Question about RCA PROV712 Camcorder
RCA Proview PROV712 video camera Battery & Dew/Clog lights flash
My RCA Proview PROV712 video camera Battery & Dew/Clog lights flash in both battery (fairly new replacement battery) mode and with AC adapter. the lens works and displays an image correctly on the LCD screen, but it won't record or playback the tape.
Gryfox
  • 216 Answers
SOURCE: RCA prov712 battery will only last 5 minutes
Be sure to charge for AT LEAST 14 hours on the new battery, even if the charger light goes out - it's still trickle charging. It's normal for most camcorders to auto-shut off after 5 minutes, if it's not recording. But if your batt light comes on, the problem is probably with the battery.
Posted on Dec 20, 2006
robotek
  • 1512 Answers
SOURCE: RCA CC6262 Camcorder Problem:
Hi
Unfortunately, the camera may be beyond repair. The common complaint from camcorders of this vintage and older, is surface mount capacitors failing, not just a few, but many, all through the unit. It affected most makes and models. Meant that any camcorder 5-6 years old, may not be worth repair, as faults exist in many different places. Fix the display problem you have, to find autofocus problems, or poor performance. I suggest returning the battery to the store for a refund. Explain it did not do the job for you... and cut your losses. Sorry it has to be news like this, but is the best bet under the circumstances.
regards
robotek
Posted on Jul 06, 2008
SOURCE: Sharp Viewcam VL-E66U
I let it sit overnight and when I opened the door I nudged the part that holds the tape up. I got the tape out but I think it is still frozen. I will try a different tape and hope it still works. I'll post results.
Thanks
Kate
Posted on Sep 08, 2008
SOURCE: Can't find an audio vider cable for my RCA Prov712
I found it on-line but thank you for your reply. ANgie
Posted on May 05, 2009
SOURCE: I have a RCA cc6364, had it for years. I bought a
Does your camera work of a Power Adapter? If it does, then the battery is most likely at fault. If however it will not, then it will be the camera.
Posted on Feb 22, 2010
Batteries for rca cambio w101 v2
The tablet has a built-in rechargeable battery. The unit comes with an AC adapter (DC IN 5V) to recharge it via an electrical outlet in your home, or you my use a Micro-USB cable plugged into the port and plug the other end into the USB port on your PC/Mac.
If you're having issues with the battery, such that it may not have been used in a long and entered discharge mode. Connect the AC Adapter for several minutes to get it up to at least 5% before attempting to power on.
Even though the battery is a built-in rechargeable, it can be replaced if necessary, and fairly easily IF you take your time 10-15 minutes and have basic skills. A replacement battery for this unit sells for about $10 on ebay.
Jun 18, 2017 | RCA Televison & Video
Dew light
Dew is likely to form in the following circumstances: ?When moving the camcorder from a cold place to a warm place. ?When placing the camcorder in a cold room which is then heated rapidly. ?When moving the camcorder outdoors from an air conditioned room or car. ?When placing the camcorder in the direct path of air blowing from an air conditioner. ?When placing the camcorder in a humid room. Dew will gradually form on the head drum of your camcorder and make the video tape stick to the head. This causes damage both to the head and the tape. When dew forms, recording and playback may not function properly. When ?DEW? flashes, remove the cassette,leave the cassette compartment open,and wait for a few hours to allow the camcorder to acclimatise to the surrounding temperature. To use the camcorder again, turn on the power after waiting for a few hours. Be sure that ?DEW? has disappeared. Do not insert a cassette while ?DEW? is flashing; this may result in damage to the tape.
Aug 03, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
May 04, 2009 | RCA PROV712 Camcorder
Dew detected
Leave the camcorder turned off in a place with constant dry temperature with the door open. Take the battery off and wait a few hours like at least 3.
This should work unless it is really damp inside then it may take longer. This happens when the camera is moved from heat to cold or cold to hot temperature. Both tape and camera need to be climatized to prevent this from happening.
Oct 03, 2008 | Quasar VM-L459 Camcorder
Flashing lights
This sounds similar to a problem I had. I brought the camera in under warranty and the repair shop fixed it. They shop text is cryptic.
Problem: Camera light keeps flashing, not charge
Solution: Troubleshoot to intermittent switch block control, replace with new one, test OK.
Feb 17, 2008 | Sony Handycam DCR-HC20 Mini DV Digital...
CF-71 battery LED always flashing
hi, first try cleaning all the contacts of the battery and the laptop,let me know
Jan 04, 2008 | Panasonic Toughbook 71 Notebook
DEW indicator / battery
In your owners manual on page 52 you will find a list of authorized service centers. Give the one in your area a call. Give them the brand name and model number of the camcorder. Tell them you are having a problem with the dew warning coming on while using the camera with the battery. They should be able to help find a answer to this problem.You can also call the panasonic customer support telephone number at 1-800-211-7262 between the hours of 9am-7pm EST. Give them the brand name and model number of the camcorder and ask them for help with the problem of dew indicator coming on while in use with the battery. I hope this information helps you with your camcorder problem.
Nov 20, 2007 | Quasar VM-L450 Camcorder
Dec 19, 2006 | RCA PROV712 Camcorder
Video Cameras Logo
649 people viewed this question
Top RCA Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
