Question about GE JTP15 Electric Single Oven
Measurements for wall oven jtp15wow1ww
Size
2 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: My GE wall oven model
Hi
Thanks for using FixYa. It seems that you interrupted the self clean cycle in between or you ran the self cleaning cycle after a long time, as these kind of issues are usually caused due to these reasons. The issue is with the latch assembly going bad and should be replaced. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 13, 2010
Whirlpool double wall oven RBD306PD26 size specifications
From what I could get from the service manual, the oven is a standard 30 inch width. The best thing to do is get a yard stick and measure length, width, and height. Take pix with a phone so you have references to show a salesperson or a tradesman if you are buying new or having upgrades done.
Sep 02, 2015 | Whirlpool Ovens
Will a GE built in oven JT3000DF fit in the space that has a Kenmoore build oven in that space at this time 9114105559 part number
Simple. Measurements. Unless i'm missing something here.
Take present oven detailed measurement, compare it to the newer oven's detailed measurement.
Feb 03, 2015 | GE 30" Built-In Single Electric Wall Oven...
I have a GE wall oven, model # JKP07G004B0 and I would like to replace it. I need to know which new one will fit the space.
Since it is so old the diminsions are no longer available online and the only way to get the size is pull it out 4-6 inches and measure height,width and depth of the cut out portion of the cabinet it fits into
GENE
Jul 30, 2011 | GE Ovens
Hi We need to replace wall oven model 755T what size wound it be so we can buy new one Thanks Tracy
The best way to determine the size wall oven that will fit is to partially pull out the existing one and measure the cut out of the cabinet it will fit into
Jul 26, 2011 | Fisher and Paykel AeroTech OS302 Electric...
How do i measure my oven for a new one?
By measuring from top to bottom and side to side. (This is with the old oven out of the wall and you or measuring the hole that it came out of.)
Mar 29, 2011 | Whirlpool Ovens
I have a Kenmore smooth cooktop electric range. It is about 3 years old. Recently i used the self clean function, and since then I can't get the oven door to unlock and I'm getting a F5 code on the read...
Press the "Off/Clear' button to cancel anything on the display, and reset the oven. This is a soft reset and will simply get you out of any program you have started. If the problem still persist,
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the oven back into the wall power supply to reset any anomalies with the oven memory.
Mar 02, 2011 | Kenmore Ovens
Oven temp does not remain constant. changes + /- 50 degrees.
Sounds like either an intermittent temperature sensor or its wiring, OR a problem with the electronic control.
We repair a lot of controllers with this sort of symptom.
Best Regards,
Bruce
www.fixyourboard.com
Oct 14, 2009 | GE 24" Built-In Single Gas Wall Oven
Our Frigidaire 24 in wall oven won't light. The igniter glows but there appears to not be any gas present.
The ignitor is weak and needs to be replaced. You can not tell by looking at it. You have to measure the amp draw through the ignitor.
Sep 01, 2009 | Frigidaire 24" Single Gas Wall Oven with...
Replacement for built in oven/microwave
Hello tippett_631
Welcome to fixya,
You said, ,
22 years ago you built the house you are currently living in. The above oven/microwave oven was built in. You are interested in replacing this unit with a new unit but it must be the same size. ? by the way i You would be happy with a double oven versus the microwave/oven duo. You have measured across the front of the unit and it only measures 26" across. Any assistance you could give us would be greatly appreciated.
I can help you!
The front is 26 inches.
And how high is it from the top to bottom?
Also when I sell a wall oven I always send out the installer to check the hole or cutout size.
Most of the time no wall oven fits with out at least one cut!
Do you have any room to cut a little on all sides?
What is your model number now. And what color do you want now??
I will send you some GE wall oven models and sizes so you can check your self if it will fit. usually they have to cut at least one side to fit it in the old hole!
Sep 25, 2008 | GE Ovens
GE JTP15 Electric Single Oven Logo
153 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
