Question about Microwave Ovens
KITCHEN AID KHMS 105 WWH
LOUD POP AND FLASH AND NO HEAT
3 Suggested Answers
hiltonjug
  • 612 Answers
SOURCE: kitchen aid microwave model# khms 147 hss-1 runs but doesnt heat
Your problem is your mag tube (Magnatron) you can go to www.partsselect.com and your part number is PS2352604. Their price is $123.44. I work on micro waves myself and have found that if one isn't a built in over the stove like yours, they are not worth repairing because you can buy one cheaper. If this unit is not real old and you can replace this parts yourself it might be worth fixing bit if you are going to have it repaired, it might be cheaper to replace it. Good luck.
P.S. If you open this unit up. Make sure you bleed the capacitor off, this is one that will knock the _ _ _ out of you if you ground it by touching it. Bleed it by using screw driver to short capacitor to ground or case.
Please rate this solution
Posted on Sep 03, 2009
  • 15 Answers
SOURCE: lightbulb burned out for microwave model # KHMS
Most home improvement stores and even some Walmarts/Chain grocery stores/Ace Hardware carry replacements. You will need to remove the cover from the microwave oven on most models unless your bulb is inside a protective cover inside the actual oven. Take the bulb with you when you go to make certain of a proper match. Be certain to unplug the oven if you need to remove the cover in any case.
Posted on Oct 13, 2009
Kitchen Aid microwave over will not heat
Common cause of this problem is transformer fuse blown.check the fuse.if fuse is ok, then replace magnetron
Mar 02, 2015 | KitchenAid Microwave Ovens
Kitchen Aid microwave KHMS105EWH-0: I started to heat a cup of coffee, it momentarily interrupted power to the kitchen, fluorescent lamps went out, then slowly came back on. More below.
Because of the loud snap you are hearing, my guess is you have something shorting out in the high voltage section of the microwave. I'm surprised it is not blowing the internal microwave fuse yet. Average repair cost depending of what part it going bad is approximately $150 to $200. Considering the age of your micro my suggestion is put the money towards a new one.
Mar 01, 2015 | In Microwave Ovens
What is the wattage of a Kitchen Aid microwave model # kcms135h?
1200 Watts. It should be plugged into its own dedicated 20-amp circuit. It is shares a circuit with a refrigerator, coffee maker, or toaster, it will pop your circuit breaker.
Oct 20, 2014 | Microwave Ovens
I have a kitchen aid khms 1850 microwave. When setting idle it continues to make a small rumbling sound and after 30 minutes it smells like something is overheated. I'll unplug it after a day and will...
That is the sound of the magnetron failing. The large capacitor inside may also be drying up and causing the sound. When the capacitor dries up further it will start blowing fuses.
Nov 24, 2013 | Microwave Ovens
I have kitchen aid microwave modelkcms185jss starts runs fine but does not heat food at all.
Does not heat food means a problem on magnetron tube and fuse blown in high voltage area. Have it replaced and it will heat again.
I hope I answer your problem.
Mar 30, 2011 | KitchenAid KCMS185J Microwave Oven
Microwave makes a loud sound and then won't heat. About 3 years old.
It sounds like a failing magnetron. Sometimes they can be intermittent before they finally fail for good.
Chances are your oven has a 5-10 year warranty on the magnetron.
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
To allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and your detailed symptoms.
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
Dec 12, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Lightbulb burned out for microwave model # KHMS 1850SSS-0 Kitchen Aid Where can I purchase a replacement? Thank you, Carrie
Oct 13, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Kitchen aid microwave model# khms 147 hss-1 runs but doesnt heat
Sep 03, 2009 | KitchenAid Microwave Ovens
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
Oven dont warm food
Kitchenaid KHMS 147 HBL-1 unit does not heat. All other functions are working and it worked this morning but as of this evening it will not heat. I was thinking the fuse but would like some advice
Oct 09, 2008 | GE Microwave Ovens
Microwave Ovens Logo
48 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
