Question about York Exercise & Fitness
York t302 treadmill wont start
Hello, My York treadmill powers up but the display just flashes and beeps continuously. I am handy with a screwdriver and multimeter but don't know where to start looking. Any help would be most appreciated, thanks
3 Suggested Answers
SOURCE: york t101 treadmill ls error
York treadmill T101 will not run has a error L5
Posted on Feb 20, 2010
  • 773 Answers
SOURCE: I have a York z16
LS or L5 error is the speed sensor. Because it is such a vague code I can't just tell you exactly what's wrong with it. I can tell you what it may be.
If you are lucky it's just a fuse. If you have belt movement, it's likely that its just a fuse. If there is no belt movement, it can be a computer failure. the MCB will need replacing.
If you have belt movement and you check the fuse, and its not blown, then the speed sensor is no good and needs replacement.
In most cases its a fuse.
Good luck, hope this helps!
Posted on Oct 25, 2010
York T101, motor will not start, display is fine.
1) LUBE THE DECK BELT, IN ACCORDING WITH THE INSTRUCTION MANUAL.
2) lUBE THE ROLLERS BEARING
3) tEST THE INPUT VOLTAGE MOTOR, IF THERE ARE THE MOTOR NEED REPAIR.
4)tEST THE OUTPUT VOLTAGE BOARD, FOR INPUT VOLTAGE MOTOR, IF THERE ARE NOT THE BOARD IS FAULTY.
SEE THE BLOCK DIAGRAM ATTACHED.
God bless you
Jun 07, 2012 | York Exercise & Fitness
I have a treadmill york barbell max series 2, keeps displaying err in the speed window and wont start up at all, sometimes it will start working and then sometimes it wont and err comes up again
1) You have out of adjustment the sensor reed switch,see the schematic.by 1/8" or 3mms aprox.
2) With this you will fix it.
3) However if the problem persist, you must check if the display board is o.k or faulty.
4) Test the 5VDC for IC( Including EPROM, ROM,etc) Tight flexible cable for Display Board vs Lower Board(Main Controller Board).
5) Since the Lower Board send the Power Supply coming from the Transforme you must Test it, and then power supply for +5Vdc.
6) You must have Strong Conclusion if the problem is Upper Board or Lower Board(Main Controller Board) .
Finally The Lower Board Control 90% functions of the Treadmills.
Nov 23, 2011 | York Barbell Home Use Fold-Up Treadmill
Computer treadmill wont work
Causes:
1) Blown fuse or breaker check it.
2) VSD/MICROPROCESSOR(cOMPUTER)/EPROM/SRAM Failure
3) Check connectors loose to display board, or corroded contact from connector to display board.
4) Missing +12VDC to display board.check power supply +tansformer.
E.CUADRA
Oct 09, 2011 | York Barbell Home Use Fold-Up Treadmill
I have a York evolution tv treadmill model x8 which starts for about 3 seconds then stops with E7 on the display, I understand this is a safety key error code but the key is in place and if it's...
Definition: Incline motor calibration abnormality: 35~40 seconds after the down command was sent,
the calibration base signal was not received.
Check the calibration motor (mechanical +electrical)
Jul 11, 2011 | York Barbell Home Use Fold-Up Treadmill
York 2750 treadmill: How do I reset distance display? regards
Does anyone know where I can buy a replacement earlip pulse monitor for York 2750 treadmill?
Jun 27, 2011 | Health & Beauty
My York t302 threadmill motor starts to keep strange noise after some running. Motor has been changed once as well as whole threadmill. So this is my third motor and problem still exist. Here is the...
i just had a noise in my York T301 that sounds exactly the same as yours. It also came up with a E1 error code and stopped working. I pulled the motor hood off and noticed that the magnet in the drive pully had come dislodged. It was hitting the speed sensor near the belt. Glued magnet back in and all better. Hope this helps.
Oct 06, 2010 | York Barbell Home Use Fold-Up Treadmill
E1 not ERR1 error appears on the display of diamond t300 york fitness treadmill??
Your problem might be that a magnet has fallen off. Here's an illustrated guide that will make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Jul 04, 2010 | York Yankees Bedding MLB Comforter
York t101 treadmill ls error
May 11, 2009 | York Exercise & Fitness
York t500 treadmill model no:LQ6010 showing err07 when turned on
Error 7 is a Safety Key Error..
that's the red magnetic circular thingy on the console.
Simply secure the safety key in place and try it again
Jan 19, 2009 | York Barbell Home Use Fold-Up Treadmill
Exercise & Fitness Logo
41 people viewed this question
Top York Exercise & Fitness Experts
Electro Med Services...
Tom Chichester
ray gallant
Are you a York Exercise and Fitnes Expert? Answer questions, earn points and help others
