Question about Coleman Powermate Portable Generator PM0435003
I have colman powermate 10 hp model#196412 type 1180-E2 ser# 990203YD where can I find a manual it is running horribly
5 Suggested Answers
CarlGehrke
  • 169 Answers
SOURCE: powermate 6250 no spark
Hi Mark,
The engines used on the Powermates have a low oil shutdown system that can be troublesome. Try this:
1 - Make sure there is enough oil in the crankcase. The oli level needs to be all the way up to the bottom of the threads in the oil fill hole.
2 - Still no spark? Replace the spark plug with a new one (properly gapped), then spray something like brake cleaner into the carb. Pull the rope and see if you hear any detonations from the engine. If the engine tries to start but won't you need to look at the fuel system, then the ignition.
3 - If you proved there isn't any spark happening, look under the plastic cover where the kill switch is located. You'll find a small metal box with wires coming out of it. Find the wire that goes from the box to the kill switch and disconnect it at the switch. Mark things as needed so that you'll remember where to put them back. Give the rope a gentle pull and see if we have a working ignition, if it does have spark there is something wrong in the low oil shutdown mechanism.
4 - If you've convinced yourself that the low oil shutdown is misbehaving try changing this oil and flushing out the crankcase. Look for any evidence of debris that would have made the oil level float bind. As a final test reconnect the wire we took off the switch and disconnect the one that goes from the module to the oil sensor on the side of the engine, if you don't get a spark with the sonsor disconnected you probably have a bad module.
5 - If we didn't get ignition with the low oil shutdown disconnected from the kill switch, reconnect the wire we took off and then disconnect the (usually black) wire that leads down inside the engine. This is the kill wire for the ignition module. If you get the engine to start with this wore disconnected you may have a shorted kill switch, test it with an ohm meter.
6 - if there still isn't a spark with the kill wire disconnected you may have a bad ignition module. You have to take off the carb, then the blower housing to get to it. Check that the kill wire isn't shorted to the block anywhere, and that the module has the proper gap and orientation before replacing it, The modules say "cyl side" on the side that should face into the engine. A regular business card or a playing card ought to just fit between the magnet on the flywheel and the module, too loose would cause a loss of ignition. You get extra points if you use a feeler guage to set the gap to 0.010 inches.
7 - Ignition modules are available from a bunch of different places, your local Briggs supplier will want to know the model, type, and code numbers located on the side of the valve cover in order to be sure which parts you need,
Rate me if you liked the answer,
Carl
Posted on Dec 01, 2008
CarlGehrke
  • 169 Answers
SOURCE: how do you seperate the engine from generator.
Assuming that you intend to someday put it back together, do this:
1 - Make it safe by taking the wire off the spark plug and getting all of the gas out of the tank.
2 - Remove the stator part of the generator. There are 4 long bolts with 7/16 inch heads that hold it onto the adapter plate at the engine end of things and a 1/2 incher holding the end away from the engine down on the frame. Some generators have more than 1 frame mount, these are harder to get out, I use a channel lock pliers to hold the rubber mount and a socket to remove the nylock nut. When it's all loose, pull the molex plug out of the distribution panel (where the outlets are) and then gently slip the stator off of the rotor. Try not to break the windings.
3 - Support the engine/rotor assembly by placing a block of wood, stone, or metal under the rear of the engine.
4 - Take the long bolt out of the end of the rotor. Use a 6 point socket for this so as not to mess up the bolt head. This is also much easier with an air ratchet. The rotor shaft has an "innie" cone shape milled into it and the engine has a corresponding "outie" bevel that fits inside the rotor shaft. This is called a tapered shaft mounting. You can get the rotor off of the engine shaft one of 2 ways...
The "official" method:
Get the kit from Briggs and Stratton, tap threads into the inner surface of the bolt hole, insert the appropriate threaded rod and torque it to pull the rotor free. This only takes one tech.
