Question about Bosch Axxis WFL 2060 Front Load Washer
Machine leaks through the filter
The water is coming out through the filter during the wash. The filter is locateed at the right bottom of the fron of the machine.
    New Friend:
Has it g a filter
Posted on Apr 22, 2013
  • 909 Answers
REMOVE WATER THEN UNSCREW FILTER AND PULL OUT.CHECK THE O RING THEN TAKE NOTE OF CORRECT POSITION WHEN REINSTALLING IT.THERE ARE SOMETIMES GROOVES THAT THE FILTER HAS TO SLIDE INTO. MAKE SURE IT IS NOT CROSS THREADED. HOPE IT HELPS TERENCE
Posted on Jul 11, 2007
    President:
  • 1,462 Answers
Possibly not done up tight enough or needs a filter seal - a cheap part. occasionally the filter housing cracks but rarely
Posted on May 19, 2007
Water leaks from machine during use. Have checked filter on right near base is clear.
Sounds like the water pump is going bad or a hose is leaking. Replace the water pump which in most cases are not, too costly. Most water pumps can be replaced from the bottom of the machine. If you can not find the part # on the water pump, look it up by the model # of the machine.
Aug 22, 2011 | Washing Machines
WATER IS COMING OUT FROM THE BOTTOM OF THE WASHING MACHINE ONCE THE WASHING HAS STOPPED, IT DOES NOT LEAK DURING CYCLE AND IT SPINS AND DRAINS FINE..
i would inspect both the hoses on the pump
no leak during cycle is explained because water is moving through them to fast to leak when the machine settles it starts to leak
Oct 15, 2009 | Hotpoint Aquarius WD63 Front Load...
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
Bosch washing machine leaks at right bottom
The part that you removed, was the pump filter, the pump is located behind the filter, possibly, the pump itself is leaking, or the filter cover is not fastened in tight enough, pr the filter seal is defective, if after tightening, it still leaks, suggest you replace the pump.
Please rate my solution.
Thanks.
May 26, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
ULTIMATE CARE II WASHER - MODEL LSQB520JQ0 IS LEAKING
you can tip this unit back, the bottom is open and then oyull be able to see where the leak is coming from, any part wharehouse(online stores as well) will stock the pump if needed.. most common cause of leaking pump is fron center shaft youll see the water line
Mar 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidare front load washing macine leaks water
Sounds like the dispenser is leaking somehow, there is no filter that would cause it to leak. Remove lid of washer by screws on back lip and inspect during fill to see where leak is.
Jan 20, 2008 | Washing Machines
Bosch Maxx WFL2860 filter leaking
unplug the power before you do something leak first check and then clean filter, replace some hose available in appliance center.
Jan 03, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing machine is leaking from the bottom
try looking at the tubes where the filter is. remove the front cover at the bottom and check the filter. worth a shot
Nov 13, 2007 | Samsung WF203ANW Front Load Washer
Water leaking from bottom front panel
Plug off the wall. Open the back of the machine to take a good look at the tube coming out from the bottom of the tub, open the front door to see if the door washer is loose somewhere. You could even try to reach out thru the back to locate any loose rubber gasket, the door gasket that is...... Possible you could take out the top of the machine to see if any of the normal 3 tubes entering your dispenser has come loose.....
Sep 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Bosch Axxis WFL 2060 Front Load Washer Logo
820 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
