusted off then the drum will spring loose.
Oct 18, 2014 | 1996 Ford Escort 4 Door
Indsit washingmachine: making scraping noise when spinning. metal drum inside feels loose and is leaning forward making it scrape on whatever is underneath. how do i stop the drum doing this?
If the inner drum is loose the bearing may have failed or the drum shaft spider may have broken. the scrapping will be the drum hitting the heating element.
Dec 30, 2012 | Washing Machines
Interior drum is loose. The satin less steel drum on the inside seems to have come loose. The outside part is well seated and secure but the interior drum seems to have become loose.
if the drum bangs all around and is noisy when it's spinning the spider gear is broke.usually it breaks from using to much detergent,in a front load washer you use less water so you need less detergent,you should be using 1/4 cup of h.e. detergent,any more than that damages the spider gear,the metal that it's made out of is like a metal stud that you would use when framing a wall,the extra detergent gets in there and it's like sand paper it eats at the metal and it breaks and the drum feels loose.unfortunetly it's time for a new washer,the gear costs around 4 to 5 hundred dollars not including the time.you can check to see if one or both shocks are broken or check the springs on the top sides under the top panel but it sounds like the spider gear to me.
Feb 21, 2011 | Frigidaire GLTF1670A Front Load Washer
When the machine goes into spin cycle there is excessive vibration as if something was loose in the drum. Other wise the machine cycles fine. Is there someway to check for bolts or nuts loose on the drum....
Move the drum around by hand and listen carefully. There should be no loose bits or rattling, if there are it is possible that something has slipped in between the drums. It sounds as if the drum bearing may be failing. Grip the inner drum and move it up and down at the front while feeling for play relative to the outer drum. i.e hold outer drum and lift inner drum relative to where you are holding. There should be virtually no play.
Jan 05, 2011 | Kenmore HE2 Plus Front Load Washer
Inside drum of front loader loose bearing in back is ok but drum must have bushing gone how can i change this bushing the drum looks like its sealed
If the inner drum moves or is loose the the inner drum needs to be replaced .At the same time you should replace the rear of the outer drum as this contains the seal and bearings.
Nov 04, 2010 | Kenmore 43142 Front Load Washer
I've changed the drive belt, but it seems that the...
If the drum being pushed forward makes the problem better, I would say your felt pads under the drum which the drum rides on are either worn down the metal or loose.You need to remove the front casing of your dryer and inspect these felt pads. If they are loose tighten them up and if they are worn they need to be replaced. When you have your dryer apart you may also want to try to move the rear of the drum to the left and to the right and see if the back of the drum is loose as this means your bearings are loose and may need replacement. To fix this problem however the top of your dryer will have to be removed to take the drum out (many times the top will tilt back on hinges) because the bearings are on the back of the drum.
May 12, 2010 | Dryers
Loose part in drum area
unplug machine go to botton remove large outlat hose9attached to the drum and pump u can then work inside through the hole
Mar 20, 2010 | GE WBVH6240F Front Load Washer
Stainless steel drum loose
A loose inner drum usually indicates a failed rear tub bearing. The only solution is to replace the rear half of the tub. (which contains the bearing).... You can check if the pulley nut has come loose by removing the rear panel. There is a large nut that retains the belt pulley to the shaft of the basket.
Jun 04, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore has loose drum
drum lose need more on that drum should move side to side all around if its not draining something blocking the pump if drum is lose its the basket drive block busted
Feb 28, 2008 | Washing Machines
Washing Machines Logo
357 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
