Question about Kitchen Ranges
My Frigidare stove Model FGFL67DBD will not light the oven. A display of "F31" comes up. What's the deal. My name is Brenda.
    Scholar:
  • 31 Answers
F3 is the oven temperature sensor, F31 may be a similar code. If you are comfortable with your own repairs, you can remove the panel covering the controls and check the connection to the oven temperature sensor. Remove power to the over before removing any panel. Once the panel is off, make sure all connectors are firmly seated, connect and disconnect the plugs ensure a good connection. If this does not resolve the issue, try Appliance Parts Pros to order a replacement sensor. The wiring diagram that shows what color wires are the temperature sensor is usually secured to the back of the range, inside the storage drawer, or inside one of the service panels.
Otherwise, you will need to call a tech to repair the problem.
Posted on Jan 07, 2009
Oven will not come on error message F31 appears
the oven needs two things 1, gas or electricity plus 2, thermocouple.
If gas try lighting manually by removing oven bottom plate of oven when possible. That puts everything out in the open. If it does not open that way go to the bottom broiler opening and light manually.
this will tell you where the problem is.
Electric oven, go to fuse box and shut off supply line them turn back o n. This is easiest fix and resets the stove. On electric stove there may be an interlock that shuts oven off when the door is open.
Hope this gets you started!!!
Apr 04, 2016 | Kitchen Ranges
Oven wont start, shows F31 error on display
What is the complete model number of the unit?
Dec 04, 2012 | Washing Machines
I have a frigidare electric stove. The oven got
Hi
Thanks for using FixYa. Error code F1 means a bad Electronic Range control (ERC) and to resolve this issue you’ll have to replace the Electronic range control (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 26, 2010 | Frigidare GLEC30S8C 31 in. Electric...
Power surge fried Frigidare FEB24S2ASB
The electronic oven control has gone bad. The repair is a lot less expensive than the replacement of the whole stove. Part number is 903091-9051 at about 165.00 retail. You can fix rather than replace whole stove. Hope this helps.
Mar 04, 2010 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
Frigidare range glgf376dsm display not working
That's common for the burners to work since they & ignightors have nothing to do with the control board. The oven light is also run by the control board. Before replacing the control board, make sure you have both phases of the power coming in. One 1/2 of the 220 operates the burners and the other phase is the power to the controller. The controller then put both phases on the heating elements. There should be a tech sheet and schematic on the back of the stove or under the hood where the controller is. Good luck
Jan 22, 2009 | Frigidaire GLGF376 Gas Kitchen Range
Oven model FGF316ASA OVEN WILL NOT IGNITE
change the igniter its just weak
cost around $65 for universal fit
takes 15min to change
Nov 17, 2008 | Frigidare FGB24S5DC Gas Single Oven
Kitchen Ranges Logo
201 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