The "redneck" metohd:
You need a friend you trust to swing a hammer, a fairly heavy hammer (I use an 8 lb sledge), and a chunk of 4 X 4 wood long enough to act as a punch when placed against the rotor laminations. Turn the rotor so that the laminations are horizontal. Put the 4 X 4 against them as far away from the engine as you can without breaking the plastic parts of the rotor. While holding the 4 X 4 tightly against the rotor, have the other guy whack the other end of the 4 X 4 sharply and with a good amount of force. Then rotate the rotor 180 degrees and whack the heck out of the other side. Repeat this process until the rotor pops off of the enigne shaft.
My old shop mate and I got good enough at this to take the rotor off in 2 whacks every time.
Regards,
Carl
Posted on Jan 07, 2009
  • 3 Answers
SOURCE: Does anyone know where I can download an owners
Try this link. The model number will be on your generator.
http://www.powermate.com/productmanuals.php?cat_id=3
Posted on Oct 13, 2009
  • 30 Answers
SOURCE: HOW DO I USE THE
It is a twist-lock plug, just push it in and turn to the right. Link to the manual:= http://www.powermate.com/pdfs/2007/11/17/manual_pm0435003.pdf
Posted on Jun 13, 2011
I cannot locate the owners manual for my Coleman PowerMate 6250 generator 10 hp? Any place I can find this online quickly thank you
Most PowerMate manuals are available here: http://www.powermate.com/productmanuals.php?cat_id=3 . However, describing it as the PowerMate 6250 10 HP generator is insufficient to find the correct manual. The Coleman PowerMate line has several models with 10 HP engines and a 6250 Starting Watt (5000 W running) capacity.
These include the Powermate PM0435005; the direct link for this manual is http://www.powermate.com/pdfs/2011/12/29/pm0435005.02.pdf .
Please add a comment with the actual model number of your generator if you need further assistance with finding the correct manual for your generator.
I hope this helps.
Sep 05, 2017 | Coleman Electrical Supplies
How to troubleshoot a gasoline powered generator
What might you be trouble shooting may I ask. Or go find your owners manual online at Colman.com.
Mar 15, 2016 | Coleman Powermate Powermate 5000W...
Manual for model 185432
Hi Keith, I have searched Coleman's Powermate website and I cannot find your model, it doesn't even come up on their search engine. Google searches for just the number 185432 will bring up information for a 9 HP Vanguard engine.If That helps, here is a link from Partstree.com http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=185432-0271-E2 If that doesn't help I would call Coleman's customer service and ask them if they would mail you one. It could also be possible that they are using a different number on their Powermate website.
Good luck, Michael Burke.
Dec 10, 2011 | Coleman Powermate Powermate 5000W...
10 hp briggs and stration
A friend gave me a Coleman powermate generator model # pmo545208. I discovered that it had no spark , well it still does not due to lack of time but any way i have been looking for a owners manual online for about 3 to 4 weeks and from what i see so are a lot of other people just like you Sir and myself well may I say to you and all else who are seeking the same as i was LOOK YE NO MORE.simply call the company that took over POWERMATE when it went bankrupt some years ago but kept thier name and phone number.That company is PRAMAC. the phone number is 1-800-445-1805 i think they are located in the eastern part of the US. but anyway i had an owners manual,a operators manual and a operating and maintenance manual in just seconds.You will need a PDF reader or unlocker to view them , may i suggest opening before burning to a disc or printing .Anyway have a nice day and HAPPY NEW YEAR JAMES NEWMAN
Dec 06, 2011 | Coleman Powermate Powermate 5000W...
HOW DO I USE THE 240 CORD THAT CAME WITH MY 5000W. COLMAN POWERMATE
Jun 13, 2011 | Coleman Powermate Portable Generator...
Need a manual for a Coleman Powermate air compressor Model #VP0200608 Elec.
I'm looking for a owners manual for a colman powermate air compeser modle cl0502710
Apr 18, 2009 | Air Tools & Compressors
Oil to gas ratio for Coleman Powermate 5000?
my powermate is straight gas.......be careful. go to colman web site and download service manual. mike
Nov 18, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Portable Generator PM0435003 Logo
114 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
