Question about Husqvarna 155bt Gas Backpack Leaf Blower
The blower stops running after about 20 minutes
Ariens 1336 Pro, the problem is that it will just stop dead. Engine runs strong, blower keeps discharging but the drive just stops. Wont go forward or reverse. After a little time it will take off.
what exactly is it and what are you doing . sounds like a lawn tractor with snow blower and tranny fluid is not being pumped thru because of too cold . Am I close ??
Dec 15, 2017 | Cars & Trucks
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 | Dryers
1993 chev g-20 van. Heater fan sometimes just quits, then a few minutes later comes on.
You'll need to know if the blower motor has power and ground when it stops running. Could be the blower motor, the resistor, or a wiring problem.
Feb 01, 2014 | Cars & Trucks
Blower motor
may be motor on way out ,,,,, the resistor for the system usually allows full blower power when set to top speed,,,,
Nov 22, 2013 | 2005 Ford Focus
Ac blower in mobile home starts then stops
e.o oddly i remember seeing an AC blower doing this outside of its system it seems to me the control box on the blower isnt really seeming to know what to do since its all controlled electrically and if its getting mixed inpulses then the control box itself can get confused on knowing what to do such as fan speed and controlling it to turn off and on....most likely the control box isnt working as it should and may need replacement or have an electrical guy check things out
Apr 16, 2017 | Heating & Cooling
ECHO PB-500T - Stopped running and added gas fuel mix. Quit running again with full tank and now flywheel is stuck and I can't pull to start it. What is the problem?
My $350 Echo PB-500T seized up. I almost cried.
The solution was to drain the fuel tank.
  • Refill fuel tank with an 2-cycle Oli/gas mixture.
  • 40:1 =3.2 oz to one-gallon gas, do not use Alcohol base gas.
  • Remove the spark plug.
  • Pour approximate 1/8 oz 2-cycle Oli into the spark plug hole.
  • Remove the pull cord assembly (4-bolts)
  • This reviled the crank shaft-Pull cord bracket
  • I use a large monkey wrench to turn the shaft (CW) Clock-wise.
  • Complete approximate 20 revolutions.
  • Reassemble, but don't install the spark plug yet.
  • Complete approximate 20 more revolutions
    by pulling the pull cord.
  • Use q-tips to swab the top of the piston, as much as possible.
  • Install the spark-plug and crank, it will smoke for amount 7-10 minutes
Jul 30, 2011 | Echo Gas Blower 162 MPH 450 CFM Blower...
Craftsman gas blower (leaf) stops working after a couple of minutes. It was working fine up to a couple weeks ago. Now I start it, it works for almost two minutes as slows down until it stops. Then I have...
It could be something as simple as adjusting the carburetor. (if you have the adjusting tool) otherwise it sounds like there may be some debris in the carburetor. After running for a little while, it blocks the fuel jet. Then when you shut it off, it falls back somewhere in the carburetor. I'd suggest cleaning the carburetor and draining the fuel out and putting new gas in.
Dec 15, 2017 | Craftsman 4 Cycle Blower/Vac
Toro gas leaf blower erratic engine performance
hi
change the sparkplug or seals.
bye
Oct 04, 2009 | Garden
Echo backpack blower stops after 20 minutes
Make sure the fuel tank cap inlet valve is working properly, this will allow a vapor lock if it is not. Then check the fuel line in tank to make sure the pickup filter is not hung up in tank thereby allowing the fuel to get below the pickup. Also check the fuel line for holes. You can also try toro.com customer care, manuals and parts, type in model no. then get owners manual and see if in troubleshooting section it list this problem.
Apr 04, 2009 | Echo Garden
Samsung Ac compressor stops after 20 minutes and fan keep running. Again after 10-15 minutes if ac is restarted the cooling happens for 20 minutes and compressor stops.
eventually,cycling process is doing done if the thermostat sense the configure temperayure set up it will trigger to stop your compressor motor as well as the blower fan,blower fan independenly to you compressor.if your thingking that your compressor is tripping off,check your operating current on one line using clamp ammeter and compare to the rated current that tag on
motor compressor body,if the current flow is higher than the rated current specified on compressor motor,well problem occured it will trip your compressor,because overload protector is becoming your thermostat.but if you got same current result it was cycling process.If tripping off maybe air is present in your system call qualified ac tech, to purge out air in system.
Mar 15, 2009 | Samsung AW0693L Air Conditioner
Husqvarna 155bt Gas Backpack Leaf Blower Logo
134 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
