Question about Proform Exercise & Fitness
Why would my belt on the Proform 730 si begin to run backwards? Does anyone know the fix for this issue?
  • Proform Master
  • 6,694 Answers
If it was running in the proper direction before suddenly changing the direction then the motor control board is faulty. If it was happened after some service inside then the connection of the motor is reversed unknowingly. If so reverse the connection of the motor. As its a DC motor it will change the direction when the applied DC voltage reversed.
Ajin
Posted on Nov 04, 2012
5 Suggested Answers
  • 16 Answers
SOURCE: treadmill powers up begins to turn belt then shuts down
Have you tried to calibrate the speed. If not you might want to try it and see if it will help you with your issue.
Posted on Apr 14, 2009
maxtreadmill
  • 832 Answers
SOURCE: Speed indicator and belt problem
Under the motor hood by the front their is usually a speed sensor either not working or not adjust close to pulley where magnet is locate in , when it passes by the sensor it should read it.
Posted on Feb 28, 2010
maxtreadmill
  • 832 Answers
SOURCE: my treadmill Proform caliber walk... belts keeps
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in2_bing.gif and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes
Posted on May 16, 2010
  • 42 Answers
SOURCE: My Proform 730 worked great
hi, do you have the instruction booklet if so check if your treadmill uses oil. alot of treadmills use oil just like a car. and if it dosent get some wd40 spray and with the power off give the motor a spray and the rollers. the same thing happened to me and i sprayed the motor every moving part i could see. then i left the treadmill on without standing on it for half an hour and its been working better than before. please note wd40 spray can smell abit so open the windows. hope i have helped!
Posted on Nov 11, 2010
Belt slips while in use
Try adjusting the tension on the running belt. This video is the rear roller replacement on a Life Fitness 95TI, but includes the belt adjustment. This is a different machine than yours, but it is the same concept.
Mar 31, 2014 | Proform Walking Belt For The 375 Si...
Display working no motor running proform 200
RUN THE SOFTWARE CALIBRATION FOR EASY DIAGNOSTIC, TROUBLESHOOTING, AND FIX IT.
God bless you
Sep 21, 2012 | Proform 730 Folding Treadmill Model...
When i step on belt it stops moving
do the wheels lock up too that push the belt? if the wheels still spin than the belt might be too loose if that is the case look for an adjustment spot for the belt.
Jun 05, 2012 | Proform 730 Folding Treadmill Model...
The breaker keeps tripping halffway through my workout on my proform 730 cs. why?
see my personall TIPS for to see the schematic.
2) Try to run the software calibration for diagnose and troubleshooting and fix it.
3) The c. breaker can indicate the motor, trafo, capacitor, or board is hot and trip the breaker.
sincerely. God bless you
Apr 28, 2012 | Proform 730 Folding Treadmill Model...
I need a wiring diagram for a pro form 730 treadmill
There are many different kinds of Proform 730 models. Please search for or find your specific Proform model here and look at the parts list for the accurate wiring diagram for your model.
Oct 20, 2011 | Proform 730 Folding Treadmill Model...
On my Sears ProForm 730 treadmill, I cannot make the belt move to the right (it is rubbing on the left side) by turning the left-side back belt screw clockwise (in any amount). The belt is walking back...
The belt does not need to be replaced more than likely. The problem is probably because that adjustment bolt is stripped out causing it loosen and keeping it over on that side. ProForm sells star washers that help them stay steady and not slip out. I would call them and ask for a couple of star washers and a new adjustment bolt for that left side.
Aug 16, 2010 | Proform 730 Folding Treadmill Model...
My pro form 730 runs then its stops after about 30 mins
If you have not lubricated the deck I suggest you doing so you may purchase the lube @ Gymparts.com Part # TM001
May 13, 2010 | Proform 730 Folding Treadmill Model...
The treadmill keeps cutting out and slowing down during use.
SOUND LIKE A LUBRICATION ISSUE DEPENDING ON THE MANUFACTURER NOW A DAYS SYN SILICON IS USED ON MOST PHENOLIC DECKS IF NO MAINTENANCE HAS BEEN DONE I WOULD ALSO CHECK THE FOR UNEVEN SURFACE AND THE BELT MAYBE TO WORN AND THE LUBRICATE WILL NOT BE EFFECTIVE , BUT ITS CHEAPER TO TRY LUBE THAN NEW BELT AND DECK. GO TO gymparts.com part# TM001 or call them @ 1-800-496-7278
Mar 01, 2010 | Proform 730 Folding Treadmill Model...
Treadmill stops when I step on it?
your running belt might b on 2 tight or u dont have enough power going 2 the motor make shure u have a designated power line 2 your machine
Dec 20, 2009 | Proform 730 Folding Treadmill Model...
Treadmill powers up begins to turn belt then shuts down
Did the shop only do a continuity check or a real load test with amp check also? Motors can look good and run with no load but fail under load.
Mar 25, 2009 | Proform XP Weight Loss 620 Treadmill
Exercise & Fitness Logo
99 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
