Question about Sunpentown SPT SU-2550P Ultrasonic Humidifier with Fragrance Diffuser, Cool Mist, Super Quiet and comes with Night Light, Pink color, Covers up to 450 sq ft
Why is my SPT su-2550v humidifier leaking?
Leaking out the sides when I turn the tank over and place onto the base. It appears to fit correctly and doesn't move, but all of the water immediately leaks out of the sides. Why is it doing this and how do I fix it?
Water leaking from tank cap HM495
is the rubber seal in place on the cap or did you lose it could be a small crack where the threads are look for both , good luck
Mar 07, 2015 | Humidifiers
Why does the crane elephant humidifier leak
The humidifier has just started leaking from underneath the trunk part and drips down the front side and pools quite a bit underneath the humidifier causing quite a wet mess. This just started after I ordered a replacement water tank. Any suggestions?
Feb 15, 2013 | Crane Elephant EE-3186 1 Gallon Humidifier
The water from my bionaire humidifier keeps leaking well not leaking pouring out of the humidifier base. I checked and no there is no cracks on the water tank and it does not leak from the tank itself. But...
try to check the insulation of your drain pan because of your water came from your unit is cold that create moist on the tank when hit by hot air from sorrounding air apply insulation on the tank.
Mar 27, 2011 | Bionaire Humidifiers
How do I change the filter on Sunbeam Model SCM 2412 humidifier?
Turn the unit off and disconnect from the electrical
outlet.
2. Remove the tank from the housing.
3. Unlock the housing from the base by turning the lock
knob to the unlocked position.
4. Lift the housing straight up and place to the side.
5. Unlock the wick holder from the base by turning the lock
6. Remove the wicks from the wick holder.
7. Follow the weekly cleaning instructions.
8. Insert new filters into the wick holder and lock the wick
holder back onto the base.
9. Replace the housing onto the base and lock it into place.
10. Fill the tank and place back into housing.
11. Repeat Operating Instructions.
It will take about 30 minutes for the humidifier to reach
Nov 03, 2010 | Sunbeam (0013871361) Humidifier
Our HCM-640bw Honeywell humidifier will leak water onto the floor. If I fill the tank and let it sit without turning it on, no leaking. When it runs for about two hours it leaks bad. Any ideas on how to...
Found a hairline crack in the water canister. Had to locate by filling the canister and waiting for a couple of minutes for water droplets to form outside the canister. This ever so slight crack allowed air to enter the chamber and made changes to water dispensing rate which overfilled the resevoir over time ( hours). The cracks were not visible under 10X magnification without the water droplets.
Jan 18, 2010 | Honeywell QuietCare HCM-630 Humidifier
No instruction manual
FILLING THE WATER TANKS
1. Before filling the water tanks, push the POWER switch to the “OFF” position and
unplug unit. Refer to cleaning instructions.
2. Remove water tanks from base, turn each tank upside down and remove tank cap
by turning counterclockwise. Fill tank with clean cold tap water.
Replace the tank cap by turning clockwise. Tighten firmly.
3. Carefully pick up tank, since it will be heavy when full, and slippery if wet.
4. Place water tanks on base. Make sure tanks are properly placed, otherwise, the
humidifier will not work correctly.
Feb 11, 2009 | Slant Fin Cool Mist GF-220 Humidifier
Holmes HM4600 Humidifier LEAKING - - HELP
well since you just purchased this item, you should be able to return it for exchange, and it should still be under warranty, but if thats not doable, then it sounds to me like its a O-ring that is bad if the tanks are removable, best bet though is to exchange it, look at your home owners paperwork, to see about the warranty, more than likely your covered, hope that helped,
mr.grzz
Jan 20, 2009 | Holmes Products HM4600-U 11 Gallon...
LEAKS
Try to just fill the tank with water and set it upright on a table. If it leaks, the tank is cracked and needs to be replaced. Order one at kaz.com (search using model#). I have had this tank leak if the special cap is not sitting properly on the base. Make sure that the steam tower is properly locked in place before you place the water tank in the reservoir. The cap on the tank has a spring release that has to be correctly lined up so it only releases water when the water level in the reservoir drops.
May 08, 2008 | Vicks Warm Mist V745A 1 Gallon Humidifier
Air innovation humidifier KS30U-06C leaking
check the o-ring seal in the bottom , they like to get crossed up when you pull the tank out to refill. a little vaseline will help.
Mar 30, 2008 | Heating & Cooling
Humidifier leaks
My Air-O-Swiss U7142 has a leak from the very bottom. I found that as long as the water flows on to the "pan" that evaporizes the water, the water will come out from the bottom. Does anybody know how to fix this?
Jan 18, 2006 | Honeywell HCM530 Humidifier
Sunpentown SPT SU-2550P Ultrasonic Humidifier with Fragrance Diffuser, Cool Mist, Super Quiet and comes with Night Light, Pink color, Covers up to 450 sq ft Logo
Top Sunpentown Electrical Supplies Experts
John Trevino
lloyd cole
rlev_7
Level 1 Expert
Are you a Sunpentown Electrical Supply Expert? Answer questions, earn points and help others
