Question about Nikon Coolpix 4500 Digital Camera
Noisy camera When I turn the camera on it makes a clicking noise,then an hour glass shows in the view lens shortly after that the message says system error.Whats going on here?
  • Anonymous Nov 06, 2007
    We have exactly the same problem. The camera makes a wheezing sound, an hour glass appears in the screen then reads system error. Possible to fix or is it too costly and we need a new camera? Thanks.
  • jescuh Jun 06, 2008
I guess you will have either given up by now or got the camera repaired by Nikon or so. But in case somebody else has the same problem (like I had), here's my solution.
Same as wilding2004 and ruggb described, it is a problem with the motor can't adjust the zoom of the lens because it is blocked.
To remove this problem, it is likely that you will have to open the left part of the camera body where the lens is located. So if you don't feel confident in that, send it in - but this will cost at least $50 - $300, which is a lot taking into account the age of the camera and the price you'll pay for the same model e.g. on eBay.
To open the body, you have to unscrew many very small PH screws (I used a PH 0 x 60 screw driver) and some of them are not easy to find: - There are six screws on the left body facing towards the right part of the body which contains the monitor, buttons, battery and so on. You can only see and unscrew them when the camera is tilted by +-90°. - There is one screw at the front holding the cover for the protective glass of the lens and viewfinder. Probably you won't have to remove it, but I did and it didn't do great harm :-) - There are two screws hidden below the Coolpix label made of plastic on the left. This is glued onto the body, so there is no other way to remove it than pulling it off, probably using some small screwdriver to loosen it in the beginning.
After removing all these screws, you'll be able to separate the upper and lower cover of the left half of the body. Then you will have to further remove interior parts or at least loosen them enough to free the zoom again.
A little bit of a warning: Since this camera, like any other compact camera has a built-in flash, there is a capacitor on the left side of the camera to supply it with power. And even if you have powered off the camera and removed the battery, it will still be loaded. So be careful not to touch it - could get painful.
Hope it helps someone, a coolpix 990/4500 fan.
Posted on Feb 20, 2009
  • 64 Answers
I HAVE SOLVED THIS PROBLEM!!
wilding2004's solution won't work with a 4500 but you must take it apart.
The problem is that the viewfinder adjuster is connected to the lens adjuster and somehow (this is the mystery) it comes off and eventually jams the lens mechanism. Tapping the camera on the back of the lens assy while it is making noise m i g h t knock this piece loose, but it is not fixed and for sure will jam again.
I have written instructions but it is not for the faint of heart.
You need to be a little mechanically inclined and know how to unsolder and solder two small wires.
I will email the doc to you for a small Paypal donation.
r u g g b a t n c d o t r r d o t c o m
Posted on Sep 02, 2008
    Problem Solver:
  • 11 Answers
I just fixed this problem with my Nikon 4300. I removed the backplate and separated the electronics from the case by pulling all the ribbon cables. I did a visual inspection for damage, (burns on pcb etc). Then I used a very small screwdriver to work the motor axel for the lens. This freed up the lens which I tested by connecting to power. Then I re-attached the ribbons and put the case back together. Everything works again. You MUST make sure you're free of static when touching the internal pcb.
Posted on Aug 03, 2008
    Genius:
  • 2,985 Answers
Nikon Technical Support Team can advise you re this. If it is a new[ish] camera it may be replaced If not then it is time to buy the next one.
Posted on Jun 12, 2007
SOURCE:
When I turn my camera on, the lens comes in and out while making a weird sound... It does this for a couple of seconds then states on the display to turn the camera off then on again. It will still let...
I'm sorry that the lens of the Camera is not working and the Camera is displaying "Turn off and ON" message. Please click hear to view the information about the issue. Please click on the sub link on the page to get the instructions to perform the power resetting. If the issue persists after Power resetting, service is required.
Please click hear to locate your nearest Service Facility for the Camera.
Thanks for understanding. Please let me know if you require any clarifications or additional help.
Apr 30, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
After my kids dropped camera on carpet (it was on but lens was not out, they were viewing pictures). The lens will not move, it's stuck and makes grinding noise like it wants to move in and out. After it...
hi dear alexanderesma, your lens have the pin roller's out of cylinder helicoid,some case maybe repaired, otherwise change of lens unit become necessary.
Please send to Nikon service.
Regards
Mar 11, 2011 | Nikon COOLPIX P90 Digital Camera
My camera lens won't go back in and is making weird noises.
Since you said it makes noise when you turn it on, the gear system controlling the lens might be faulty. have it checked.
Sep 16, 2009 | Panasonic Lumix DMC-FS3 Digital Camera
When I turn the camera on it makes a few noises then shut off
i called the company (1-888-553-4448) olympusamerica.com and they told me to send it in and they will repair it for 70.95 plus a 6months warranty because i cant find my reciept. they also said what eva is wrong with it they will be able to repair it, but if u have ur warranty u can send it to them it wont cost u anything because u have ur reciept.
Nov 11, 2008 | Olympus FE-220 Digital Camera
Camera shuts off lens error
"lens error" will only be fixed by sending into repairs. 800-706-2534 and keep choosing option 2. Tell them you have a lens error and they will tell you where to send it.
Mar 29, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
My Samsung S850 Wont Turn On
cameras beep when it has a problem. most likely the lens get stuck or lens gear failed or motor drive gear to lens, or allot of other problems like it doesnt reconize the optical sensor.
look online for the beep codes and problems.
ty
hope I helped
Jan 27, 2008 | Samsung S850 Digital Camera
Lens error
This is the lens focus gears. They are either knocked out of alignment, or debris has jammed them. The good news is it can be fixed....Casio most likely won't help. Hint...google my user name.
Dec 24, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Shutter release problem
Try removing the lens and the battery and leaving it for 24 hours - this can happen when the gremlins get into the works !
Jul 24, 2017 | Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
Nikon Coolpix 4500 Digital Camera Logo
242 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
